Question about Motorola Mobility RAZR V3
Changes ring style when charging
When I plug my phone in to the charger it automatically changes from 'ring and vibrate' (my usual setting) to the 'loud' ring style. At first I thought i must be accidentally pressing the buttons on the side, but no - it's the phone doing it all by itself. anyone else have this problem or is it just my phone?
My phone also does this and its something Motorola have built into the phone. Can't change it I'm afraid!
Posted on Jan 15, 2007
SOURCE:
MOTOROLA W376G...turn off phone on ringtone
Hello!
Set phones ring style as "Vibrate then Ring" , "Vibrate" , or "Silent" to avoid the power on alert.
I set my ring style to "Vibrate then ring" so that I dont have to change the settings everytime I turn it on or forget to so when I receive phone calls or alerts it still rings & then I dont have to go back and change the settings again when I turn tha phone off so that is dosent have the power on alert.
This is the Only way I have found to turn the phone power on tone/alert off.
Change Ring Style:
-Go to Main Menu
-Settings
-Select Ring style
-Then choose change, & set it to the ring style you want.
Feb 21, 2010 | Motorola Mobility W376 Cell Phone
Vibrate
1 go to settings
2. ring style
3. click the little button top left on phone under "select". it will let you change your ring style
4. scroll to vibrate
5. click same little button under "select"
6. keep clicking "back" - the little button top right on phone under "back"
Jan 29, 2010 | Motorola Mobility TracFone C139-4 Cellular...
Change Ringtone Automatically when charging
The BlackBerry gives few profiles to choose from; e.g. Normal, Loud, Quiet, Vibrate.... my recommendation would be to configure each profile separately and just enable/disable the profile you like when you enter/exit your car...
The phone itself is not capable to switching the profile on its own once it is plugged in to your car charger...
Hope this was helpful...
Nov 10, 2009 | RIM BlackBerry Curve 8310 Smartphone
Phone does not ring when call comes in on my Motarola Razrv3 cell phone. It vibrates but no ring. The ring volume is set on 7.
1st make sure that your phone speaker is not malfunction, to do this just play any ring tone from your phone to check whether there is a sound come out from the phone speaker.
If there is no problem to hear sound from phone then have to check the phone setting, to do this just PRESS and HOLD the button #, a shortcut to toggle between RING mode and VIBRATE mode. Or goto Setting>Audio>Style Detail, and change the alert type such as sound or music. Make sure u are not in the Silent style mode.
YBC (/\)
Oct 21, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My motorola pebl phone will not ring
Hii
can u plz chk and tell me if ur profile is set into vibrate mode? and regarding keys, u can set the key tone volume to zero.
if ur a new user here is wht u hav to do
> MENU > RING STYLES > Change it to LOUD or VIBRATE and RING
Regards
Hope it helps u
Sep 11, 2009 | Motorola Cell Phones
Motorolla Razer V3i Keypad is not working
sir it is hardware problem because of vibration it damaged
Jun 02, 2009 | Motorola Mobility RAZR V3
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
Motorola w377
Like most of the W377, this one's very odd. The only way I know how to do this is to switch off all Key tones. Key volume is part of the Ring Style menu, so:
>Settings
>Ring Style
>Ring Detail
>Change
> On the Detail menu use the 4 way selector arrows to cursor down to Key Volume
>Change
>0
>Ok
>Back out
NB The Ring Style settings for ALL ring parameters (Ring Volume, Line 1, Text Msgs, Voicemail, Alarm, and Key Volume) change whenever you select a different Ring Style, so you can set up one ringtone in Loud Ring but get a different one for Soft Ring, a different one for Vibrate and Ring, a different one for Vibrate then Ring, etc.
For the sake of sanity (and to avoid the alarm waking me up with a loud blast of Bach when I wanted a quiet 'Ding') I have set the same ringtones etc in all of the above profiles.
BTW whenever you can't find a menu you need, try pressing the black round button (OPEN MENU) in the middle of the 4 way selector arrows - it opens submenus that can't be accessed any other way.
Hope this helps.
Jan 02, 2009 | Motorola Mobility W377 Met Silver/Pink...
Won't Ring
check the settings in your phone book. this happened to my phone and all of the personal ring tones were set to vibrate. I don't know how this happened. I went into each contact and changed the ring tone to none and I am back in business
Sep 15, 2008 | Motorola Mobility W385 Cellular Phone
In vibrate mode, phone continues to vibrate after being answered
The phone is in "vibe then ring" mode.
Go to tools then ring styles using the "-" at the top center of the keypad. It will be set to vibe then ring, press "change" alter the style to vibe, vibe then ring, silent, loud or whatever you like. That is also where you find what ringtone is used for the ring.
Oct 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
109 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
