Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water Actuator is broken.
The actuator paddle you press to dispense water has broken off at the base. I have ordered a replacement part but can't figure out how to get the broken part out. Can anyone help. Thanks.
  • 5 more comments
  • hon2007 Nov 24, 2007
    Thank you for your instruction, however i needed to know, in which direction and how to remove the drip tray. How do you snap the tray out.
  • pj149 Mar 01, 2008
    How do you remove the plastic so you can replace a broken water paddle.
  • coolvt86 Oct 13, 2008
    water accuator handle instrall
  • Anonymous Nov 20, 2008
    paddle broke off at base
  • shah255 Nov 26, 2008
    I dont think we can pull the drainage tray out...
  • Anonymous Jan 31, 2009
    paddle broke off how do I replace it?
  • joshguru22 Jun 06, 2010
    actuator paddle to dispense water is broken how do i get the broken part out
I had the same problem with my water dispenser and since they were willing to sell me a part but provided no directions and I couldn't locate any I decided to make my own for those who might need them. Here is a link to a PDF I made, hope it helps.
http://www.rharriman.com/SupportFiles/FridgeActuatorReplacement.pdf
Before starting this job I would also like to warn all to please be save and UNPLUG the fridge. The whole job took me less then 30 minutes and I doubt anything will go bad in that amount of time.
Posted on Mar 31, 2010
  • 8 more comments
  • casewalk17 Sep 09, 2010
    WOW!!! You are a wizard - thank you so much for the ONLY helpful instructions on the web!!! The photo steps were perfect; awesome idea and so gracious of you for posting them! Thanks :)
  • jasont767 Sep 24, 2010
    Excellent guide! I was shocked that this tiny plastic part cost $75-$80. I'm very thankful that I was able to replace the part using this guide, thus forgoing an even more expensive repair. Thank You Kind Sir!!
  • gmmusser Jan 14, 2011
    THANK YOU!!!!!!!!!!!!! Awesome information and help. I DID have trouble with the water hose...very awkward position and it was tough slotting that into the hole again! Anyway, had everything put back together but obviously the water hose was not in position and water trickled and "leaked". No bit deal! When I got to that point again and was able to slip the hose in position, I was able to "hold" the water hose that was poking out with a pair of needle nose pliers. :) SUCCESS....THANKS SO MUCH!
  • mcasey262 Jun 11, 2011
    Like the others on here, I want to thank you for sharing that .pdf. It saved me a lot of time. The only step that made me nervous was the first step. I was afraid that I was going to break the plastic on the bottom that snaps out. I was worried that if the little actuator cost $77 it would be very expensive to replace that bottom piece.
    Fortunately it came off, and the rest went smoothly. Thanks again for your help!
  • Savyguy Jul 02, 2011
    Thank you... excellent detail, you are right.. i did everything until the part of putting back the hose, i can't and is killing me!!
  • ldelizo Jul 27, 2011
    Thank you SO much for your guide.
    The water hose reinstallation is indeed very tricky. To solve this, I got a chopstick (wooden from a take out place), broke it in half, stuck the top thicker end of the half chopstick into the end of the plastic hose, then used the stick to sort of "thread" the hose into the hole.
    The hose is so stiff that when you re-install the dispenser unit and push the unit it into place, the hose is forced into the hole and will stick out a little (as before). Obviously, don't leave the chopstick in there.
    AGAIN, THANK YOU FOR THE EXCELLENT GUIDE. It was a lifesaver!
  • shaasif Aug 04, 2011
    YOU ROCK@!!!!!! Mine just broke and I swear that when I looked at your first pic I thought someone broke into my house and took a pic of my fridge...
  • Tcbking Aug 15, 2011
    Thank you very much. This was the only truly helpful set of instructions that I could find. It was so much easier without second guessing myself and doing it on my own. Thanks.
  • David Hay Dec 11, 2011
    Trying to download pdf, and it is displaying an error.
    Can anyone help, please?!!!! Please let me know how to get pdf, send it to me, or give me some step by step instructions. Thanks!!!
  • app_3rp12648 Mar 26, 2013
    OH no! I really need these instructions! Could you upload them again with a new link here? the link is bad!
I just replaced the water actuator. The problem is getting access to the actuator. this is what i did; turn off the power Remove the drain tray it just snaps out. remove the 3 screws behind the tray. carefully lift the panel up and out. There is a short control wire connecting the panel to the frig so be careful. remove the water hose from the outlet hole and remove the ice and water module. the rest is self explanatory.
