How to put bath supports onto new fibre glass bath.It does not have a wooden frame, do I need to make one?
You mean a tub surround? You have no box for the tub to sit in? What were planning on using to hide the sides of the tub? Most big tubs, whirlpools, jacuzzis, etc, sit in a frame work of two by fours and plywood, the ply top supports the tub and the tile, The ply walls or tile board walls are needed for the tile, access to the motor is necessary if you don't have a panel on the tub itself. The tub is set in a finished box, all the tile work done on the top, and set in a ***** of concrete for support. This is for tubs with no sides on them, some tubs have one side finished, and they go up against the walls, and get tiled over the lip. But they get set in mud too. But no walls, just a band against the wall for support. I have seen every tub in every house we have worked on for 25 years done this way, it works. Check it out. Hope this helps. And I hope this is what you are talking about.
