Denon AVR-3803 Receiver Logo
Posted on Nov 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
System: DENON AVR 3803 The TV is connected to the receiver, so both the audio and video components are fed through the receiver, I think. The image on the TV was present, but the TV/VCR button was pushed on the remote control and interference appeared. No subsequent actions made the picture reappear, including pressing the TV/VCR button again. I don't know if something was reset inside the control's programming interface, but please respond as quickly as possible.
  • Anonymous May 11, 2010
    Are you using the inbult tv tuner are changing channels using your tv or are you using a vcr or dvd recorder as your tv channel?
Anonymous
Level 2:
  • Expert 119 Answers
  • Posted on Mar 03, 2009
Anonymous
Expert
Level 2:
Answers
119
Questions
0
Helped
61322
Points
167
THERE ARE ONLY TWO WAYS THE TV SHOULD BE CONNECTED TO THE DENON,
1. MONITOR OUT OF THE DENON TO AN INPUT ON THE TV.
2. AUDIO OUT FROM THE TV TO AN INPUT ON THE DENON.
ALL YOU DEVICES CAN BE CONNECTED TO THE DENON IF #1 CONNECTION IS USED OR ALL DEVICES CONNECTED TO THE TV IF #2 IS USED
I have a Denon AVR-3803 receiver and I have a DirecTV HD DVR HR 20-700. We believed someone hit a button on the receiver to cause the screen to go black. What buttons should we be pressing to try and...
First thing would be to check all the input settings on the TV and Receiver. Without knowing how it's connected, follow the cables from the Direct TV receiver to the AV receiver then to the TV and note the location. (input name) on the electronics back panel. Then make sure the TV is on that input, (Video1, Video 2, etc) Same on the AV Receiver, make sure the name on the back of the unit where the video cable is plugged into is displayed on the front of the Receivers display (CBL/SAT, HDTV, etc.) Lastly, make sure all the products are "on" especially the Direct TV receiver. It happens! Hope this helps. If you still have an issue, post a comment/reply and I can help you further diagnose the problem.
Hi Have Vizio Flat Screen and a Denon 3803 receiver. The Tv a Vizio 65 Inch flat screen was here. Out of the wall is a power cord and red,blue,green monster cable. Red and Blue is audio and green video I...
Red, Green and Blue cables together typically denotes a component video signal - an Analog, High Definition transportation for video. This cable does not carry audio, you need another cable to hook up audio between the DVR and receiver. You can use either an RCA stereo cable (red and white), optical-audio, HDMI, or a whole plethora of other audio cables. I would recommend optical or HDMI to get the most out of your system.
1helpful
2answers
I just bought a I Pod dock ASD 11R and would like
Get a 3.5 plug with two RCA plugs and connect it to an aux imput via the headphone out of the dock.
Can't record out from a digital input
It only passes the signal it see's. Digital for Digital and Analog for Analog. Try running a Standard analog RCA from your Cable box to the receiver then try and record. Hope this helps. If you still have an issue, post a comment and I can help you further.
2answers
Hooking up an external audio source (IPOD) to the Denon AVR 3803
Yes it is.  You will need to pick up a mini plug to stereo rca adapter.
No television sound from denon avr-3000
TV has Component input (Green,Red,Blue) connect as follows:
1. Connect Component Video and Audio cables from the Cable box, PS3, DVD or Sat box to thea Component Video and Audio input on the Denon (TV/DBS, DBS,VCR1 VRS2, VDP or DVD).
2. Connect a Component Video cable from the Denon to the TV Component Video input.
3. If you do not have a cable or sat box and have a cable from the wall to the TV you must take an RCA(Red&White) audio out of the TV to an input listed in #1
Denon AVR-987 System setup lockout
YOU NEED TO HAVE A MONITOR OUT CABLE FROM THE DENON COMPOSITE, S-VIDEO, COMPONENT OR HDMI TO AND UNUSED INPUT ON THE TV.
SELECT THAT INPUT ON THE TV AND PRESS THE SETUP BUTTON ON THE DENON REMOTE AND YOU SHOULD GET A VIDEO SIGNAL ON THE TV TO UNLOCK
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
