Question about Zenith DBZN-311 Remote Control
Comcast Remote Can't Program My Sceptre HDTV
Supposedly the Sceptre HDTV's use the Sony remote code (0000 or 0111), for the Comcast 3 n 1 remote. Not so. Does anyone have a clue what it may be? I have seen other people have this problem. Some have found a code that will turn on and off the Sceptre HDTV, but will not control the TV volume from the remote.
  • 2 more comments
  • dquin656 Nov 27, 2008
    I feel like such a fool. I didn't realize there were so many different kinds of comcast remotes. It turns out that I have a OnDemand DVR remote and that uses a 5 digit number, instead of the 4 digit number.
    I started with the basic Sony 5 digit code (10000) and ta da! It worked! And, the sound button also works.
    I hope this will help others that are remote control challanged, like myself.
  • Bill Lowry Oct 10, 2012
    Thank for ending my frustration. Bill in Mi.
  • toomuchrock
    toomuchrock Dec 19, 2012
    10000 works and "exit" swaps the sources
  • R Foltman
    R Foltman Apr 28, 2014
    Spectre x325bv-FMDR doesn't have a code for Comcast any help?
  • 3 Answers
Thanks...this worked great for me. I used code 11100 on my Sceptre tv and it appears to be working perfectly!
Posted on Mar 11, 2010
I tried the same thing and it worked. Odd thing is that the rocker key marked "volume" doesn't do anything -- but in the TV mode, the left-right buttons around the OK button control the TV volume. I guess the "whatever" theory works, too. ;-)
Posted on May 30, 2009
  • petmak Oct 27, 2010
    The 11100 code works for the X42 Naga and the left/right buttons on the comcast red ok remote do control the volume. Thanks so much!
Codes for Comcast remote
Go to this website: Comcast Remote Codes Program Your Remote Control
It will guide you through the setup process based on your remote. But these could be the codes when you set it up:
13899, 12528, 12337, 14160, 11217, 11360, 12633, 14139, 10878, 12935, 11599, 12506
Nov 01, 2015 | Sceptre Televison & Video
Need a code for my Sony RM-Y16 Remote to split screen with my Comcast DVR
It is possible that this remote will not program to your Comcast dvr. Your DVR is probably newer than the remote and has new codes that the remote doesn't support. The only thing you can do now, is either purchase a new universal remote that supports both units. or use your Comcast remote to program it to your TV. the Comcast remotes are programmable.
Oct 07, 2012 | Sony RM-Y916 Remote Control
I have a Sceptre 46 in. LCD TV. It worked fine with Comcast until 4:00 AM EST last Wednesday, when it turned itself on. I came into the living room and saw the display on the COMCAST DVR flashing on and...
Try reprogramming the remote the code for scepter is
10889 if you have a RED ok select button on your remote or if you have a DARK SILVER remote
Brand: Sceptre
Most likely code: 10889
  1. Turn on a device (e.g., VCR or DVD Player) and, if applicable, insert media, (e.g., video cassette or disc).
    NOTE: Please read steps 2 to 6 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2
  2. On the remote control, press a device key once (i.e., or TV).
    NOTE: Use the AUX key to program control of an Audio Amplifier or Receiver, a DVD Player, a Home-Theater-In-A-Box Device, a PVR (or DVR), or a VCR.
  3. Press and hold Setup until the selected mode key blinks twice, then release Setup.
  4. Locate the code for your device in Manufacturer's Codes listed below. Brands are listed in alphabetical order with the most popular codes listed first.
  5. Enter the first five-digit code for your device. If you perform this procedure correctly, the selected mode key will blink twice.
    NOTE: If you enter an invalid code, the selected mode key will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
  6. Aim the remote control at your device and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 6, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
    NOTE: If the device does not have a Power key, press the (Play) key
Dec 02, 2010 | Sceptre X42GV-Naga 42 in. LCD Television
Comcast Remote Control - Won't accept remote codes
To reset the remote control, just take out the battery from the remote control, and reinsert it after an hour or so. The remote control will reset itself.
After that try to set it up with the setup code said for your device. You might have to try many codes before getting a code that'll have the most functionality with your device.
Setup procedure and set up code list of many popular brand remote controls are given by these sites. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
Mar 04, 2017 | Motorola Televison & Video
Can't find remote codes for comast remote
Comcast has not added remote codes for that brand to their cable remote. This is likely because they haven't received the IR frequencies from your TVs manufacturer. This is a common problem with TV companies that are small and don't yet have a lot of models or total sales.
I'm afraid for now, you'll have to use two remotes. Unless you want to purchase a learning remote that can replace both the TV and the cable remote. A learning remote works by picking up the necessary frequencies directly from the remote you want to replace.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today!
Please post a comment if you need additional assistance so that I can help you further.
Jan 11, 2010 | Televison & Video
Sony tv comcast remote code the codes 0000,0111 dont work
if your remote has a red ok button then you need a five digit code. try 11100, 10000, 11317. if you have a remote with a gray ok button then 0000 should work. if this doesnt work, write me back telling me what color your ok button is and i will send you instructions on how to scan for your code.
Oct 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How to program comcast remote with my toshiba 19hlv87
with comcast remote with red ok select switch the toshiba codes are 11256 most likely, other codes are 10154, 10156, 11265, 10060, 10650, 10845, 11156, 11356, 11656, 11704
with comcast remote with grey ok select swithc the toshiba codes are 0154, 0156, 0060
Dale
Jun 05, 2009 | Toshiba 19HLV87 19 in. LCD HDTV
LG 42PB4D 42" Plasma TV
This worked for me too! THANKS
Dec 04, 2007 | LG 42PB4D 42 in. Plasma HDTV
Zenith DBZN-311 Remote Control Logo
9,392 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
