Question about Denon AVR-1601 Receiver
AVR-1601 Keeps Jumping to Pro Logic TV
A strange thing has suddenly developed with this receiver. When I try to set the audio to TV/DBS, it goes there for a moment, pauses, goes to D-Coaxial, and then settles at "Pro Logic TV." With that setting, I'm getting no tv audio through my sound system. I've tried turning the receiver on and off, and repeatedly tried to get it to go to the TV/DBS setting. Any idea why it refuses to stay there?
5 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: Manul denon avr-1601 en castellano
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-1601&imageField.x=15&imageField.y=13
Espagnol as well ...I think
Posted on Feb 16, 2009
housejess
  • 317 Answers
SOURCE: Denon AVR 2308 ci. No sound when using TV (Niece changed setting
there should be a way to change a setting between.....analog, coaxial, optical 1 and optical 2..if everything is connected through rca jacks try analog
Posted on Nov 04, 2009
SOURCE: No audio running TV through Denon AVR 1910
I had the same problem. You're not doing anything wrong. the thing is you can't (I don't know why but the owner manual says it) have sound going to your tv AND your HT speakers when you're using HDMI. You should try going to input setup, choose hdmi audio out to your TV instead of the speakers, and then run an optical cable from your satellite to your receiver, assigning it to the TV/Cable input.
Posted on Jan 20, 2010
SOURCE: apple tv to optical audio on avr 1601
You need to assign the optical input to the video input you are using. It's under the 'Input Setup' menu.
Or use HDMI, it will output the audio thru the HDMI connection. Once again assign the input under the Input Setup menu (press the Menu button on remote to access setup menus)
Posted on Dec 11, 2011
I have a Denon AVR-2801. I use an optical cable from the TV for Audio Out to the receiver. I set the receiver to TV/DBS but when it comes on, it just says TV and I get no sound from the receiver to
You need to do the input assign. The receiver doesn't yet know that you plugged a cable in to one of the Optical ports.
If you have done the above, then the next thing is to check the amp's Mode button. This cycles the input between Optical and analogue audio inputs.
Sep 05, 2014 | Denon AVR-2801 Receiver
Configuration Audio from Samsung digital tv with sony Bluray player Hdmi already to Tv
all components should go directly to the AVR. Then the video only to the digital TV.
Mar 19, 2014 | Denon AVR-1601 Receiver
Apple tv to optical audio on avr 1601
Nov 19, 2011 | Denon AVR-1601 Receiver
I have denon avr 987 receiver i messed up settings somehow. when i have receiver set to dolby digital tv i get sound, but no picture. if i switch the setting to DBS i get picture buy no sound. what did...
Are your DD TV and DBS referring to the same source device or are they separate, say, cable Box and Sat Box?
Start over with the digital audio assignments for wherever you plugged in the digital audio cable from (guessing) your Cable TV box (recommended as "TV" is not usually a great source for audio).
The manual:
http://www.retrevo.com/support/Denon-AVR-987-Receivers-manual/id/696dj079/t/2/
You might also want to define the specific cabling of things if more is required. Exact point-to-point paths and cable styles for audio and video.
Dec 31, 2010 | Denon AVR-987 Receiver
I have picture on vcr 1 but sound on tv dbs on the remote how can i sync them
It has nothing to do with the remote. Reconnect the audio and video cables to the same input source on the receiver, either VCR1 or DBS (after turning off the receiver!).
Feb 09, 2010 | Denon AVR-2106 Receiver
How can i connect Nintendo wii to avr-590. Have
To connect a Nintendo Wii to an AVR-590, I am assuming this is a Denon Receiver, you will need to connect the Nintendo Wii to the TV, then connect audio out from the TV to the AVR-590 Receiver, and select the receiver to be in Pro Logic. Depending on the TV, if you have fiberoptic output on the TV, you would hook a fiberoptic out from the TV to the AV Receiver, but you will still not get true Dolby Digital, just Dolby Pro Logic. This will be the most effective way to solve the problem. Hope This Helps
Geek Squad
Dec 28, 2009 | Electronics - Others
Dec 12, 2008 | Denon AVR-1601 Receiver
Denon Receiver keeps changing channels
hello my friend this is happening cause you have a push in button,disconnect from ac take a near look and push the reset button you must check your remote too saludos
Dec 12, 2008 | Denon AVR-2807 Receiver
No television sound from denon avr-3000
TV has Component input (Green,Red,Blue) connect as follows:
1. Connect Component Video and Audio cables from the Cable box, PS3, DVD or Sat box to thea Component Video and Audio input on the Denon (TV/DBS, DBS,VCR1 VRS2, VDP or DVD).
2. Connect a Component Video cable from the Denon to the TV Component Video input.
3. If you do not have a cable or sat box and have a cable from the wall to the TV you must take an RCA(Red&White) audio out of the TV to an input listed in #1
Nov 21, 2008 | Denon AVR-2106 Receiver
Denon AVR-1601 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
