Question about iLO (2 GB) MP3 Player
My mp3 blinks blue
Ok i hade my mp3 for a couple of days and now when i turn it on it stays on the blue backlight and it just starts blinking and then it shuts off like whats happening how can i fix it and my batteries are new so i dont knnow whats going on?
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 06, 2008
Why does the red indicator light flash but the tv does not come on? What do you think could be the problem?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Jul 25, 2014 | Element Electronics Televison & Video
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a sharp LC-37D40U that will not power on. The power light blinks 1 time every second. I held the input and volume - button while plugging the TV on and the TV cuts on and then cuts right back off,...
OK if you have blinking red light.
Try to open the cover then disconnect the inverter board after that try to power it on again..
If the light stays in blue (LIT) and of course you don't have picture or backlight you have faulty inverter board that need to be replace.
Nov 08, 2012 | Sharp AQUOS LC-37D40U BACKLIGHT INVERTER...
Proform Elliptical 1050E - Display blinking / going out
you may need a new overlay or console. Call Treadmill Doctor at 800--750-4766 and they can trouble shoot it for free!
Jul 11, 2012 | Exercise & Fitness
2004 Alero. Car turns over, but won't start. Security light blinks.
Hey jonce17....I had the same problem, and my Alero sat in my driveway for 2 days. I looked online for the solution, and I found out how to bypass the security. After it won't start and the security light is blinking, turn the ignition to the on position. Leave it there till the security light stops blinking and stays on (usually takes 9 to 10 minutes). Then turn ignition to off position and start it like normal. This happens to me about once every couple of months. Hope this helps....
Nov 07, 2010 | 2004 Oldsmobile Alero
Screen starting blinking on and off then it stayed
ok check the braces my ds is so messed up and it does the same thing and just like put the ds in different positions and play with it if that doesnt work then use the warranty or sell it.
Aug 14, 2009 | Nintendo DS Lite Console
Barbie mp3 quit working
You have to change the battery. To do that you have to take that thing off on the back of the MP3 player and unscrew it to change the battery.
Mar 05, 2009 | Mattel Barbie Girls MP3 Player
Power goes out
easy fix my friend its temporary firmware problem . ok now to fix it plug the sansa in your pc ,just doing so can fix the problem if not ,unplug it from the pc the unit should have stayed on (the blue LED's of the wheel r on but no screen backlight) push the ON button on the side and hold it push for a good 20 secon then releass it that will make the unit do a soft reset and then turn it back on again it may chow the low bat simbol just plug it back in your pc the screen will show the turning arrow the backlight of the screen will work, let it recharge and there you go fix.
Dec 29, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
My RCA Lyra mp3 player sometimes has blinking backlight and freezes, and System Corrupted
to fix it go to the command prompt and format the drive C:\format G:
this does erase everything on your lyra though hope you have your songs backed up...
Nov 27, 2007 | RCA Lyra RD1072 MP3 Player
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
iLO (2 GB) MP3 Player Logo
21 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
