Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Installing themostat for Whirlpool
Need to get a description on how to install the thermostat unit (#2198202) for a Whirlpool side-by-side refrige.
  • Court Jan 10, 2009
    Dial is located on the top left portion of the refridgerator compartment. I have a side-by-side unit.
  • Shane Hays May 11, 2010
    Where is the dial located?
    Scholar:
  • 82 Answers
Usually there are some screws that are at the area where the dial is. If it is the type I am thinking of it has a long capillary and two areas where the wires plug into. If you take off the wires you can usually follow where the capillary is and intall it. It is pretty self explanitory once you get the screws out. If this doesn't help you, can send me a picture and I can go from there.
Posted on Jan 12, 2009
I have a Whirlpool side by side refrigerator #ED22TQXGW00
Replace that part and that will solve this problem. 2198202 Temperature Control Thermostat
Make sure you unplug the refrigerator before beginning work, Sea Breeze
Feb 13, 2013 | Whirlpool GS6SHEXNL Side by Side...
Compressor on refrig/freezer not working, fan next to compressor stopped working also.
Sounds like you need to replace the thermostat which is located behind the refrig control knob . Tap on the knob and if the refrig starts , replace the control behind the knob .
Oct 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by Side Model # ED5GTN It is not staying cold - freezer let everything defrost and fridge not staying cold.
Open the freezer door and listen for the freezer fan . If you do not hear the fan , tap on the refrig thermostat knob mediumly . If the freezer fan comes on , then the thermostat is bad , pt # 2198202 which is located behind the knob . If you DO hear the freezer fan , then the overload / relay on the compressor is bad which is pt # 8201786 ( comes with instructions ) . Both are easily repairable . If any problems , reply back for more help .
Aug 03, 2010 | Refrigerators
Fridge is freezing food
ajust your themostat down and if that dont fix it ,you will need to replace the themostat part # 2198202
contact searsparts.com to order it
Feb 01, 2010 | Whirlpool ED2FHGX Side by Side...
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Whirlpool Model ED5SHAXML12 is freezing food in refrigerator even when dial is at off. Happened from one day to the next.
At the refrig controls , the freezer control , controls how much air goes into the refrigerator section . Open the refrig door , and up at the top left , put your hand over the damper (air vent) . Turn the freezer control from high to low , and feel the difference in the air flow . If you turn your freezer control to a lower setting , less cold air will enter the refrig . Think of it as : the freezer control adjusts the temperature , and the refrig control , tells how long to run the compressor . In actuality , this is how it works . However , with the dial (refrigerator thermostat) in the off position and refrig still running , this indicates a bad thermostat . Pt # 2198202 .
Sep 09, 2009 | Whirlpool Refrigerators
Side by side model ED5FHEXLQ01,not freezing,fridge not cooling
Check the compressor and see if it is running , If not , Pt # 8201786 . If freezer fan is not working , then Pt # 4389144 . Be sure to check the coils under the front of fridge to make sure they are clean , If nothing is running , tap on the thermostat , and if refrig starts up , then Pt # 2198202 will do it .
Aug 01, 2009 | Refrigerators
Temperture control switch not working
If the temp control works manually then that tells me that the tube that is connected to the thermostat is not telling the refrigerator compressor and fans to come on by sensing the temp change. The part number for the thermostat is 2198202 if the model number is correct above your post. If ED25PQXF is not the model number then we need to possibly change that number. Let me know, Thanks Sea Breeze
May 19, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
246 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
