SOURCE: I have aN Energizer E2 Slider battery charger, Is
all chargers show a light of some colour when charging , green or red , depending on make of charger , when the battery is fully charged the unit monitor this and automatically switch of to stop from over charging , a safety feature that has to built in for safety reasons ,
SOURCE: i have an energizer CHCC-UK battery charger. As
wHEN THE GREEN LIGHTS COME ON IT TAKES ABOUT 12 HOURS TO FULLY CHARGE THE BATTERIES. WWHEN CHARGED THE LIGHTS GO OUT. Ken13
SOURCE: energizer CH2PC-UK battery charger' how long do i
Charge time depends on the mAh capacity of the batteries (should be listed on the package, or the side of the battery) most AAAs are under 900mAh so 2 hrs should be sufficient, but AAs vary greatly in capacity so heres a link to check after you look up your mAh rating
http://energizer.com/SiteCollectionDocuments/pdf/rechargeable/CHDC.pdf
SOURCE: I have a wii system
I have the same problem. Has anyone figured out an answer or should I try to return this unit? :(
