Question about HP LaserJet 5p Printer
Out of memory
Printer says out of memory how do I fix it
  • 22 Answers
You need to add more memory or modify the print job that you are trying to print. You can try changing the dpi to a lower value.
Posted on Mar 17, 2007
SOURCE:
Initializing scanner hp cm6040
Most common cause of the error on this printer is the memory on the CPB (copy processing board) is bad. This board is picky about memory and typically only works with the actual HP memory designed for it. The easiest fix is to use the memory that is currently installed on the formatter, which is identical, and purchase 3rd party memory for the formatter, which will support any compatible memory.
May 07, 2016 | HP Color LaserJet CM6040f MFP Q3939A...
We have a HP 8150N. The printer will not print and is giving a 62.0 printer error message. We have turned the printer on and off which has not helped. Is there an eazy fix?
62.0 memory error. This error indicates that the memory that is soldered to the formatter is likely bad. If the error was 62.1 or 62.2 that would indicate that the memory in one of the upgrade slots was bad. The only real solution to 62.0 will be to replace the formatter.
Jun 13, 2011 | HP LaserJet 8150n Printer
If printer runs out of paper and you refill starts
The continuous printing issue can be fixed following this link
http://www.fixya.com/support/r5095488-unable_print_hp_printer
Regarding Gibberish printing or say garbage printing, If the above utility does not fix this issue, probably the printer drivers are corrupted, and you may have to uninstall the printer software from your pc and download and reinstall the latest drivers. this link below will let you choose the operating system of your PC and download the drivers
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=60426&lc=en&cc=us&dlc=en&lang=en&cc=us
Jul 07, 2010 | HP DeskJet 842c InkJet Printer
Problem prompt on DIMM error
If the printer freezes or crashes at memory count or if the printer shows error Mem test failure replace DIMM or if the printer display is completely blank in that case obviuosly you can try reseating Mmeory Module.
However that doesn't fix the problem formatter board is faulty.
Need to get Formatter replaced.
Thanks and Regards
Neeraj Sharma
Jun 27, 2009 | HP LaserJet P3005n Printer
I don't want to add memory. is it possible to erase memory?
Your posting is a little unclear, but let me answer with the information you have provided.
You have a brother multifunction printer and you have instructions for adding memory.
the memory in the printer is referred to as "volitile" which means that it holds informaiton as long as there is electricity put to it. If you would like to clear the memory, simply unplug the machine for about 30 seconds.
if you have a problem and are being directed to fix that problem by adding memory, then the print job that you are sending to the printer is too large for the amount you have loaded in it.
try printing fewer pages.
good luck
Jun 10, 2009 | Brother MFC-8860DN All-In-One Laser...
Canon Printer HELP
You go to your printer setting & find out "Clear Memory" Option pass it.
Mar 31, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
WE HAVE A OKI B4300 PRINTER IN OUR LAB (WE ARE A MEDICAL CLINIC). IT SEEMS TO BE STUCK IN SOME SORT OF LOOP. THE DISPLAY READS RAMCHECK AND INITIALIZING OVER AND OVER AGAIN
If the printer has additional memory, remove the memory and reboot the printer. If the printer initializes, the ram memory may be defective. Try reseating the optional memory, if unit fails to initialize, memory option is defective.
If the printer does not have any additional memory, this "RAM CHECK" condition is probably being caused by a low voltage power supply problem. It is recommended to replace the low voltage power supply - part number 41991601.
Jan 12, 2009 | OKI B4300 Led Printer
Speed
Add memory to the machine and it should resolve your issues. The 2840 comes with 96MB built-in and has one slot open for additional memory located under the right side cover. It can take a max of 224MB total. I would recommend adding a 128MB memory card to max out the machine. It takes 100 pin, 133MHz, SDRAM.
Don't by it from HP as they list it at $500.00 or so. Buy the clone memory for around $25.00 for 128MB.
Here's a link to source the memory:
http://www.memory.com//net/System.aspx?model=23451
Hope that helps you.
Jul 10, 2008 | HP LaserJet 2840 All-In-One Printer
DIMM Error HP P3005n
Hi, The Dimm Error your receiving does it have any numerical codes ? The firmware could possibly be defective ?
Dec 03, 2007 | HP LaserJet P3005n Printer
HP LaserJet 5p Printer Logo
Clive
Clive
Thomas F. Schneider
