Question about HP OfficeJet J4580 All-In-One Laser Printer
I cannot receive or send faxs' ineed to changespeed to 9600' and
ECM to on
    Scholar:
  • 174 Answers
ECM error message
Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
  • All faxes sent in color use ECM.
  • All faxes sent at the highest transmission speed use ECM.
  • The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
  1. On the product control panel, press the Menu button (c01743394.gif ).
  2. Use the arrow buttons (c01073166.jpg ) to select Basic Fax , and then press the OK button (c01335940.jpg ).
  3. Use the arrow buttons (c01073166.jpg ) to select ECM Mode , and then press the OK button (c01335940.jpg ).
  4. Use the arrow buttons (c01073166.jpg ) to select On or Off , and then press the OK button (c01335940.jpg ) to confirm the setting.
  5. Press the Back button (c01496476.gif ) twice to return to the main screen.
Mar 06, 2014 | HEWLETT-PACKARD HP 2140 Fax
Hi i can't send and receive faxes. My phone
Here's the link to download the Lexmark X7170 User's Guide: http://bit.ly/c8EHEn. Go to Faxing for the instructions on how to go through the settings on the printer. For setting the printer to ring to answer at 0, set it to pickup on the 1st ring. To turn off the distinctive ring, set the ring pattern to any. Hope this helps.
Jul 15, 2010 | Lexmark X7170 All-In-One InkJet Printer
Dell 1600n only receives 1 page of fax.
turn off ECM (error correction).
then if problem persists, slow down the fax speed to 9600 bps.
this problem always occurs with a digital or VOIP line.
Jan 14, 2009 | Dell 1600n All-In-One Laser Printer
Having a hard time receiving fax and sending fax from my hp-5600 all in one sends error 232 how do i fix?
This is not a fix but will probably make it work. Turn off ECM (error correction mode) set both send and receive speed to 9600.
Nov 16, 2008 | HP Office Equipment & Supplies
Baud rate
# Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
1. Press the Fax button, then press Options untill it gets to ADVANCED FAX.
2. Press Select.
3. Press Options untill it getsl MAX SEND SPEED appears on the LCD display.
4. Change it to 9600 BPS using the - (left arrow) button.
5. Press Select.
# Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
1. Press the Fax button, then press Option untill it gets to ADVANCED FAX.
2. Press Select.
3. Press Options until ERROR CORRECTION appears on the LCD display.
4. Change the setting from On to Off using the + (right arrow) button.
5. Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes.
Mar 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
CANT SEND FAX THRU VOIP LINE
Make sure baud rate is set to 9600 and error correction mode (ECM) is off. If this does not correct your issue then you may have to contact your provider to adjust your sample rate (packetization). This adjusts the size of the packets and is often a common fix. You may want to run a ping/tracert from command prompt to check for latency and/or packet loss with your ISP. I'm a voip tech and these are the primary fixes for fax issues.
Jan 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Sending Fax
set baud rate to 9600 or slow
set resolution to standard
set error correction mode (ECM) off
if fax has overseas mode turn it on
vonage can make changes to the line that could help, if your using a voice line with call waiting use *70 prior to the number to disable call waiting for that call
Dec 31, 2007 | Lexmark X125 All-In-One InkJet Printer
Any way to manually LOWER the Fax Connection Baud Rate?
Newer fax technology adjusts transmission speed automatcally, so no adjustment is necesary. therefore, there is no menu option to change it. Your problem resides either on your phone line or the one you are trying to connect to. Call the other people and ask them if thei are receiving without problem. If you are able to transmit elsewhere and the other party is receiving from everywhere, try turning off the ECM option on your unit.
Oct 27, 2007 | Samsung SCX 4521F All-In-One Laser Printer
HP OfficeJet J4580 All-In-One Laser Printer Logo
59 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
