Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
How do I calibrate the temperature for the RTH7500D thermostat? It is 2 degress warmer than the thermostat reflects. Does this thermostat operate on the battery power alone? There are only two wires going to the thermostat. One is the red hot and the other is the return leg that activates the relay that transfers power to the hot water pump that circulates water to the registers. .Since there is no common wire going to the thermostat and the thermostat will not operate without the batteries, I am assuming the battery is the only source of power that operates the thermostat.
  • Melvin71 Dec 04, 2008
    The second part of my question was not answered. Does the 2 AA batteries provide power for the RTH7500 thermostat since there is no neutral wire(X terminal) going to the stat. There is only the hot (R terminal)and return wire(W terminal) to activate the heat.. I am guessing that the hot wire and the wire to the W terminal provides 24v power to the thermostat but if that is the case, why does the stat show no display when no battery power is present?
  • 61 Answers
There is no feature in this thermostat to adujust sensor. You need to make sure you have picked for hot water systems.
Follow blue link for instruction manual
If you need more information, please post back.
If this answers your question please hit accept
Posted on Nov 28, 2008
  • Joseph Lillie
    Joseph Lillie Dec 04, 2008
    Yes the battery supply the power for the thermostat
The humidistat changes with home but reads about 20% low. Can the read out be adjusted to more accurately reflect the actual conditions?
A common problem is dirt. Dirt can affect the thermostat's calibrationand interfere with its operation. For example, if a thermostat is set to heat for 70 degrees is really maintaining a temperature of 73 degrees, the additional energy use can increase your fuel bill by as much as 7 percent.
Google your make and model #manual, the manual will let you knw if it can be calibrated.
Thermostat Temperature Calibration DoItYourself com
Jan 21, 2016 | Heating & Cooling
Kenmore ice maker is not making ice very quickly
What is the model number?Here's a few helpful tips that may help you decide what to do. The rate at which a refrigerator cools depends on the ambient temperature. The warmer the ambient temperature, the longer it takes for the machine to reach its set point temperature. The relation to the ice maker is the ice maker thermostat. The ice maker thermostat needs to reach a set temperature and close to begin a harvest cycle. They can lose their calibration over time and it may take longer for it to close.
Dec 06, 2012 | Kenmore Side by Side Refrigerator
Compressorruns fora short time
the thermostat controlling your unit likely has a window type of programming for digital or mechanical adjustment for older style thermostat that sets a minimum off temp and a maximum on temp, there may be an adjustment to set the range it operates at, otherwise you may have a defective thermostat controller unit and it needs replacing also insure that the temperature sensing element is clean and free of dust build-up and your filter is clean
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
The thermostat is registering temperatures in the
The coolant temerature sensor/engine coolant temperature sensoris out of specs ,and should be replaced.
Mar 07, 2010 | 2008 Saturn VUE
What can keep causing Check engine code P0128
CODE P0128- THERMOSTAT MALFUNCTION. POSSIBLE CAUSES 1. ECT SENSOR IS OUT OF CALIBRATION. 2. CHECK THE OPERATION OF THE THERMOSTAT IT MAY BE STUCK OPEN.3.INSPECT FOR LOW COOLANT LEVEL OR FOR AN INCORRECT COOLANT MIXTURE.
Jan 06, 2010 | 2004 Kia Spectra
What is the difference in temperature controllers between a fridge & a freezer? Can they be interchanged?
Refrigerator and freezer temperature controller can-not be interchanged (normally). They have a designed range of operation. Such as...say the refrigerator thermostat has a range of 45 degress at the warm setting and 33 degress set at maximum cold. This would never work for the freezer. Some electronic devices have ways to change their setting range but that is specific for each control.
Sep 04, 2009 | Refrigerators
Heating & Cooling Logo
506 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
