The blue projection unit in the tv isnt going, i looked in the back is this a replacement part and if it is how and where can i get one and is there any way I can do this my self?
  • 8,617 Answers
If you go to the following link and leave your model number in a email they can help you out with a blue CRT. They also help explain how to change the CRT yourself correctly and safely.
http://servicemanuals.vstore.ca/
Posted on Nov 28, 2008
Philips 60PW9363 60-Inch Widescreen HDTV-Ready Projection TV discolored. possible crt fluid issue??
Thats sounds like the classic sign of CRT coolant needing to be replaced you can get the phillips CRT coolant kit from www.tvrepairworld.com and it comes with the coolant for all 3 CRTs and the instructions
Nov 08, 2012 | HP Philips 60Pw9363 60-Inch Widescreen...
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
WILL NOT TURN ON. GREEN LIGHT; TWO RED LIGHTS
check the projectors lamp.look like to need replace
May 05, 2010 | Hitachi 60V500 60" Rear Projection...
I believe the blue lamp in my 57H81 is going bad.
You need to replace convergence out chips in your Toshiba 57H81 tv by qualified tech because 3-D look picture in rear projection tv shows some thing wrong with convergence output chips.
Your tv model number shows it is rear projection tv that use 3 tubes to make color picture on front screen where as dlp tv use one lamp as back light source to present picture at front screen that is generated in light engine.
Mar 25, 2010 | Toshiba 57H81 57" Rear Projection...
Toshiba 43hx70 Cinema projection TV-where are the IC relays?
DID you ever get this fixed I am wanting to replace mine, I paid big $$ for this tv back 6 or so years ago, the picture cinvergence isnt real bad, but I cant line u the red and blues in the menu as good as they need to be. I was also wondering If i replace the lamp if the tv would be brighter. I have most my setting turned up but...The picture is not as bright and crisp as it used to be any one have a suggestion on this also..
Jan 02, 2010 | Toshiba TN43V71 43" Rear Projection...
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Philips 60PP9202/17F Blue Problem
call the repairman back and tell him the tv isnt fixed correcctly. have him come back and finish the work he started
Jan 27, 2009 | Philips 60PP9202 60" Rear Projection...
Optical unit
I have the 52G786. These JVC HIDLA (LCoS) rear projection TV's are very trouble prone. Mine was in the shop 3 times in the first year. Now at three years old, the screen is getting dim then bright and flickering back and forth, but it's not the bulb.
You can now get a 50" 720p plasma for just under $1000, so that's the direction I am going. Fixing it is just asking to throw money out the door because it is likely to break again.
Sep 18, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Rca guide plus gold 52 in projection tv
sounds like the blue CRT is contaminated open the back turn on the tv look into the blue gun if it looks snotty the coolent needs to be replaced
Oct 31, 2007 | RCA P52926 52" Rear Projection Television
Blue power light constantly on...
possibly shorted crt drive ic on crt board.
Jun 14, 2007 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
