Question about Aprilaire 700 Humidifier
AprilAire 760 not running after installing new circuit board
Unit worked fine last year. Not running this year. I had a service tech come to the house and he determined the circuit board was bad. I bought a new board and put it in but the unit still is not working. I check and have 24 v from the humidistat and the 120 v line is hot when the furnace fan is running.
Help
  • DennisC5A Dec 05, 2008
    installed new circuit board, fan still not running.
  • dkesler Jan 19, 2009
    A service tech unwired my Aprilaire 760 from the furnace when he diagnosed a bad solenoid. I ordered the part and replaced it and it works fine. However, I don't know how to rewire to the furnace to turn it on/off with the blower. My furnace has the 5 connection points Y W R G C. To which of these do I connect my 2 wires from the humidifier? Thanks.
I called the service company that put in my new furnace (FAmily Heating and Cooling in Detroit, very highly recommend these people)
Anyway they sent out a second service tech who determined that I would be better off having the humidifier wired to go on whenever the furnace fan was running instead of using the humidifier signal from the circuit board on the furnace. After he changed the wiring the unit runs fine. It is pretty likely that the circuit board was bad also.
Posted on Dec 01, 2008
Aprilaire 760 keeps running
Is this a newly installed unit it sounds as if there's a wiring issue. Could you show a picture of the wiring terminals. If this is not a new install try turning of your furnace fan.
Nov 02, 2014 | Aprilaire 700 Humidifier
Unit stopped working and discovered the circuit board missing
suspect the last technician is pulling a fast one
if the board was missing , it would not be working from day one
Dec 20, 2017 | Humidifiers
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
Nov 06, 2013 | Aprilaire 700 Humidifier
Humidifier not working
Mine is a SUL495 Filter Free unit and worked fine last year and the first couple of days recently, but I'm having the same issue, motor running , no mist, and trying to talk to someone @ in customer service today is a joke, I've cleaned everything but still no luck, I paid $40.00 for this unit in Jan. 2011 and have about two weeks until the warranty runs out, and the other wonderful thing is the nearest service center is about 50 miles away, I may wait until Monady to try to speak to someone, but I probably won't like the answers.
Nov 25, 2012 | Sunbeam SUL496-UM Ultrasonic Humidifier
Wire Honeywell HE220 to N8MPN/L, *8MPN/L furnace control board
HI
I have similar isssue with HE220 but in my case the water run through all ththe time, even when unplugged from the power outlet.
Would that be solenoid issue?
the unit run fine for last season so the wiring is fine.
Any ideas would be greatly appreciated.
Jan 22, 2012 | Honeywell HE220A1019 Whole House...
I have a HoneywelI Enviracare Elite whole house humidifier. I have no power to the thermostat. The wire goes into the furnace and is attached to a control board. The furnace is working. Humidifer is n
Most of the humidifiers are run by 24 volts AC. disconnect the power wire to stat on circuit board and check there with meter and connect to low voltage ground for 24 volts, I'm assuming the two wires that power the humidistat are red and white.typically red is used for power. most likely you have power if the red for the stat is connected to the W on the board and the heat works, but the humidifier only works while heat is on.the next thing in line is the humidistat , it's a switch so if there is only two wires going to it take them off the stat and connect together, if furnace is on heat and running and stat wires are connected it will send power to water solenoid, if its not working yet the problem lies in the water solenoid if you have 24 volts at the two wires at solenoid.check while disconnected, do not connect those two wires together or a 3 amp fuse will blow on the furnace board. if you have 24 volts there then the valve may be bad or the valve may be stuck or clogged, loosen water supply line to make sure water is getting to valve. I spent many years working in the HVAC industry.
Dec 31, 2011 | Honeywell Humidifiers
Model 760 Aprilaire makes a loud noise when running. It almost sounds like the blade is hitting something. Its 10 years old !! I built the house so if you can tell me for sure what it is I'm sure I can fix...
I think you're on the rate track. If it's ten years old the blade and.or the shaft may be worn out. Turn off the water line feeding the humidifier.Turn off the electricity to the unit. Drain the tank, open he tank cover and try spinning the blades with your hand. That way you can tell and see what its rubbing against and if it can be repaired. But, if it's 10 years old, parts may not still be available for that specific model.
Good luck. Hope that helps.
Feb 11, 2011 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
242 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
