Question about Acer Computers & Internet
After accidentally pressing my thumb into my laptop screen, whilst trying to move it, I have damaged my screen. The cover frame itself is not damaged but the picture underneath is incredibly distorted. The crack, underneath the screen, runs diagonally from one side of the screen to the other, the screen on right side of the crack is not visible at all, there are only small partts of the screen that actually are visible. Can anybody help with this problem? Where could I get it fixed and how much would the charge be? Thank you.
  • 41 Answers
This will require a new LCD replacement. I was quoted on this when I damage my old Toshiba. It costs about $300 to have it replaced. You can get a new screen from eBay for about $200, but you need to verify its compatibility and make sure you read all the tutorials online before proceeding.
Posted on Nov 27, 2008
Lcd replace
You should the installation instructions with the new lcd screen
Replacing a damaged laptop LCD screen can bring your laptop back to life.
You'll be able to access files you thought were lost and use the laptop just as you did before. And it's not as difficult as you might think.
Turn off the power, unplug the battery and all cables.
Eject the installed battery if you have one.
This will protect you against electric shock.
Find the small, round rubber screw covers and pry them off.
This will expose the small screws holding the LCD screen frame in place.
Depending on your laptop, these covers might be made of some other type of material.
Remove the frame by gently prying.
Locate the LCD screen's cable and power supply cords. Unplug them and remove any tape holding the screen in place.
Check the identify of the manufacturer on the back or side of the screen.
It may be different than your computer's manufacturer.
Since these screens look so similar, make sure you order an LCD screen that matches your manufacturer's model number, or else the new screen will not fit.
Plug in the new LCD screen, replace any tape holding the screen in place and replace the frame.
Don't pinch any wires as you press the frame back into place.
Screw the frame down and switch on the power to see if it works.
If it does, go ahead and replace the screw covers.
If it doesn't, remove the battery, the screws and the frame.
Check your connections.
If it still doesn't work, call your parts supplier and ask for assistance in getting another replacement LCD screen.
Hope this helps
http://www.laptopscreen.com/
watch video
Nov 04, 2012 | Computers & Internet
How can I remove battery cover on pantech ease
The back cover on the Pantech Ease is difficult but not impossible to remove. This is what works for me: First turn the phone off (for 2 reasons). Most importantly the phone should be off before you remove or replace the battery, memory card or sim card. The other reason if because it is almost impossible to remove back cover without accidentally pressing any buttons and/or the touch screen (I accidentally called someone once). Next remember The Trick is All Thumbs. On my Pantech Ease it is almost impossible to open the back cover without using Both Thumbs Pressing Down while simultaneously using Both Thumbs to Slide the cover off. It also seems to work better if you hold the phone sideways so when you are pressing and sliding the cover if sliding off to one side or the other. The bright side of having a cover like this is that the cover does not easily pop off when you don't want it like other phones I have owned in the past. Hope this solution is helpful.
Jun 26, 2012 | Pantech Ease P2020 AT&T
Lcd screen has lines in the middle area (3" wide
Laptop screen display problems occur for many different reasons. Some issues need professional attention, but others can be repaired by the owner. A screen that displays vertical lines often means that there is a problem with the video cable connection to the LCD screen, or the cable itself. In order to repair this problem, the display screen must be disassembled. If you feel confident that this task is within your realm of expertise, follow the steps below to remove your laptop's LCD panel and fix the vertical line problem on your laptop screen.
1. Remove the rubber seals covering the screws on your screen's outer frame using a flat-head screwdriver. Remove the screws, then carefully pry the frame from the screen using your fingers. Release the plastic latches holding the framing in place, then remove.
2. Remove the screws holding the screen to the support brackets. You will see the video cable, which is attached to the back of the LCD screen. Try unplugging and reconnecting this cable, making sure that it is seated properly. If the problem was the connection, this may solve the vertical line issue.
3. Turn on the laptop. Move the video cable around a bit, without moving or touching the screen. Check the screen to see if the display image changes at all. If it does, the problem may be with the cable itself.
4. Move the laptop screen around to see if this affects the display. If so, the problem is most likely with the LCD screen itself, not the video cable. Replacing the screen will be necessary.
I hope you find it very helpful. Best regards.
Aug 17, 2011 | Acer Computers & Internet
My hp dv600 when powered up looks normal but if i give it a few seconds the screen goes black and wont come back i shined a light and i do have picture but no light maybe ballast?
alejandro,
An LCD screen cannot produce enough light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Very similar to the Fluorescent lamps, (Bulbs), used in homes and businesses, but on a MUCH smaller scale.
