Question about Frigidaire GLER642A Electric Dryer
Brown marks on clothes
The dryer is leaving brown marks on fine materials. I'm thinking that the items are getting stuck between the drum and the paddles in the drum that churn the clothes. What can I do to fix this?
    President:
  • 878 Answers
This is a pretty common problem with these Frigidaire dryers. Crice hit it right on the head when he said the clothing is getting stuck between the guides and drum. The upper and lower felt guides need to be changed. This is not one of the easiest jobs. The top and front panel have to come off and the guides are glued on with high temp. adhiesive. The old guides have to be scraped off. Part numbers for the upper and lower guides are 5303937139 -(upper) 5303283286 -(lower). Catriver...post back
Posted on Mar 14, 2007
I have the calypso dryer that leaves random brown streaks on our clothes. Any suggestions
Something like this happens when one of the drum supports wears down leaving a gap between the drum & bulkhead. Clothes can get caught-up in this gap & this will cause the brown marks you see on your clothes. Open the dryer door & look around the front & rear perimeter of the drum, if you can see a gap I recommend replacing the drum rollers. If you aren't comfortable making the repair yourself, you can contact a local appliance repair shop or the manufacturer of your Calypso dryer.
Sep 28, 2017 | Dryers
I have a 2006 Whirlpool Duet Electric Dryer that leaves brown marks on my cloths. I have cleaned the inside of the dryer per the manual's diretions, but it still leaves the marks. They almost look like...
Usually, if you are getting brown streaks or marks on clothing, one or both of the drum seals are going bad. Clothing will drag between the bulkhead and the drum, leaving brown marks. If you want to do the repair yourself, I can provide instructions, otherwise call for service.
Dec 30, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer 65291, burn marks
The problem you describe is usually caused by a rear drum seal worn and pinching articles during part of the drum's rotation. Replacing the rear drum seal is covered in great detail at the link below. Be sure to follow all links in blue that pertain to your machine. Caution: The glue that comes with the seal is VERY sticky and messy and comes out faster than you'd like at times. Do not get it on areas and items you're not prepared to discard. It is VERY difficult to remove once dry and it dries very quickly.
Rear drum Seal replacement procedure
Oct 02, 2009 | Kenmore Dryers
Brown streaks of clothing from dryer
Check your front and rear felt seals. How old is the dryer and what is the model number?
Eric
May 16, 2009 | Whirlpool LER4634J Electric Dryer
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
Dryer is leaving brown marks on items
Yes, this is what causes the brown marks, the felt piece will have to be replaced.
Apr 11, 2009 | Whirlpool Dryers
Kenmore dryer leaving brown burned lines on clothing
the rear drum seal was bad and as things rub against it they will get black marks on them.
Larry
Aug 02, 2008 | Whirlpool GEW9250P Electric Dryer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Brown smudges on clothes
Take a look and see if the drum near the door moves up vertically. It shouldn't move more than 3/16ths of an inch. If it does, replace the upper felt seal/plastic slide. The upper seal that supports the front of the drum on the front of the dryer is worn out to the point that clothes can get stuck in the gap between the drum and the front of the machine. This leaves brown wedge marks on clothes. While it's apart, replace the lower felt seal as well.
Apr 20, 2007 | Frigidaire FullFGX831C Size Stack Gas...
Frigidaire GLER642A Electric Dryer Logo
235 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
