Question about Samsung DVD-P230 DVD Player
Dvd showing in black and white
We have not used our dvd player for some time. Tonight when I put on a disk it run in black and white not color. What could be the problem and how do I go about fixing it.
Hi i am shantanu . if your dvd supports ntsc then change your audio video format of tv to auto/ntsc mode
Posted on May 13, 2009
IF you have a Modern DVD player hooked to a Modern TV then you most likley have 3 color coded cables running from the back. RED GREEN and BLUE and thats just the way your TV see it. If your TV is Not showing RED but the picture looks like a black and white with some Strong shots of Yellow and Blue with some green. Then the RED cable is loose or bad, Check it or Replace it.
The same prosedure for other Colors.
Hope this Helps.
Posted on Dec 17, 2008
I'm assuming you're using the yellow ended video cable and two audio cables hooked up to your TV to display the signal. If so, I would just make sure they are connected in the correct output jacks on your dvd player and that they match up with the input jacks on your TV. If so, then I'd try another DVD player to see if that one plays OK.
Posted on Jan 13, 2007
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
DVD disks just play in black and white. No color.
This is because of the audio video format issue. You select the TV type to auto (Advisable) or to the appropriate selection such as PAL or NTSC in the DVD player to get the better output with the color.
This selection you usually find in settings > Video setup> TV Type
Aug 06, 2009 | Zenith XBV443 DVD Player/VCR
Show movies in black and white no color
unit is in a progresive mode. need to turn back to interlaced.
Jun 01, 2009 | Sony DVP-NS575P DVD Player
Cant get color picture when playing DVD's
I too had the same problem. On the Vzio there are AV plug ins on the left side (not the back, but the left side). Use these jacks when connecting to the DVD player and choose the AV button on the TV remote. Viola!
May 27, 2009 | Sony Televison & Video
Black and white picture for DVDs not tv
Make sure you don't have a componet plug in a A\V hole or the other way around.
Mar 15, 2009 | Bose Lifestyle 18 System
Curtis progressive scan DVD player 1071
your not using progresive scan out are u change that back to regual
Feb 06, 2008 | Curtis Progressive Scan DVD Player 1056
Playing movies in black and white
Use a scart lead to connect it to the TV, that should cure it.
Dec 08, 2007 | Sony DVP-NS315 DVD Player
Sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Sep 01, 2007 | Sony DVP-NS50P DVD Player
Black and White
There some thing that you had done to get black and white on your tv with the dvd ,check your connections.if the connections are properly connected then the tv could be having a problem in the video input, have a tech look at it.
Apr 03, 2007 | Zenith C13A05LG 13" TV
Samsung DVD-P230 DVD Player Logo
284 people viewed this question
Jerry Greenberg
Jerry Greenberg
