Question about Zoom X6 (5590) DSL Modem (55900003)
Zoom x6 reset back button does not work - Zoom X6 (5590) DSL Modem (55900003)
  • davmor Nov 28, 2008
    Tried it, but guess what? didn´t work. Thanks anyway.
  • 4,806 Answers
It will work, you have to hold the button in for around 60 secs
regards and please remember to rate us
Posted on Nov 27, 2008
  • Lee Hodgson
    Lee Hodgson Nov 28, 2008
    try it again, but this time have the power on if you didn't before
    regards
Is the Zoom ADSL X6 modem router supposed to provide connectivity for a 3G Kindle? If so, how do I set things up?
Zoom X6 routers don't work with either Kindles or Nooks- it seems the connect on demand to save power confuses the Zoom router - typically requiring the unpractical fix of rebooting the router every two minutes.
Feb 03, 2011 | Zoom X6 Adsl Modem/router Rohs...
I have the Zoom X6 (5590) DSL Modem, trouble using software
You may check the following:
1. Make sure to plug the power cube into a power strip or wall outlet and then plug the power cube's other end into the modem's power (PWR) jack.
2. You should only use the power cube with the Zoom X6. Other power cubes may damage your hardware.
3. Try another wall outlet.
4. Reset the modem. Use a paper clip and insert it into the RESET pinhole in the modem's back panel and press it 3 times. Then turn off the modem for a minute and turn it back on. Check if the power light will turn solid green.
5. Possible defective modem.
Hope this helps! Good luck!
Dec 12, 2009 | Zoom X6 Adsl Modem/router Rohs...
I cannot connect my ds lite with zoom wireless
Sometimes they will put the wep key on the router. It should be a 10 digit number. You could also try resetting the router. There should be a very small hole in the back of the router. Stick a paper clip in it and hold down the button for 10 - 15 sec. Good Luck
Jul 13, 2009 | Zoom X6 (5590) DSL Modem (55900003)
Zoom resets using yahoo messenger
http://portforward.com/english/routers/port_forwarding/Zoom/X6/Yahoo_Messenger_Chat.htm
Dec 28, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Reset button does not work zoom x6
This a long one, I have to cut it into 2 parts. Since Fixya have limited space on each of the reponds.
There few steps that you need to take in order to get to the x6 modem.
You may already taken these steps before, but you need to re do this again:
Step1:
Disconnected the modem from the computer and turn it off.
Make sure the DSL software is installed on the computer.
Disconnect the ISP cable from the modem and leave it off for now.
Turn off the computer.
Step2:
Reset the DSL by insert a paper clip into the “reset” pinhole on the rear panel of the DSL and press 3 times (press down and hold for 2 sec).
Connect the DSL to the computer and turn of the DSL first then the computer.
Step3:
Open the browser and type in http://10.0.0.2 on the address bar, press enter.
If this do not open the DSL login page.
Do the following; close the browser.
Open the DOS prompt (if you have windows Xp or Vista-start>>all programs>>accessories>>command prompt.
Type in “ipconfig/all” (without he quote mark) at the blinking curser.
This is what you should see, with little variation, dependent on what is on the network.
Nov 27, 2008 | Zoom X6 (5590) DSL Modem (55900003)
DSL Flashing
You dont need both. Do the following:
Unplug your speedtouch from the phone line at the back of the speedtouch unit. Plug that cable into your Zoom. Then plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Nov 23, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
USB Modem V ADSL Router/Modem
Unplug the plug (from phoneline) on back of USB modem, plug into Zoom router. Plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Aug 12, 2008 | Zoom X6 Adsl Modem/router Rohs...
Zoom x6 model 5590 wireless router
Make sure the Connection Type is set to Static IP on the setup page of the router
Mar 10, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
How to make itouch work with the zoom x6
you have to go to bottom right click the thiung that looks like a computer the y be a button that says fix
Dec 10, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Zoom x6 router
Well for most zoom X6 routers I saw it's
http://10.0.0.2
That should take you to the main page. The manual is located here for X6 models.
http://www.zoom.com/techsupport/adsl/adsl_x6.shtml
In the manual it's on page 13. I would download a copy of the manual and read it as well.
Nov 18, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Zoom X6 (5590) DSL Modem (55900003) Logo
681 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
