Question about HP DeskJet F380 All-In-One Printer
Printer Status Reads Offline
On 11/3, I had to have my computer reinitialized and my programs reconfigured. Today I tried to use my printer, but it's offline. How do I get it online again so it will print? I have a HP Deskjet F380 which is hooked up to my computer. I've successfully installed the printer driver and did few prints, which worked fine for two weeks. Today when I was trying to do a print, the printer staus said to be offline eventhough the printer is connected to the computer and turned on.
Please help rectify this issue. Your help will be greatly appreciated.
  • Anonymous Nov 28, 2008
    how to change current printer setup
  • Jaks08 Nov 28, 2008
    Many thanks.........
    By looking at the solutions you had, I went ahead and re-install the printer driver and it worked fine.
    Once again...thanks for your help.
  • 57 Answers
The problem is that your print and your computer are not communicating.
Try to print a test page.
This could be a hardware conflict:
right click on my computer
select properties
select hardware
then select device manager
There should be no ! or ?
If there is not an error sign then try to reinstall the drivers again under safe mode.
If there is an error see below
If there is then you have a conflict or other problem with that device
double click the device and see what the device status says.
if it is a resource conflict (sounds like it is) then click the resources tab and at the bottom you will see a conflict device list.
You should be able to adjust your resource allocations from this same window. Do this by deselecting use auto settings and click change settings. You will be able to adjust up and down to find a resource location to use. Like telling the comp where in memory to put the info you don't want it going to the same place as another device is.
Posted on Nov 27, 2008
Always shows "Printer offline" status (Mac OSX)
Have you installed the printer driver for the selected printer??
Oct 30, 2017 | Samsung Clp-325 Colour Laser Printer
Printer offline wont print cant get back online
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Jan 12, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
The Brother MFC-7840W printer was installed on a USB connection. The printer worked the previous week albeit not for all applications but at least for the Vista word program. Now it doesn't respond to...
Hi there!
You can check if the usb cable is connected directly & securely from printer to your computer. Once it's verified. The display of your printer should show the date/time.
Since the printer is displaying offline you can open Control Panel, go to Printers folder right click on the printer icon and select 'Use printer online' If you have pending documents right click on the printer icon and click on cancel documents.
Try checking for a duplicate copy of your printer driver or check which printer driver is selected as the default and has the status ready.
Right click on the printer driver that has a Ready status click on printing preferences and click on print a test page.
Hope this helps! Vikroks
Mar 22, 2011 | Brother MFC 7840W Printer
I checked everything, the printer is connected, there's ink, everything is good, but it says it's offline. I clicked "Use printer online", but it's still offline. I tried Refresh, and it's still...
The first thing I would check is the cable. If you're using a USB connection, try a different (and known to be good) USB cable. If that doesn't do it, you may have a damaged USB connection socket at the printer, which is not cost effective to repair.
Hope that's helpful.
Dec 31, 2010 | HP Deskjet F335 All-In-One InkJet Printer
Printer status always offline
go to your programs and select printer and faxes..rigth click your printer icon and select use this printer online..and if you want make this printer to be a default printer select also use this printer as default..
May 18, 2009 | HP DeskJet 3940 InkJet Photo Printer
Printer offline
first of all when you upgrade your computer you deleted all your program thats why your computer cant recognized your printer. do you still have the disc the came with the printer if you do dont worry the only thing you should do is restall the program by inserting the disc into the computer and then follow the steps in the screen.
Apr 24, 2009 | HP PhotoSmart C4385 All-in-One Printer
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
"Offline" means there is no signal from the PC to the printer. Check the following:
1. The printer is not in "Sleep Mode",
2. It's ON,
3. The cable is attached to both the printer and the PC.
4. Go to the Printer Config in Control Panel, right click on your printes' icon and remove the tick/checkmark from "Offilne".
Nov 06, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
Photosmart 2575 printer is offline - won't print
Good Day,
One thing you can try instead of deleting the doucment writer is to change the default printer. You can do this by right-clicking on the HP printer icon and selecting "set as default" from the drop down box. Also try turning the printer off and back on aswell as restaring the computer if you have'nt already. Did that printer ever work from that computer? How is it wired, by "switcher" do you mean a shared printer through you network(was printer sharing configured properly), or an A-B printer switch. Please clarify
Hope this helps for now
Jul 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP DeskJet F380 All-In-One Printer Logo
233 people viewed this question
Seeker5211
Seeker5211
