Question about Sony DVP-NC80V DVD Player
Sony dvp-nc80v Recently purchased player display's loading.......at disc selection after approx 5 minutes switches to another disk. After repeating this with all 5 disks player displays "no disc"....Do any of you have any idea's?
I have the same 5 min problem i am trying to clean the dust off the lens
Posted on Jan 16, 2007
If this happened after a power surge, it's possible that one or more capacitors in the power supply have been damaged, and that could cause the player to act up. Otherwise, the symptom you're experiencing is a classic one of the laser pickup not reading the tracks on the disc (assuming you meant to say it switches the disc after approx 5 Seconds). If it is within the warranty period, it would be worth getting looked into. You can get a good CD/DVD player to act up like this by placing the discs upside down on the platter.
Posted on Jan 13, 2007
SOURCE:
No disc message when there is a disc in dvd player
Either a dirty or bad optical pickup in the player which is what reads the disc.
Jun 11, 2012 | Sony DVP-NC80V DVD Player
Tip
Sony DVP-NS725P Region free code.
This region free hack also works for the DVP-NS725P using the original remote control. If the first one fail try the second one, it works like a charm.
Thanks a lot....
SONY DVP-NS300, DVP-NS305, DVP-NS400D, DVP-NS700, DVP-S330, DVP-S335, DVP-S360, DVP-S336, DVP-S525D, DVP-S530D, DVP-S535D, DVP-S536D, DVP-S725D, DVP-S735D
Multi-Region:
Turn On the unit with the remote controller
Wait until "no disc" appears in the unit's display
Press Pause, 3, 1, 4, 1, 5, 9
The word "CODE" should appear in the display
Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
Put the player into Standby mode
Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
Press Audio and Return for auto-switching On
Press Angle and Return for MacroVision On
Press Subtitle and Return for MacroVision Off
on Mar 07, 2010 | Televison & Video
How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
May 15, 2010 | Sony DVP-NS330 DVD Player
I purchased dvds from ebay and they will not play on my dvd player. Is there a way i can unlock or change the region on my Sony DVP-SR200P DVD Player? Please help!!!
Or
Or
I found these codes for all the other DVP-SR series players, yours was not listed but I thought was worth a try.
Apr 14, 2010 | Sony DVP-SR200P DVD Player
Is this dvd player a multi region dvd player?
Its Not But you Can Make It.
Just Take Out The Dvd And
1.Power Off The Unit
2.On The Remote And Hit Display, Top Menu, Clear, Power A Menu Will appear on The Screen.
3.Select option 2 (Drive Manual Operation),
than option 4 (Tray Aging Mode). The screen will show two input lines, each with 5 digits
4. Change The Top Line To 12450
5. Then 00000 On The Second Line And Press Enter
6. The Disk Door Will Open And Close A Couple Times
7. Repeat Steps 3-5 and enter both Codes As All 00000
A Long Process But It Works.
Hope This Helps.
Sincerely,
Michael Scott
Jul 14, 2009 | Sony DVP-NS575P DVD Player
Won't read dvd
Try switching the LINE SELECT button from OUT to IN, then back to OUT. This solved the problem in which our Sony DVP-FX810 player showed LOADING for around 30-45 seconds and then CHECK DISC.
May 09, 2008 | Sony DVP-FX810 Portable DVD Player
Cannot Close Sony DVP-NC665P 5 disk tray
There is a possiblity that he may have shifted the unit while discs were in it causing the discs to slip off the tray and into the unit. You have to open the unit to check if there are loose discs.
Nov 12, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Display says "LOCKED", won't eject disk, all other functions work. Need unlock procedure.
How I got my DVD from ”lock” condition
My DVD (Panasonic m: DMR-ES10) had gone to ”locked” condition without any warning.
Perhaps the reason was that I transfered the machine when it was on and recording was going…
Guidebook didn´t help to resolve the problem, neither Internet. Finally I managed to solve the promlem . This is how i did step by step:
1) Power on
2) Hello
3) read
4) no disc
5) functions
6) to others
7) setup
8) select down arrow
9) disc
10) select right arrow
11) setings for playback
12) enter
13) ratings (level8)
14) enter
15) No limit
16) enter
17) ”The Recorder is now unlocked” (picture of open lock)
18) enter
19) return
20) return
After this DVD works normally.
Jalmari
Aug 11, 2007 | Sony DVP-S330 DVD Player
My sony dvd is powering off about one minute after I turn it on.
1. Press Display.
2. Go down and select Setup.
3. Move to the Right and Down to select Custom, Press ENTER.
4. Move down to the center box.
5. Move Right to select Auto Power Off, Press ENTER.
6. Change it to Off, Press ENTER
7. Press Display and you should be done.
Aug 11, 2006 | Sony DVP-CX985V Multi-disc DVD Player
Sony DVP-NC80V DVD Player Logo
257 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
