I have vista HP touch screen computer and my webcam does not work please help me fix this problem
  • Jannette Amandy May 11, 2010
    What is the model of the webcam you have?
    Have you check if its software is compatible with winVista already?
    What is the error you're getting when you try to use your webcam?
    Genius:
  • 1,226 Answers
If the webcam is built in to the HP comp then, you have to install the correct driver of the cam, else maybe the cam is switch off try to find any button to switch on your cam.
or verify also if the cam is detected in the system.
melnavz
Posted on Nov 28, 2008
I have an HP 3100 webcam and am trying to use Skype, the audio works fine, I can see the person I am talking to, but they can't see me, when I try "video start" a black screen comes up with a...
please refer to google you will get the exact solution to the issue.
Please type the following text in google "how to use HP 3100 webcam on skype"
you will get various results as follows
Camera name recognized but not loading?
Can not get video to work - HP webcam?
Video Render... No video HP Webcam 3100?
please select the appropriate option.
Dec 31, 2010 | HP Webcam
I have an hp pavilion dv6...i know how to open my webcam and it usually works just fine when i take pix or when i use it to video chat on skype. today it stopped working. when i open my webcam it says that...
Windows Vista and 7 ( can't remember about XP ) come with native drivers for the webcam so it may be a problem with these. You could try running a system file check by browsing to all programs, accessories, right click on the Command Prompt and select 'Run as Administrator'. Type in the following command and hit return. sfc / scannow
If that doesnt work download and install the software driver for your webcam on the link below. http://www.downloadsource.net/d16952/HP-Pavilion-Webcam-Driver-Windows-Vista-x32-x64/ i hope this works for you.
Dec 12, 2010 | HP Pavilion dv6000z Notebook
Fresh vista install now webcam don't work on hp computer.
whats the Exact model of the HP Laptop - I assuming the webcam is integrated on the laptop - if so we should be able to find a driver on the HP support website here http://www.hp.com/#Support Put the Exact Model in the search box - you should then be asked for windows version choose vista and then look through the drivers should be a webcam
if its NOT integrated reply with the Make and Exact model of the webcam
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | Computers & Internet
Computer dosnt reconize webcam, cant set it up
i'm sure your webcam driver is not compatible with vista..try download that driver for vista in hp support n driver website n install by using vista only...don't use same driver for windows xp when u installing your webcam into vista
May 27, 2009 | HP VGA Webcam
Webcam dont work, keeps saying device not found
I have the same problem...If you have any ideas pls contact me:
the_kamykaze@yahoo.com
Apr 17, 2009 | Computers & Internet
Webcam prblem
if you had windows xp or something other than vista make sure your webcam will work with vista if not you'll have to get a webcam that will work with vista 90% of programs will not work with vista unless it has vista on it sorry for the bad news
Mar 27, 2009 | HP Pavilion dv6915nr Notebook
Hp Pavilion tx1320us - Vista Home Premium - Webcam doesn't work. Please Help!!!!
Try downloading the webcam fast recording(software) patch and see if that fixes the problem. Also update software if not done recently.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us〈=en&product=3548576
Jan 06, 2009 | HP Pavilion TX1320US Tablet PC
HP Pavilion dv6000 Webcam problem
Download Quick play if you can i havent tride this before so i dont know if it will work hope this helps. =]
Feb 10, 2008 | HP Pavilion dv6000z Notebook
Touch screen stopped working
Hi Everyone
I have the solution to the touch screen problem. You need to get the support and strip down document for yout touch screen from HP.. for instance the one for the tx1000 series is c00853874.pdf
you will need another machine or to print the pages required to strip your machine all the way down to removing the monitor, and the surround on the screen.
the document is step by step...label the screw etc, you'll be fine...even if you have never done it before.
the result is the terrible build quality of the machines. the ribbon access cables for the webcam, and for the touch screen are poorly installed.
I found that my touchs screen access cable was not actually properly installed at all, and was only barely contacting when i received the machine.
my touch screen is working properly, you need to be gently with everything, the circuit board that the webcam and the touch screen connect to is directly behind the screen..
you must strip the screen down, and then lift the glass... there are 4 screws around the edges of the glass when you have it stripped down... once you lift the screen up.. there is a circuit board on the rear of the top of the plastic screen back. the are connectors going into this...for the quick access buttons around the screen edges...the webcam,.. and the touchscreen.
i have to say i just discussed this with a guy called GINO on Hp online support...and he doesnt care that this is the solution...or that there has been a manufacturing fault since day on.. they never plugged the cables in properly.
email me if you get stuck...
James
Nov 04, 2007 | HP Pavilion tx1000z Notebook
EasyCam Vista Trouble
This webcam was not designed for Vista --- it does not have the Vista chipset. Jasco has a potential workaround for this on their website. Go to www.jascoproducts.com, support and then click on Browse and Update Vista certified products. Go to the bottom of the page and you will see a PDF link. It's not a guaranteed fix, but it's worth a try. Good Luck!
Aug 26, 2007 | GE EasyCam Webcam
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
