My keybaord has a big problem,each time i press a it is done q as an exemple but when i press q i get the oppsit
    Scholar:
  • 174 Answers
It sounds to me you have your regional settings wrong, a UK keyboard has the @ near the enter key, but a US keyboard has a " near to the enter key on the same key if you get what I mean.
Different regions have different layouts
Go to control panel->regional and language options -> Launguages tab -> then as i guess you are in the UK add the UK layout and delete the Us layout. It will ask to restart and bingo, your layout should be OK.
Posted on Nov 27, 2008
No display on toshiba 2040
When powerin ON the system, is light coming on keybaord ?
check light on keybaord by pressing NUM LOCK key
Oct 11, 2013 | Computers & Internet
Vaio keyboard pcg-5kfp
Trey newegg.com, tigerdirect.com, or any of the other big suppliers out there.
Jul 29, 2013 | Sony VAIO Computers & Internet
Cordless Keybaord - Some keys not functioning
Could be interference from a wireless device using the same frequency. Locate any other wireless keyboard/mice from the vacinity and try it again. Also, push the connect button on the bottom of the keyboard and see if that helps. Also make sure the base station of the keyboard is close enough to the keyboard/mouse.
Jun 25, 2010 | Logitech Wireless Access Duo Optical...
OS set up Problem
The os is founds that no hard drive detection in your Laptop , you first check it in the bios/cmos settings whether the hard drive is detected, if not so means remove you hard drive once and plug it again you can solve the problem, at the bottom of the laptop you see 2-3 openings locked with screws in any one the litter big opening you can find the harddrive ,the omly thing you have to do is have move to the oppsite direction correctly and then back to its normal positon, you can find solution, Thank you , dont forget to vote .
Nov 02, 2009 | Sport & Outdoor - Others
How do i use the num lock keys to type letters in english
Its a very dicey situation here. since the keypad has been damaged. we need to make sure the motherbaord is okay or not. what the best you can do just spend almost $10 and get another external keybaord. or you can use an onscreen keybaord from, start / allprograms /accessories/ accessibility / onscreen keybaord. but its is very difficult to work. untill you get hands on it. so getting an external usb keybaord would be the smartest thing to do. its a very old machine and i am sure it should not be under warranty.
so free option is: onscreen keybaord
least expensie :USB keybaord
Spend a more: get an internal keybaord (laptop)
Costliest: Buy another computer.
Decide what you want to do...
Sep 25, 2009 | Dell Latitude D600 Notebook
Converting degrees and minutes and seconds to radians
With the TI8x/TI8xPlus you can enter an angle in degrees (Angle mode must be set to degrees) and convert it into DMS representation the following way. Exemple
18.675 [2nd][ANGLE][4] [ENTER] gives 18deg 40' 30''
If Angle [MODE] is set to degrees you can enter a number in radians and convert it into degrees. Exemple How many degrees are ther in 1rad ?
[1][2nd][ANGLE][3] display 1 with a small r as superscrit. Pressing [ENTER] yields 57.29577951
To convert 1rad into DMS, takes a little effort but can be done: you have
to convert radians to degrees and the result [ANS] into DMS.
You cannot use an angle written in DMS in any calculation.
But if you want to convert an angle from degrees to radians enter your number and divide by 57.29577951
Hope it helps
Sep 02, 2009 | Texas Instruments TI-84 Plus Calculator
My casio calculator cfx is coming up with 'syn error' everytime I type in a sine cosin or tangent problem
I believe you are not pressing the keys in the right order.
If you know how to set angle unit, skip this part and go to Exemples
If you want to calculate the sine , cosine or tangent of an angle given in degrees, the calculator must have the angle unit set to degrees. To do so :Turn calculator ON, scroll to [RUN] icon and press [EXE] then [SHIFT][SETUP]. On the fifth line angle must be set Degrees. If it is not in degrees, press the key correspondig to menu deg (F1)
(If you have to use the Radian as unit of angle, that is where you set it.)
So your angle is in degrees.
Exemples
To calculate the sine of 15 degrees press [SIN] 15 [EXE].
If expression inside the sine is complicated or contains diverse operations use parentheses as in the exemple
[SIN] [(] 90/2 -180/3 [)] [EXE].
You proceed the same way for cosine, or tangent.
Hope it helps.
Aug 31, 2009 | Casio CFX 9850GB Plus Calculator
Can't find angle measurements function on casio fx 9750
In [RUN], screen press [OPTN][F6:->][F5:ANGL] [EXE].
Exemple 18.53 deg
18.58 [F1 Degree symbol] [EXE] shows 18.58. At the bottom of the screen appears a new option DMS with a left arrow. By pressing the corresponding key [F5], the screen displays 18 deg 34 min and 48 secs. To enter an angle in DMS, exemple the one above, you procedd as follows:
18[F4]34[F4] 48 [F4] [EXE] displays 18.58
Hope it helps.
Aug 20, 2009 | Casio FX-9750GPlus Calculator
How do I know if I am in lower or upper case as there are no lights indicator on my logitech new keyboard.
Well I guess you will know when you try typing, if there is no light indicator on the keyboard ( well there just dumb ) and you can't do anything about it.
Jan 05, 2009 | Logitech Cordless Desktop MX 5000 Laser
Dell Inspiron 1525 keyboard stop working - how can i fix it?
Try in safe mode:
Switch on the laptop and start tapping 'F8' key multiple times (especially when you get the dell logo.Locate safe mode and hit enter (by using the down/up error key).Open a notepad and check all the keybaord keys one by one and confirm if it works.
Test keyboard:
Switch off the laptop (if it is already switched on). Press "Fn" and power key together, this will launch a test (psa), wait for a message "where the color bars displayed",press 'Y' to continue the test. follow onscreen instructions till you rach a window with four options,(express test,symptop test,custom tes,,,,,), click on custom test and select keyboard, click on run test.....and confirm if keybaord works while running the test.
Regards,
Musheer.
Dec 07, 2008 | Dell F3534 Touchpad
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
