Lost my keyless entry code for my 2003 ford expidition
The factory reset code is behind the glove box. To see the code you'll need a flashlight. No other tools.
First, empty the glovebox and open to stops then gently bend those stops at the top of the glovebox in to clear the trim. Swing box down and allow it to hang. Next, you'll see several wiring looms in the right section of the area behind the glovebox. Behind that is the ECM, the componenet you're looking for. It's mounted facing the left side of the truck with a code label on it, so it's a little hard to read. Get a piece of paper and write down the only 5 digit code printed on the label. It's bold face and is one of the bigger numbers but not the biggest. Once you have the code, write whatever 5 digit you want your new code to be on same piece of paper. Go to drivers door, lock truck completely. Enter the factory code into the keyless entry, and within 5 seconds press the 1-2 button on the keyless entry the enter your new code. The truck should unlock. SuPER EASY!!
