Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Cannot reset the time on the TV due to elec out once.
Trying to reset the time after the elec has gone off. Can;t figure it out
  • 903 Answers
Http://www.manualnguide.com/manual-get/4445/
go here and download the user manual
I hope this helps
Posted on Nov 28, 2008
I have new batteries on my Pegasus mobility scooter and it still stalls when going up hill.
hi, there is a chance that the reset switch has gone faulty, at worse the controller is drawing more current than it designed for so that may be a fault ready to happen, but let's be positive, the reset switch needs to be checked...
Regards
Rob
Jan 19, 2016 | Pegasus All Terrain Personal Transporter
Tv shut off wont come back on makes clicking sound
It seems that Tv works for some time and then shuts off, if so it can be due to a thermal shunting and then it seems to hop around trying to start up with a clicking noise.
You need to start by checking on this clicking noise, once this is confirmed it will be relative of the fault.
perhaps it can be due to some loose links, dirt or shorting due to moisture in HT or a trip due to overload or chnages in the +B. All these means that you need to check the board for the correct voltage feed and see if there is any issues.
Nov 07, 2011 | Toshiba 50HDX82 50" Rear Projection...
Tv take a long time for a picture to appear once the power is turned on. is it a problem with the set?
no some of the new> tv < they have 15 to 10 min. window power saver on them they built them like that so just incase of an elec. storm.
Feb 07, 2011 | LG 37LC7D 37 in. LCD HDTV
Panasonic ES2206 elec razor vibrates but doesn't shave
if u had this for over a year and used it every day most likly the batties are gone, but u can try this, use the shaver until all the charge is gone complety wait 10 minutes charge the shaver for a full 24 hour without using it or unpluging it and see what happens some time u need to reset the battery for a full charge
Nov 11, 2009 | Health & Beauty
Cant get any channels between 34-98
If your remote does not have a menue to access auto channel programing, look for it on the TV itself. It may be hiding behind a small panel door, usually toward the bottom of the tv.Once you find it you may have to figure out how to bring the screen up that has programing feature. The screens usually can be brought up by channel or volume controls. Once the auto programing feature appears you push or press ok. If that does not work you should be able to manually key in each channel, one at a time. There as many variations as tvs. Hope this helps. Good luck. Larry
Aug 25, 2009 | GE 19GT317 19" TV
Dish 625 DVR
No this problem is not recognized as common probably due to the limited number of people who actually use optical audio. I hate to say but sounds like it may be time to replace the receiver once more or even trying to get a free upgrade due to this issue.
Sep 15, 2008 | DISH Network DVR-625 DTV Receiver /...
Can't place files on my Dane Elec Usb stick
Well maybe it's full... check.. Maybe it's "Protected" in some way... maybe it needs to be "Shared" in permissions.. otherwise maybe it has gone kaput... hope not.. GL
Jul 25, 2008 | Electronics - Others
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
How do you turn off the progressive scan
I own this model and do have the manual; however, standard AV and S-Video connections do not transfer progressive scan video images. If you hookup a progressive scan output to a non-progressive scan TV input, you will not get an image, so it is probably the way you have your machine connected to your TV that is the problem. If you are trying to watch regular TV through your machine, you will probably need to use a standard Coaxial Cable. I hope this helps.
Nov 03, 2007 | Avion AV-DVR100 DVD Recorder
Sony Tv Problem
standby only usualy flashes when child lock is engaged...normaly a hard reset is in order...
Aug 10, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
