Question about Logitech QuickCam Fusion Webcam
Quickcam Fusion Sound recording
Does the Fusion come with a mic built in? I am using Vista and cannot get any sound to record.
  • perryrose Nov 27, 2008
    I discovered my own solution to the problem. The Fusion cam has a mic selector. You go to the setup program and select the picture of the mic. You then select Microphone (2 Logitec Mic Fusion). Now it works. Anyone having the same issue try this out.
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Posted on Feb 15, 2009
My computer speakers stopped working after installing Logitech quickcam deluxe for notebooks. Please help.
Run an audio check
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Aug 28, 2010 | Logitech QuickCam Deluxe for Notebooks
My webcam works fine on other websites but when i try to talk nothing happens. It works fine when i test it but not on websites
You need to set the mic you wish to use with the webcam as the 'Default' mic
XP
Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your preferred mic the default device in the 'Sound recording window'
VISTA
TEST SPEAKERS
Restart computer
Configure to your chat program
Aug 25, 2010 | Logitech QuickCam Fusion Webcam
No sound
You may have a laptop with a built in mic or headphones with built in mic and webcam with built in mic
You need to set your webcam mic as default
Vista
TEST SPEAKERS
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
Restart computer
May 23, 2010 | Logitech QuickCam Deluxe for Notebooks
Sound won't work
make sure the webcam mic is set as default - especially importsnt if you have laptop with a built in mic as well
TEST SPEAKERS
Restart computer
May 02, 2010 | Logitech QuickCam Communicate STX Personal...
We cant record a video clip with sound - only picture
You need to go into the recorder options ant tell it the sound source to us is the USB Mic. on the webcam, or what ever the source of the Mic. is. There are several sources in Skype that allow changes to be made. Use the drop down menu for the selection and select the one you are using for the mic. Good Luck, RAC
Mar 28, 2009 | Logitech QuickCam Connect Webcam
No sound when connected on aim
Is your microphone integrated into your webcam? Make sure the correct device is selected. Go into Edit, Settings, Enhanced IM. Under Audio and Video, make sure the Microphone device selected is a functioning mic, such as Logitech Mic, or if using a headset, select the USB headset (if usb) or your sound card if using a mic plugged into your built in or add-on sound card.
Dec 01, 2008 | Logitech QuickCam Connect Webcam
I've bought a logitech quickcam communicate STX. When I installed it first it worked fine. Someone unpluged it from the usb port and it wouldn't work. I re-installed the drivers and it was fine again but...
The microphone may not work because of a hardware or configuration problem. To determine if it's a hardware problem, test the microphone in Sound Recorder.
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
The microphone may also be defective. To test this, try the camera on another USB enabled system.
If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
Feb 25, 2008 | Logitech Webcam
My mic doesnt work
to put that in cam microphone working, you need to see on audio settings properties and change the "recording device" to usb audio device, instaid of the soundcard as is. That means that the sound recording will be from the cam's microphone.
The steps are:
1- rigth mouse click on the speaker next to the clock OPEN VOLUME CONTROL
2- OPTIONS - PROPERTIES - RECORDING
3 - in MIXER/RECORDING DEVICE (where is your soundcard's name) change to USB AUDIO DEVICE and then OK
4- In the remaining volume control window, select MICROPHONE and then close all the volume control windows
5- you can test the mic settings in messenger (any version) because of volume and to a clearest voice sound in your pc.
ATTENTION: carefull with the distance between your cam and your sound speakers because of distorcing sound and feedback
Jan 23, 2008 | Logitech QuickCam Fusion Webcam
Logitech QuickCam Fusion Webcam Logo
65 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
