Question about HP PSC 2110 All-In-One InkJet Printer
My HP psc 2115 reports "Remove & check black cartride"
This happened before and cleared itself when I replaced the cartridge, but this time a brand new cartridge has made no difference.
SOURCE: hp psc 2410xi photosmart all-in-one printer.
Airportbum,
I have the same issue. How did you "fix" the circuit board?
Posted on Apr 24, 2008
  • 32 Answers
SOURCE: remove and check color cartride error message
hi zmoyo-
with your post date of 10/22/08, this may no longer be a problem for you. I hope not, but if it is, here are a couple links that might help. they are from HP's support site for your model:
http://h10025.www1.hp.com/ewfrf/wc/documentIndex?lc=en&dlc=en&cc=us&lang=en&product=422000&
(for general FAQs) (Note: If you try to go to this link from a site overseas and the web page will not come up, try adding "amp;" after each "&" in the URL)
here's a link for general info for this model:
http://h10025.www1.hp.com/ewfrf/wc/product?product=422000&lc=en&cc=us&dlc=en&lang=en&cc=us
and here's a quick link for a support doc re: messages and lights displayed on the printer:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=33365&lc=en&dlc=en&cc=us&lang=en&product=422000
hope this helps for future refs. if you keep getting the cannot find eligible device message, try first printing a test page (or anything) to the printer. try checking all your cables to ensure they are seated snuggly. try using a different USB port. try rebooting your computer without the printer plugged in, then plug it in and see if your computer recognizes it before trying to upgrade the firmware again. good luck.
- JW50
Posted on Nov 04, 2008
jacklee366
  • 541 Answers
SOURCE: can't clear ''remove and check color cartridge''
if you go on the hp website and click on live chat they will help you tho it
Posted on Nov 19, 2008
  • 119 Answers
SOURCE: re: hp psc 2410xi photosmart message: remove
Are you using genuine HP cartridges or have you refilled old cartridges recently?
These are typical problem when either the cartridges is non HP genuine type or if it has been refilled.
Posted on Mar 29, 2010
  • 5523 Answers
SOURCE: I have a hp psc 950 I set uo align cartridge clear
There are several possibilities that you can check. First, what is the ink level for all colors? You need enough ink in all of the cartridges, black and the three color tanks in the color cartridge. A low ink in any one cartridge could do this.
Second, make sure you are printing on clean white letter or A4 paper (no additional print on the page). Is the paper feeding correctly from the paper tray? Did the alignment page print and arrive in the output tray? Check for a paper mismatch warning or if 4x6 paper selector lever is pushed forward on the output tray. Make sure the selector is pushed all the way towards the printer. Did the alignment page look like the previous alignment pages or the ones shown here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00657&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=60259#Alignment_Pages .
If any color is missing, look for a problem with the cartridges. Try running a cleaning cycle: press Menu (or Setup, depending on the printer) on the printer. Press the right arrow until you see Maintenance or Tools. Press OK and then OK again if Clean Print Cartridges is highlighted. (Otherwise, highlight the Clean Print Cartridge by pressing the arrow keys and then press OK.) If the output is missing, faded, or streaked. Note: a low ink issue will be made worse with a cleaning. It is a cartridge issue. This could be a symptom of clogged nozzles on the cartridge, the protective tape still on the cartridge, or poor contact between the cartridge electrical contacts and the matching ones on the print head. Remanufactured and refilled cartridges are at higher risk of failing. However, the chip on the cartridge can also fail; in this case, if you have a genuine HP cartridge, contact HP. Replace the cartridges. You may want to clean the cartridges and the print head. Use distilled or bottled water and lint free paper or swabs. (coffee filters can be used.) Wipe away from the nozzles (the contacts, edges and ramps of the cartridge) of the cartridge and the contacts inside the printer. Wipe in one direction only even on the contacts inside the printer.
