Question about Acer Aspire 3000 Notebook
Memory upgrade for freevents X50
How do I get to the memory slots - are they under the keyboard? If so how do I remove the keyboard?
I recently put an additional 1Gb memory in my Freevents X50. The hardest part was removing the casing - which I could do not completely.
There are two slots for the memory which can be found under the bottom right of the casing - below the keyboard (where the stickers are near the 3 USB Slots).
Beware I really had a lot of trouble with the case thoug. I removed all the screws for the casing only to find it was still attached somewhere in the middle under the keyboard and I could'nt find where !.
Eventually I managed to insert the card in the slot by gently parting the casing at the side - not an ideal solution because I could have broken something if I was not gentle but it worked !
Posted on Dec 27, 2008
    Problem Solver:
  • 10 Answers
What is the model of this brand and model of this Laptop? How many memory sticks do you wish to install?
In most Laptops, if you flip it over so you are looking at the bottom where the battery is, there is a cover held on by one screw that has an "M" etched into it. That will have one of the memory slots and sometimes both depending on the brand. If there is only one memory slot there and you need to upgrade two, replace that the 1st and the 2nd will be under the keyboard. Taking the keyboard off is fairly simple, you will have a plastic strip on where the buttons are that should have a little groove on the right or left side just big enough to fit a small screw driver in. Carefully pop off that plastic strip. You will now see anywhere from 1-3 screws that holds the keyboard down. Remove those screws and very slowly and carefully remove the keyboard, you may have to disconnect a cable on the bottom of the keyboard if you cannot move it far away enough to install the memory 2nd memory stick.
Please let me know if this solved your problem or if I can be of further assistance.
Thanks,
Adam
Posted on Nov 28, 2008
Philips Freevents X65 - how do I access memory slots to upgrade
Most times the memory slots will be on the bottom of the laptop. You just remove the power cord, remove the battery then remove the screws to the cover that houses the memory. Look for little icons on the cover, the circular discs will be the cd drive and the hard drive. The memory cover icon will have a jagged square on it.
If the memory is not on the bottom of the laptop then it will be located under the keyboard and palmrest area which means you will have to take them apart to get to it.
Jun 05, 2012 | Computers & Internet
Where are memory slots on Freevents X65
How can i get to both memory slots so i can upgrade to 2GB of Ram? Thanks
Your laptop has two memory slots. One of the memory slots (external) can be easily accessed if you remove the cover on the bottom of the laptop.
The second (internal) memory slot is located under the keyboard.
Keyboard removal procedure:
1. Unplug the AC adapter and remove the battery.
2. Remove two screws securing the keyboard on the bottom of the laptop. These screws are marked with a small keyboard symbol.
3. Release 4 keyboard retention tabs located on the left side from f1, f5, f9 and delete keys.
4. Lift up the keyboard and place it upside down on the palm rest.
5. Unlock the keyboard cable connector on the motherboard.
6. Remove and replace the keyboard.
Hope this helps. Thank you for using FixYa.
Sep 30, 2010 | HP Compaq nx8220 Notebook
Philips X50 charging problems
1st remove Battery after few min insert battery and connect charger Then power on laptop.If not on check Power Mosfet or Power ic.
Jun 27, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
How to upgrade RAM memory for Laptop Philips X50 Freevents?
there are 2 memory slots under the keyboard cover at the front right of the laptop. If you unscrew the 4 screws at that run along the front of the base and the 2 that relate to the front right as you look down at the keyboard you will be able to gently unclip the keyboard cover on that side and gain access. be careful though as the cover is held in place on the left by a hidden clip that I have not found as yet.
The dimm installed in the back slot is a 512mb ddr333mhz pc2700 sodimm.
Apr 16, 2009 | Computers & Internet
Philips Freevents X50 Upgrading
With this computer it is not possible to upgrade the processor.
Dec 27, 2008 | Computers & Internet
Laptop memory
got it...well..then you'll find that under the bottom, where there is a plate with one or two screws..if you have more memory(check your system in control panel) then you may find more under the keyboard.
Mar 11, 2008 | Computers & Internet
Sony A690 Memory Location
Some Vaio laptops (and some HP's) have a memory slot under the keyboard.
Jan 26, 2008 | Sony VAIO VGN-A690 Notebook
Twinhead 12D Laptop
Are you sure you have all the screws out, there is a small plastic disc on the bottom of the laptop underneath the card slot, this needs to be removed to access a screw (obviously take out plastic blank in slot first).
And there is not much reason to dismantle LCD either.
What is it you are trying to do.
Dec 04, 2007 | Twinhead SlimNote N12PI Notebook PC
Philips freevent x50
a hidden screw ,on top side beneath the keyborad "just left of the keyboard ribbon cable" has to be removed then it slides out with ease.
Nov 10, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
163 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
