Question about Cameras
Camera and flash gun trigger voltage
Hello Kalaci, First, I would like to thank you for your help with trigger voltage compatibillity for my camera and flash gun.
I wish to buy a wirless trigger but the seller needs to know the trigger voltage of my fuji finepix S9500 and the voultage of my Vivitar auto thyristor 2800.
Would you know the voltage for both or could you tell me where I could find them?
Kind regards,
Syd.
  • sydmcnin Nov 29, 2008
    Hi Laszlo, Thank you very much for your help, i wish you and your family a very Merry Xmas and the very best of luck for 2009.
    Kind regards,
    Syd (Belfast)
    New Friend:
  • 30 Answers
Hi Syd,
Vivitar 2800 and 2800D are two different flashes. The first is an old flash, having high trigger voltage, which, as you will see, still can be used with your Fuji. The second is a member of modern flashes, having a low-voltage release. Manufacturers specify the highest applicable voltage at the trigger (hotshoe or PC) terminal; at most digital cameras it reaches several hundred volts.I believe, this is, what your seller was asking. As far as I know, Fuji doesn't mention this value in the user manual of the Finepix 9500, but I met reports of people, who called Fuji and asked that and the answer was 400 volts!
So the short answer is: buy any wireless trigger if you have the 2800D, and tell the seller the flash has about 200 volts if your flash is an older 2800.
I wonder if you did already use your flash with your Fuji?
Laszlo
Posted on Nov 28, 2008
Will it work with my canon rebel xs
You must make sure that the voltage of the flash gun is not too great for the camera if it is then you may damage your camera electrics. Test it using radio triggers off camera.
Dec 18, 2015 | Vivitar Auto Thyristor 2600 Flash Unit 4...
How can I use a vivitar 2600 with a sony a6000
What have you attempted to do that did not work. Does the Vivitar 2600 slide on the a6000? If it does slide on it should fire. Also, you can use wireless trigger and receiver as well.
Oct 15, 2014 | Cameras
What is the trigger voltage of this flash gun
Okay to use on digital camera.
Trigger voltage is under 11V.
Apr 07, 2014 | Metz mecablitz 45 CL-4 TTL Flash
Cobra MD210 flashgun on Nikon D90
Take care. Nikon does warn every user of the modern DSLR's not to use old flash guns. Old camera's were fitted with mechanical switches. In those days nobody cared about 5, 12 or even 100 volt on a flash gun. Modern camera's use electronic switches (transistor) and they only can survive when hooked up to modern flash guns, because these guns block high (above 5 Volt) voltages.
Nov 04, 2013 | Nikon Cameras
Can I use Speedlight SB-50DX with Canon EOS Rebel Xti
It is not possible to use the Nikon SB-50DX directly on a Canon EOS Rebel camera. The Nikon flash gun hot shoe contacts do not match the Canon hot shoe contacts.
You can use the Nikon as a slave flash gun with a PC flash cord that matches the Nikon's flash contacts then connect the end of this flash cord to a flash trigger. The Canon's flash can then trigger the Nikon flash gun via the flash trigger.
Dec 27, 2011 | Nikon Speedlight SB-50DX TTL Flash
I now have a Nikon D80. I have a National Flashgun Model PE300SWG Can you advise me if this 'gun is safe to use with the D80?Nikon tell me that as long as the trigger flash voltage is o--250volts it is...
A flash trigger voltage in the 250V range is fine for most film cameras, but not for most digital cameras. The PE-300 has a trigger voltage in the 33V range, which I (and most others) would consider much too high for the D80.
BTW, "National" is a brand name used by Panasonic.
Oct 21, 2011 | Panasonic Cameras
What's the trigger voltage of Vivitar DF283?
According to http://www.botzilla.com/photo/strobeVolts.html the newer ones made in China or Korea are in the "Your call" range, about 5V to 10V. The older ones can go as high as 600V.
Apr 15, 2010 | Vivitar DF283 TTL Flash for Canon
Have new Nikon D700. Have Mets flash gun. Have
Even older flash units from the same manufacturer can damage newer digital cameras. It's a matter of the trigger voltage. Older flashes can put a lot more juice through a digital camera than the camera can handle.
Since you neglected to specify the model of your Metz flash unit, I can only suggest you look it up here.
May 05, 2009 | Nikon Coolpix 5700 Digital Camera
Vivitar trigger voltage
Yes, you can. The flash has a low-voltage trigger circuit.
Laszlo
Nov 14, 2008 | Cameras
Vivitar 3200 Flashgun and Canon EOS 400D
Using Vivitar 3200A flash gun on a DSLR is risky for the following reason. The trigger voltage of a DSLR at flash hot shoe that takes it to its TTL (through the lens) circuit is less than 10 volts, it is about 6 to 8 volts in the recent DSLRs. The trigger voltage generated by Vivitar 3200A at full charge flashing is around 180 volts (max). That is a fatal dose for a sensitive DSLR TTL circuit. This high voltage flash gun will work endlessly, the only damage is to the TTL flash circuit. When you attach a TTL flash to the DSLR after using Vivitar 3200A for sometime, your TTL flash will not communicate with your camera. It will be just another ordinary flash without any auto functions. There is a Wein adapter that you can fix b/w your cameral hot shoe and the vivitar flash gun that is said to reduce the trigger voltage that passes into the camera. Try it if you get it. Without this gadget it is better not to use non recommended and non TTL flashes on latest DSLRs.
Apr 13, 2008 | Cameras
Cameras Logo
1,048 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