Reset the printer by unplugging the power cord for at least 5 seconds before plugging it back in. Print a new alignment page. Does the printer give one or two pages? If you only get one page, the alignment is automatic and you should see a blue light at times as the printer feeds and prints the page. If no light shows up, the printer needs service.
If you get two pages, check the scanner glass and white scan backing. Clean the surfaces with a soft cloth dampened with clean water, if they need cleaning. Check if the bulb assembly is lighting up when the unit is on. If that scanner light doesn't come on, the all-in-one needs service. Make sure to put the alignment page face down on the glass or face up in the ADF. Copy the alignment page. If the copy has vertical streaks, clean the scanner assembly. (If this cleaning doesn't help, again the unit needs service.)
You can bypass the required alignment. Press and hold the Enter button and then press the Setup button. The unit should print but the print quality will be poorer. If any colors are missing, check the ink level and for clogged nozzles.
I hope this helps.
Posted on Oct 28, 2010
I added new office max brand ink cartridge to my hp psc 2210 printer and i keep getting a "remove and check cartridge". i took inkcartridges out and replace the ink cartridge a couple of time and still...
A lot of branded ink pots have chips in them some dont it sounds like your hp printer is not getting the correct response from these ink pots , you could try to override the report and tell it to print anyway
Sep 19, 2010 | HP PSC 2210 All-In-One InkJet Printer
Black re-mfg for psc 1610 prints unreadable
your black print cartridges has been dried, these need to replace.
Aug 22, 2009 | HP PSC 1610 All-In-One InkJet Printer
Psc750 alarm message: remove and check black cartridge.
There seems to be a problem with the cartridge. If it is printing normally, you can either live with the error, or replace the cartridge.
You can try cleaning the contacts with a q-tip and some rubbing alcohol just in case.
Jun 22, 2009 | HP PSC 750 All-In-One InkJet Printer
Cannot remove the align cartride memo
Replace all ink cartridges with new HP carts.
Feb 08, 2009 | HP PSC 950 All-In-One InkJet Printer
Your HP PSC 1210 All-In-One
if cleaning wont work & cartridges are most 6 mos, trying a different cartridge will fix it
Jul 31, 2008 | HP PSC 1210 All-In-One InkJet Printer
Cant print black or do black and white copies
He's not saying that the black cartridge won't print (which would warrant cleaning the heads, or messing with the cartridges) -- I have the same problem that MarkDan is having as well... no matter what you select as the output from any "Print" dialog window, the HP 21xx and 12xx series printers _always_ print in full color. You can choose Black and White, Greyscale, Color -- doesn't matter what you choose in the dialog boxes, it utterly ignores you, and will always print in color.
I have no idea why it does this, but it's eating a _ton_ of color ink for no good reason. I have searched all over the Web and on HP's site, but solution has been found.
Jul 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 2410xi photosmart all-in-one printer.
Here's what I found when this happend on my two 7410's. Take a look at where the ink cartridge slides into it's holder. Shine a flashlight on the circuit board at the rear. You will no doubt find it has a puncture in it that breaks the little tracer wires on the board. The culpret is the tension spring arm. It likely has come off it's base support and when that happens, and you install a new cartridge, the cartridge will push the tip of the tension wire g right into the circuit board. After you fix the circuit board, apply some silicone glue to the spring base mount to hold it in place.
Apr 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP PSC 750 PROBLEM
Had the same problem. Cleaned the copper-colored "contacts" on the actual printer. Where the printer and the cartridge touch ... you will see them when you take the cartridge out. Hope that helps.
Feb 17, 2008 | HP PSC 750 All-In-One InkJet Printer
PSC 2115 error message
turn off your machine unplug the power for about 5 mins. disconnect the usb cable from back. Plug back in power, wait until machine fully boots up. Check your cartidges to make sure there in there good and are not lose. Remove them and just put them back in making sure there secure. Then try to aline the cartidges.
Feb 16, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 2110 All-In-One InkJet Printer Logo
217 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
