Question about SanDisk Sansa e250 MP3 Player
My song keeps restarting whenever the backlight oges out
  • 8,596 Answers
Upgrade the fimware
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
How do i fix my peavey 32fx mixer master output
I would start by replacing the master out driver IC. I presume all else is fine.
May 21, 2016 | Peavey Computers & Internet
I downloaded a new theme in my nokia 5220..... It did initially changed into itS new lookS but aFter 30 Seconds or so the phone restarted and juSt ShowS a white background whick keepS blinking every 3 or...
The theme "installer" is in your memory card, but themes can only be installed in the phone's internal memory. So, you better change that theme. IF you can get your phone to start, change the theme to any of the default themes and then delete the theme you downloaded.
Jun 16, 2011 | Nokia 5220 XpressMusic Cellular Phone
Unable to play songs from memory card
rehot the "UEM" IC or change it. good luck
Apr 27, 2010 | Lands Phones
Mp3 player restarts whenever i skip a song
try using recovery mode with the sansa.fmt file and update the firmware. this will erase all your music from the device so you will have to reload all your songs but it will probably fix the issue.
Jan 07, 2009 | SanDisk Sansa E280 MP3 Player
My zune
If it freezes up hold the pause button and turn it off, then hold down the back button and up on the keypad and it will restart. If for some reason it keeps freezing constantly I suggest you contact zune.
Oct 26, 2008 | Microsoft Zune JS8-00001 Digital Media...
Songs skipping!!!
my phone sound is low please ask what possible to sound are hi
Apr 05, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Power goes out
easy fix my friend its temporary firmware problem . ok now to fix it plug the sansa in your pc ,just doing so can fix the problem if not ,unplug it from the pc the unit should have stayed on (the blue LED's of the wheel r on but no screen backlight) push the ON button on the side and hold it push for a good 20 secon then releass it that will make the unit do a soft reset and then turn it back on again it may chow the low bat simbol just plug it back in your pc the screen will show the turning arrow the backlight of the screen will work, let it recharge and there you go fix.
Dec 29, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
Phone restart automatically
Dear Sir, my set is hang plz send me code to restart
Dec 11, 2007 | Nokia 3110 Cellular Phone
Cant add/delete songs
it is just re-reading the songs
Apr 20, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