Posted on Feb 03, 2007
  • 237 Answers
This diagram may help you see what's behind all that stuff. Let me know if it helps or if you need something better. http://www.partselect.com/Schematics/Frigidaire/YZ41HPYZ.gif
Posted on Jan 13, 2007
What happens if your helper drops the front panel and the control ribbon comes out of the front board? Since I put it back together the ice dispenser will not stop running. Do I have to replace the board to fix this?
Posted on Jun 16, 2008
  • mukeshwani Apr 22, 2011
    I have the same problem. Replaced the water actuator and put everything back, once I plug in the ribbon back into the door panel the ice dispenser will not stop running. Any ideas?a
Just replacede the paddle on FRS6HF55KS frigidaire and all seems good but no power and nothing works now
Posted on Dec 23, 2009
  • befahrendorf Dec 23, 2009
    FRS6HF55KS frigidaire i replaced the water paddle and now, no power or water
I have LG refrigerator model LFX25975ST. Stuck Water Dispenser. Can I order and replace button and actuator rather than calling repairman?
Can I order and replace button and actuator rather than calling repairman? That is a question you would have to pose to LG or an appliance parts supplier.
Apr 01, 2018 | LG Refrigerators
Water dispenser not working
It may be the paddle actuator if you have one. the water valve could be the problem. It is common especially in GE refrigerators for the water tube to freeze in the door. this will require thawing out the door for a few hours. To check there is a disconnect behind the bottom grill where you can disconnect the water line to the door. If water comes out there when the water dispenser is activated then the water line is frozen in the door.
Mar 14, 2015 | Refrigerators
Water dispenser for gsh25JSTA BROKE can I fix
All of you guys are wrong. What that person is saying is that the physical paddle used when you place your glass in the dispenser bay and press against the paddle....That's what's broken the paddle......
Jan 05, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Internal water dispenser rf266ab rubber cover came off and it appears there is a piece missing that holds the plastic piece down to dispence water
Had same problem. Ordered a part that appears to just snap in and replace the broken water dispenser face at this website. http://www.repairclinic.com/PartDetail/Dispenser-Actuator/DA9704952B/2049390
Apr 19, 2012 | Samsung Refrigerators
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
I have a stainless steel Frigidaire side-by-side refrigerator with an ice/water dispenser in the door. The paddle on the water dispenser broke, and I need advise on how to disassemble the dispenser in...
the front cover will come off. if you dont see any screws then it WILL unsnap. look for a slot on the top or bottom of the cover. good luck some of them can be nasty
Oct 28, 2009 | Refrigerators
Ice and water dispenser stopped working
Welcome to the computer world. When depressed, the paddle actuates a switch attached to the bracket above. The switch sends a low voltage signal to a small circuit board mouted right behind the display. A computer chip on that small board communicates with another chip on the main control board mounted in the rear wall. Your situation could be a bad actuator switch, a broken paddle tab, possibly a bad door switch (the fresh food doors must be closed to dispense), or a bad electronic control.
Jun 05, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Need to replace the water actuator on frigidaire model FRS6B7EESB
To get help replacing the actuator you can visit mu site below and enter your model number FRS26R4A in search feature this will take you to the parts page. On left of screen click picture #15 dispenser. I shows a diagram of the parts and I or Appliance Parts can assist you in installing the actuator. Thanks Sea Breeze sea breezehvac@yahoo.com
click on link below
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Frigidaire FRS26R4A Side by Side...
Broken water actuator
Hi this is tech crazy
the solution to the problem is
You should be able to replace this part yourself. Follow these steps to replace the water actuator:
  1. Unplug the refrigerator to completely disconnect electrical power. Turn off the water supply to the refrigerator.
  2. Remove the drip tray (Key 23 in the image below) from the bottom of the dispenser.
  3. Remove the screws (Key 43) from the bottom of the dispenser module cover (Key 4). NOTE: You model may not have screws at the bottom of the dispenser cover. If not, push down on the top of the dispenser cover and pry out on the bottom of the cover with a flat tip screw driver to remove it.
  4. Pull to dispenser module cover up to release the top clips and remove this cover and set it aside.
  5. Remove the screws (Key 17) that are on each side of the dispenser module (Key 8).
  6. Carefully pull the dispenser module out slightly from the door. It will have wires attached. Pay attention to how the water tube and the ice door assembly are positioned. Pull this module out far enough to remove and replace your water actuator (Key 24).
Reverse the above process for reassembly.
Jan 25, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
HOTPOINT HSS25IFMCWW
is the ice side working? it could just be the water paddle or actuator or you may have a frozen water line.
Sep 12, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
5,093 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