HP Pavilion dv6000z series Notebook PC, is a general series designation. The EXACT model number is on the bottom of the laptop in a white Service Tag.
The HP Pavilion dv6000z series of Notebook PC's used either an LED or CCFL type of Backlighting.
Depends on which model it is.
http://www.screentekinc.com/backlight-ccfl-led-explained.shtml
As stated in the above information a Backlight is mounted in the back, or on the side of the LCD screen.
The LCD screen is composed of layers. These layers are held together by a metal frame which emulates a picture frame. If the Backlight is a side unit it will be held in place next to the layers, and inside the metal frame.
[Which means the LCD screen's metal frame, (LCD Panel Frame), needs to be opened on one side.
This will leave the layers which compose the LCD screen loose. The layers MUST be held in the proper placing when changing out the Backlight. Not an easy job to accomplish]
An Inverter is used to change the power coming from the laptop, to be used by the LCD screen, and Backlight.
90 percent of the time the problem is the Inverter.
The Inverter for the Pavilion dv6000z series of Notebook PC's is located inside the Display Assembly.
The Display Assembly is the
1) Display Enclosure Cover, (Plastic top of laptop),
2) LCD screen,
3) LCD Panel Frame, (Metal frame around LCD screen),
4) Display Bezel, (Thin plastic frame which surrounds the LCD screen in the front)
5) Camera Module
6) Inverter
7) Display Enclosure Cover Hinges (2)
8) Display Enclosure Cover Hinge Covers (2)
9) Wireless Antenna Transceivers and Antenna Cables
10) Microphone receivers and cables
11) Various mounting screws
[The Top Cover for a Pavilion dv6000z series Notebook PC is essentially the Palm Rest. The cover under the Keyboard]
With the Display Bezel removed the Inverter is located at the bottom.
(Display Assembly removed from laptop first)
HP Support > Pavilion dv6000z Notebook PC series> Manuals>Service Manual>
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3224052&
One example of an Inverter for an HP Pavilion dv6000z series Notebook PC,
http://www.amazon.com/DV6000-DV9000-V6000-INVERTER-AS0231721C1/dp/B00480MXUS
Please post additional questions in a Comment.
Regards,
joecoolvette
Jun 11, 2011 | HP Pavilion dv6000z Notebook
2 inch band across the bottom of screen
Downloading programs would not cause the type of problem you're having. It should be a hardware issue only.
1.The bottom area of your screen is close to a small curcuit panel behind the bottom plastic border of the screen frame. This little panel/bar is called the Screen Inverter. If its connection plug has loosened it could be the culprit.
2. The Display Cable behind the screen panel has become partially unplugged or damaged in some way at the top of the screen, or, it has looseened at its plug connector just underneath the back edge of the power strip panel/keybaord area so that pressure applied to the bottom of the screen frame makes it connect correctly.
3. The Screen Panel itself is failing.
These are the 3 areas I'd say you should have a laptop repair tech look at locally in your area.
Best of Luck
Jul 13, 2010 | IBM Lenovo ThinkPad T60p Notebook
Screen craking guaranty my laptop screen damage i take 1 year ago and also under guaranty preoid
Contact Compaq here:
http://h18000.www1.hp.com/cpq-country/cpq_support.html?jumpid=hpr_R1002_USEN
Dec 11, 2009 | Compaq Presario CQ60-220US PC Laptop
Tx1320us cracked lcd
If you can elaborate on the exact issue, I will surely try to help.
FYI,
As TX1320us is new notebook, I guess it is one year below model and it should be under warranty.
If you have any issues with the screen, then you can get replacement from HP.
If it is accidental damage, then it won't be covered under warranty. If you have purchased Accidental Damage Package from HP, then all broken and other damages will be covered ADP.
Anyhow, reply if you need any information in this regard.
I will be happy to answer.
Aug 08, 2008 | Computers & Internet
Does my protection plan cover a damaged LCD screen on my laptop?
It depends on the warranty you purchased. Most basic warranties do not cover accidental damage, such as the damage your laptop sustained. Your best bet is to contact Gateway directly - they will be able to determine your warranty coverage. (Or if you purchased through a store like Best Buy, take it to them.) If you do not have ADP, you would have to pay for the repairs out of pocket.
Jun 17, 2008 | Gateway MX6920 Notebook
Laptop upper part screen burn
If you are talking about the plastic cover, you can do that. If you have never been under the covers on this unit, it will probably take 2-3 hours to do it. I'd suggest looking somewhere like Ebay to try to pick up a used, non functioning LCD unit, for as cheap as you can. Went you take the parts out of the used unit, you should have a pretty good idea as how to replace the cover on your unit.
Ron-
Feb 22, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
