My soni ericson j108i menu showing other language . i want to change in english.
SOURCE: Change Language Setting on W375
Hello there. please do the following. press the menu button>press the screwdriver option>press the wrench with a brown file icon>go down 6 places from the top and select it> you will then see english at the bottom. hope i helped!
SOURCE: Cant change arabic language to english how can I
Tap 'Start > Settings' (it is represented by a gray gear in front of an yellow folder. It should be the second item, from the bottom to the top, the closest one to the question mark, which stands for Help). Tap the second tab (standing for 'System') and search for an icon representing the Earth (standing for 'Regional Settings'). Tap over it and choose the language that better suits your needs, in the dropdown menu. Tap OK to save and quit.
This procedure won't change the entire ROM to the language you want, of course, but will allow you to better understand what is going on with your device, from now on.
Hope you are able to sort your problems out.
Regards,
Carlos
SOURCE: I entered the wrong language in the setup menu
Hello and Welcome to FixYa!
It is all guess, so I'll try to give you a good guess, because in nearly all the SE phones, the Menu structure is same.
Try this, Go to main menu then settings which the symbols are a screw and a spanner at the bottom right hand corner, then in to phone which the symbol is a phone with a spanner next to it its the second 1 down, then language which the symbol is the world in a text bubble which is also the second one down in the list, there you should be able to correct it.
If you have the manual, it will be much easier to locate the correct option.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
SOURCE: language changing from arabic to english
i want chenge language my i mate phone,,,,,,,please help me......now have italy,,,but i want english how can do it
