Question about Refrigerators
New water filter replaced follower instructions in book Orang lig
Replaced water filter with new one, followed instruction in book, Orange light came on will not go into Green, now Red after 2 weeks of replacement Now water stopped all together.Fridge model;SRS757OW;;Serial no.345342BY800.Fridge less than 3 years old.Removed and replaced filter again and ran water through system as discribed in service book provided with fridge Could you advise me on the next step to look at please.Thanks damien.
    Sergeant:
    Champion:
  • 311 Answers
There is no sensor that knows you replaced it. Probably have to hold down a button or two to reset light on dispenser area; read your manual for directions or find it on-line from the mfr website if you don't have it. I do not know what key sequence.
Posted on Nov 28, 2008
We have recently installed a new water filter into our steam mop ,but it does not work now and makes a load clicking noise
Follow the instructions to de scale the steam chamber. If it is not getting hot at all , check the thermostst and the hi temp safety switch for proper operation.
Dec 31, 2014 | Filter Vacuums
RE: R/O system. Model # PNRQ20FBL Serial # TM30938P This system was in our home when we purchased it in Aug, 2009. The home was less than a year old - so the system was...
is there a precharge of air in your tank. when empty of water th?re should be about 1 bar or 14psi of air. water must be able to empty from tank. pump air in until all water is gone. if unable to empty tank has failed. also if a pumped unit, when changing filters ensure all air is bled through pump before turning it on toprevent air locking inside pump
Feb 28, 2017 | General Electric Profile Smartwater Ultra...
I recently replaced the water filter and now the water will not dispense. When you depress the water dispenser lever the water runs out from underneath the fridge. I followed the instructions for...
If the last thing that you did "replacing the filter" seemed to cause the situation I would first try switching back to the old filter and seeing if it starts to work fine again then you know that that was the problem. If you already got rid of the filter then you may want to get another one and see if that clears things up. New filter is still way cheeper then a service call.
Apr 10, 2011 | Refrigerators
How do I change the water filter? I can't figure out how to get it out.
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
When you buy the new filter, it usually comes with an instruction sheet.
Feb 05, 2011 | KitchenAid KSCS25FKSS Side by Side...
Kenmore HE2 washing machine. Was not pumping all the water out. Followed instructions to pull panel and get to the pump filter. Emptied the pump filer and replaced. Replaced the panel. Now, when...
try unpluging the washer for 5 to 10 minutes,the computer gets out of wack sometime and needs to be restarted just like your house computer,did you find the tech sheet while you were working on the pump,if so look up what's happening to you and follow the instructions,let me know how you make out
Sep 04, 2010 | Kenmore HE2 Plus Front Load Washer
I need the instruction book for the New Homer
Well you can please follow the below link to get your instructions manual -
http://www.devicemanuals.com/guide/Balance/A&D/A-D-HF-3000-Balance-Instruction-Manual-English-==TWpZMk5EWXg=.html
Good Luck!!
Thanks for using FixYa!!
Jul 06, 2010 | New Home HF-3000 Computerized Sewing...
.error 1700 says waste ink absorber nearly
(In waste ink absorber replacement, perform
the EEPROM information print to identify if the main and/or platen
waste ink absorber should be replaced. After replacement, reset
the applicable waste ink counter(s).)
Waste ink counter reset See “Service mode operation
procedures” below.
The following 3 methods are available:
- Resetting the main waste ink counter (0%)
- Re-setting the main waste ink counter
value to 50%
- Resetting the platen waste ink counter
(0%)
<Service mode operation procedures>
1) With the front cover closed, and the printer power turned off, while pressing the Resume/Cancel
button, press and hold the Power button. (DO NOT release the buttons. The LED lights in green
to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.) During initial operations,
the LED blinks in green.
4) When the LED light sin green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the
carriage returns and locks in the home
position.
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting Proceed to the step 5), and follow the
Waste ink counter reset procedures.
5 times Orange Destination settings Proceed to the step 5), and following the
Destination settings procedures.
6 times Green Print head deep cleaning
7 to 9 times Orange Not used in servicing
10 times Green Return to the menu selection
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu
selection mode automatically.)
<Waste ink counter reset procedures>
In the waste ink counter resetting mode, press the Resume/Cancel button the specified number of
time(s) according to the ink counter reset value listed in the table below, and press the Power button.
Time(s) LED Waste ink counter value
0 times Green Reset the main waste ink counter (0%).
1 time Orang
e
Reset the platen waste ink counter (0%)
2 times Green Re-set the main waste ink counter value to 50%.
<Destination settings procedures>
In the destination settings mode, press the Resume/Cancel button the specified number of time(s)
according to the destination listed in the table below, and press the Power button.
Time(s) LED Destination
0 times Green No change
1 time Orang
e
Japan
2 times Green Other than Japan (A4)
3 times Orang
e
Other than Japan ltr
Jun 24, 2010 | Canon Office Equipment & Supplies
Door display has CF , I can't find anything in the book that came with it to tell what to do
it means
Change
Filter
your water filter needs to be replaced
once you do the instructions to clear the code should be on the box the new one came in
but if not try pushing lock and light for 5 sec
Oct 10, 2009 | Refrigerators
Refrigerators Logo
197 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
