Question about Philips 23PF5320 23 in. HD-Ready LCD Television
Video output from tv to recorder
I have a philips 37inch hi-def lcd tv, can I output the video from the tv to a dvd recorder without using the antenna connection. There are scart connectors on tv but I don't think they output video, or do they?
  • 456 Answers
You can buy Scart connectors that work either solely as an out put, where you can buy some that are solely an input, look for the type of Scrat with a small switch on it, normally means that it is input/output switchable, it may also depend on the tv's scart plug. if the tv says out put or input then you may encounter a problem.
Posted on Nov 27, 2008
No audio
You have to have the cable with three colors, yellow is video, white is one side stereo and red is other side. Plug into av on back of tv then select the av
Dec 25, 2013 | Philips Blu-ray Disc Player with Wi-Fi -...
No Signal from Tv
Yes I beleave it is cabable of recording your tv, one moment.
Apr 20, 2008 | Samsung DVD-VR357
How do i fix a fuzzy picture on dvd recorder play back
What is the resolution of the recorder? If it isn't Hi definition, then you'll never get a really clear picture. OK for older TV's but not Hi Def. You can get a 2 position A/B switch and connect the audio and video OUTputs of the cable box to one side of the switch and the other side to the AV out on the TV.
Aug 09, 2017 | Televison & Video
I have a dvd/vcr rrecorder with no coaxial connection. How can I tape or record a TV program?
Hi,first of all I assume that your Magnavox DVD/VCR Dual Player has the recording features as well..othervise you cant do anything"NEGATIVE" ..If yes than follow the procedure below..
If you want to record your TV program while watching to your DVD/VCR system you need to connect "Video - Audio Output " RCA jacks or "Optic cable output" of your TV or CABLE box to "Audio-Video input or "Optic Cable input" of the DVD
There you go..Your TV's video and sound is on the
DVD/VCR Dual Player Receiver..of course your DVD source input should correspond with the jacks you used on the back...push "RECORD" button it should start for recording the coming signal into DVD
when you recording the output RCA jacks of DVD will generate the signal of whatever records that can be monitored with another TV set after properly connected..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 15, 2011 | Philips Magnavox DVD/VCR Dual Player
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
NON- Hi Def channels loose thier blue? color....picture is all green
Some CATV hi-def receivers are known to have issues keeping up with the datastream. Symptoms from the picture going solid black to other unpredictable video have been seen. Ask your CATV provider if they can switch your brand to another manufacturer. If your cable box has component video jacks in addition to HDMI, try that too. Some boxes will output RGB perfectly but bomb out with HDMI.
May 03, 2008 | Sony KDF-E55A20 55 in. LCD Television
Display mode problems usaing component cables
Is this a high def dvd player and see if you can go into the dvd menu or on the dvd remote to find a formate button. If not give me the dvd model number please..
Aug 16, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Hi Def from dvd player
Tony, Let me ask you a silly ? as Im sure you can answer your own ?. Is your TV Hi def?? NO?? Ok Is your DVD player HI def campadable? Yes. Does your DVD player have RCA outputs for video or s video Output?? Yes. Ok Tony if your TVs not HI def how do you expect to get HI def out of it??? Use rca outputs as it is compadable. if the DVD player has no s video or RCA jacks and I've not seen one yet that didnt then your going to have to get one that does. Good Luck
Jul 30, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Philips 23PF5320 23 in. HD-Ready LCD Television Logo
129 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
