Question about Onkyo TX-SR500 Receiver
Standby light blinking -unit won't stay on
I recently had cable guy in to change cable box. As soon as he left I noticed the standby light blinking on the receiver. When I turn on the unit it does go on but within 5 seconds it just shuts off. I cannot get it to stay on. Did cable guy do something or forget to plug something in? I cannot see any loose wires? Any thoughts? Thanks for your help.
When it is on, does any audio come out of the speakers? If so, you may have a problem in the protection circuits. If no audio is heard, I would first check the speaker wires to make sure there are no strands shorting across the terminals, and that you have the it selected to output audio to the speakers -- Now also be sure to check the various inputs, for instance if it has a FM receiver, select that and see if any audio comes out then as well. I don't know what the cable guy could do other than knock loose a wire or change connections on you.
Posted on Jan 13, 2007
SOURCE:
Media receiver "on" button flashes 8 times and turns the Pioneer TV to standby.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 14, 2015 | Pioneer Televison & Video
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
The laptop (recently) has just started to blink 4 (light) orange lights consecutively every time i try to turn it on. It just won't turn on, it remains with a black screen. The light blinks in where...
It looks like your laptop is in standby.
Try pressing power button.or
CTRL-ALT-DELETE- at the same time.
This should reboot your computer.
Failing this:
Remove power.
Remove battery.
Reconnect power.
Turn on.
Jan 01, 2018 | Toshiba Satellite L655S5163 156 Notebook
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
When attempting to turn on the set, the standby light should blink for a a while then stop once the picture comes on. If a problem is detected internally, the standby light should blink in a repeated pattern. Please count the number of blinks that are repeating and we should be able to help.
Thanks,
Dan
Aug 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
Sony trinitron stopped working-standby light blinks
How many blinks are you getting?. Blinking codes tells a service tech what section of the unit is manfunctioning.
The full service manual for KV-24fs120 can be found HERE!
Nov 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Subwoofer light
The subwoofer light stays red regardless of the state it is in despite it being labled a standby light. (It's more of a power on light) It seems that philips missed the point of what a standby light is.
I would have expected the light to have changed colour to indicate that the unit was operational and perhaps syncing with the receiver box.
May 17, 2008 | Philips Cineos HTS9800W System
Onkyo TX-SR500 Receiver Logo
412 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
