Question about Gigabyte GA-7N400 Pro 2 : ATX Socket A FSB400 DDR400 AGP8x SATA/IDE Raid w/audio Gb-LAN (NEWITEM121760113) Motherboard
Turns on & shuts down 5 secs later !
My machine is fitted with a Gigabyte GA-7N400 Pro2 Motherboard socket A/462
when trying to switch on it then shuts down after 5 seconds.
Have tested power supply, Ram & also made sure the processor was ok.
Have already looked at one other solution of moving a jumer but notheing on this machine, also have tried removing the cosmos battery to see would it clear anything.
So any other ideas fokes ?
Ps it seems to have happened after I removed a cable from my printer but the plug was a bit doggey & the wire came but not the plug so may have shorted something !!!!!
Next time the printer gets the hammer treatment I think !
  • ccrozier_agr
    ccrozier_agr Nov 27, 2008
    Have already tried another power supply to the unit.
    Genius:
  • 1,913 Answers
Check yourt power supply waltage and earthing.
also try toi start computer with only mother bord and smps in out of the cpu cabinet.
then check .also disconnect har ddisk and then checxk u get disaply from mothe rbnord.
Posted on Nov 27, 2008
Do gigabyte motherboards GA-7N400 pro2/GA-7N400/GA-7N400L support usb3 cards
Yes, but please make sure you buy the PCI interface version, some of available USB 3.0 card in the market are mostly PCI-express interface. Just tell the store you will install it on the old PCI slot (white one). You also ask them if they have issue with the card that they recommending to you.
Nov 04, 2011 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
Computer was shut down abnormally following a power failure in a thunder storm. No apparent physical damage to machine but will not reboot. Machine gives single long beeps at 6 second intervals. BIOS is...
take out the processor chip and clock battery along with the ram while it is disconnected from the wall outlet and wait about 5 mins. after you put it back together, if the problem persists the processor might need to be replaced or the entire motherboard its self.
Jun 28, 2011 | Gigabyte GA-7N400 Pro2 Motherboard
GA-7N400 Pro2 at startup i hawe long separate continus beeps
Possibly Ram, try and see if removing and replacing helps
Other causes may be voltage issues ( check the bios and see what the various rails are telling you)
eg: there should be readings for 12 volts 5 volts and 3 volts, if any are + or - by 10%, there is an issue with the voltge controller. You might want to try a replacement PSU?
After this.. bad video ( check by installing a video card)
Temperature warnings ( check in bios to see under PC health status) what the cpu and board temps are running at, if above 70 degrees...overheating issue or more likely at start up, board thinks that the CPU fan is not running fast enough or not working. If fan IS working, you have a problem with the CPU fan sensor, will need to replace mobo
Jan 27, 2011 | Gigabyte GA-7N400 Pro2 Motherboard
GA-7N400 Pro2 - GIGA-BYTE i need motherboard driver
can you try this link below:<br /><br /><a href="http://www.driverstock.com/GigaByte-GA-7N400-driver-download/30-9-8109/index.html">http://www.driverstock.com/GigaByte-GA-7N400-driver-download/30-9-8109/index.html<br /></a><br />hope that was helpfull<br /><br />
Aug 30, 2010 | Gigabyte GA-7N400 Pro2 Motherboard
No video and no posting
Your GA-7N400 PRO2 motherboard does not have a built-in video graphics card. You need to install an AGP 8x graphics card into the AGP slot on the motherboard. When you removed the heat-sink & fan assembly the CPU starts to over heat & the CPU will shut down the system. That's why you heard the, european ambulance sound.
If it wouldn’t, you would fry the CPU. Make sure you add thermal grease on to the CPU before re-assembling the heat-sink & fan. Don't forget to plug the CPU fan power connector on to the board.
Motherboard specs;
http://www0.dealtime.com/xPF-Gigabyte-GA-7N400-Pro2
Download & read your manual. Open the link provided here;
http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=1756
Mike
Aug 12, 2009 | Albatron PX865PE Pro Motherboard
How to disable raid feature on ga-7n400 pro2 motherboard
For starters you read your Instruction Manual or User Guide and you will find it there. If you have no manual, you will need to go to our sales department and buy one. CONSTANTIN (arzconst)
Jul 05, 2009 | Gigabyte GA-7N400 Pro2 Motherboard
hi
clear your bios setup with jumper settings.
or
take your cmos cell 15 minutes then put in position.
also check smps.
power cable,power supply.
Mar 26, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
Where to find manuals & Drivers
Here is the link for the drivers, bios, manuals, etc of this motherboard.
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1756
Good luck
Lolita
Nov 01, 2007 | Gigabyte GA-7N400 Pro2 Motherboard
Gigabyte GA-7N400 Pro 2 : ATX Socket A FSB400 DDR400 AGP8x SATA/IDE Raid w/audio Gb-LAN (NEWITEM121760113) Motherboard Logo
109 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
