Question about HP LaserJet 1320 Printer
Engine fuser error
My HP P1006 is giving me an engine fuser error, at times it can print 1 or 2 pages before the error comes up. How can I resolve this problem?
    Problem Solver:
  • 5 Answers
You need to service the Printer fuser unit,
if this is an intermittem error,
this will fix,
must be a loose connection in the fuser
Posted on Nov 28, 2008
How do I solve this problem? My hp LJ 4345 printer experiences intermittent paper jam in fuser(accordion-like) with half of the paper out of the fuser. We've replaced the fuser with a new one but the
This error can be caused by the following:
1. Fuser that is close to end of life. Maximum print quantity is 225,000 pages.
2. poor quality paper, very thin paper never feeds well and will jam.
3. Printing an image that is almost entirely black can cause the paper to buckle before entering the fuser.
Try different paper to see if that resolves the problem.
Sep 02, 2014 | HP LaserJet 4345mfp Printer
What is the rate of teflon of 1005 printer
Do you mean how many pages does the P1005 print before it requires replacement?
Here is the service manual, it is the fuser fixing sleeve:
http://www.lbrty.com/tech/Manuals_HP/P1000sm.pdf
A youtube video on the procedure:
https://www.youtube.com/watch?v=dSenawkbM3M
The part on Ebay, it mentions 30,000 pages:
http://www.ebay.com/itm/1x-Fuser-Film-Sleeve-HP-LaserJet-P1005-P1006-P1007-P1008-Grease-Grade-A-manual-/270940113101
May 28, 2014 | HP LaserJet 1020 Printer
Hp t1100 error 50.2
nstructions
  1. Remove the printer from any UPS supplies, additional power supplies, or power strips.
  2. Plug the printer into a wall outlet to check whether this resolves the problem.
  3. If the printer is already plugged in, try another power source in the building independent of the one being used.
  4. The line voltage and current source at the printer location might need to be inspected to make sure that it meets the printer's electrical specifications.
  5. Turn the printer off then on.WARNING: Be careful when removing or reseating the fuser. Temperatures can reach 400+ degrees Fahrenheit.
  6. If the message persists, turn the printer off for 30 minutes to allow it to cool, then reseat the fuser after checking the internal wiring connections on the right and left side, ensuring that these connections are properly seated.
  7. If the 50.1 or 50.2 error recurs after power-cycling the printer or when trying to print, try installing a known good fuser from another HP LaserJet 4100 series printer, if available.
  8. If the fuser is near or at the end of its estimated life expectancy (approximately 200,000 pages), then replace the fuser. After replacing the fuser, print a Configuration page, a Menu map (shows fuser settings), an Event log, a Supplies status page, and a Usage page, to reference the status of the new fuser and to ensure that the previous fuser settings are in place with the replacement fuser. To print an Information page on the HP LaserJet 4100, perform the following steps
    1. Press the MENU rocker key until INFORMATION MENU appears on the printer display.
    2. Press the ITEM rocker key until PRINT CONFIGURATION (or until PRINT MENU MAP, etc, appears in the printer display.
    3. Press the SELECT button to print the selected information page.
    To print an information page on the HP LaserJet 4100MFP, perform the following steps
    1. Press the MENU button.
    2. Press the DOWN Navigation button until INFORMATION is highlighted.
    3. Press the RIGHT Navigation button.
    4. Press the DOWN Navigation button to highlight PRINT CONFIGURATION (or PRINT MENU MAP, etc, appears in the printer display.
    5. Press the SELECT button, the button with the checkmark on it to print the selected Information page.
  9. If 50.x errors persist after properly installing a known good fuser, or if the errors follow the questionable fuser (provided it is not near the end of its estimated life expectancy), contact HP for further assistance.
Removing and replacing the fuser
Mar 23, 2013 | HP Designjet T1100 Photo Printer
Hi there. I have a HP LaserJet P1006 printer and a laptop with Windows 7. The print jobs get stuck in the que and I cant delete it. I installed the cd software many times, and I have installed the software...
you are installing the drivers may be not correct. u remove the printer driver and install the proper driver again otherwise it may be spooler problem then u have to reinstall the os and configure printer dirver
Apr 07, 2017 | HP LASERJET P1006 Printer
HPlaserjet P1006 Series When printing getting a white blank streak down the middle of the page
To isolate the problem you need to do a 'half test'. This involves printing and stopping paper half way through the printer. This can be done by opening the toner door at the appropriate time. The paper should have just entered the fuser (watch out, the fuser is HOT). You should see the paper with the printing on it after removing the toner cartridge. Carefully turn the toner cartridge over and move back the door that covers the drum. DO NOT TOUCH THE DRUM. If there is the corresponding blank spot in the center of the drum, like the paper, the scanner is dirty or blocked. A can of compressed air will help here. If you have access to a different toner cartridge, you may want to try that first.
Jul 20, 2009 | HP LASERJET P1006 Printer
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
Hp laserjet p1006 printing jobs gets struck in printing queue
I know this problems in my part it was the hp driver.
My Solution is to use an compatible driver.
HP Laserjet 5 / or 6 standard windows driver.
After that i have not this problems.
The secound problem is that this printer have very less memory and big pages in a few times are not able to print.
Dec 25, 2008 | HP LASERJET P1006 Printer
LJ3700 page tops half- way through fuser. Bob
13.01.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. 13.02.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. these are areas that you mentioned and fixes to them http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478#A3 this is the link to all error codes for your printer you might want to print these out and keep safe
May 07, 2008 | HP Color LaserJet 3500 Printer
HP LaserJet 1320 Printer Logo
1,136 people viewed this question
Ben Johnson
