Question about Nikon Coolpix 4600 Digital Camera
Coolpix 4600 "Battery Exhausted"
My Coolpix 4600 gives "Battery Exhausted" message even after changing batteries several times. I'm using long life lithiums, and they've been working fine for several hundred pictures.
  • 4492crystal Dec 03, 2008
    My Nikon Coolpix 4600 has also suddenly stopped working. It just gives me an error message saying "warning: battery exhausted." Sometimes I can get it to turn on for a very brief moment, but it then shuts itself off. It was taking pictures & then suddenly gave the error message. I've changed the batteries & it still has the same error message.
  • Anonymous Feb 07, 2009
    I have the same problem with my Nikon Coolpix L15. I hand-carried the non-working camera (which was within the warranty period) to a local Nikon office. They kept the camera for 2 weeks and returned it to me. I thought it was fixed, but NO! After I took it home, I found the same problem still there. I've already spent 10 hours to fix it, and I don't want to waste more time on it, so I gave up and did not bring it back to them.
SOURCE: Battery EXTREMELY Exhausted
As the other person says Nimh rechargable batteries are the best....Also somewhere in the menu system you will find that you need to define which type of battery you are using, this may be the cause...Nikon UK have an excellent after care team if all else fails.
Posted on May 25, 2007
zohail
  • 1223 Answers
SOURCE: Battery exhausted always showing on camera
pls call canon it may be linked to this problem ur model is different i know but i think problem is same and they are responsible for that repairs
http://www.nikonusa.com/Service-And-Support/Service-Advisories/COOLPIX-L16-L18-Service-Advisory.page
pls remember to rate me FIXYA fo rhelp
Posted on Apr 13, 2009
SOURCE: Nikon Coolpix L18 display shows
what??im not gettin a new camera, i just got this one less than a month ago. why does it do that?
Posted on Jan 04, 2010
muntejaya
  • 10421 Answers
SOURCE: Nikon CoolPix S3000 shows battery
Your battery is wear down and need to replace.
Posted on Dec 17, 2010
SOURCE: My Nikon CoolPix L22 camera
i already change new battery but nothing happen then.
Posted on Jun 02, 2011
Coolpix L26 shows "Battery Exhausted" with new batteries
There is an internal battery like a watch battery. That is the one that is dead.
Jan 24, 2013 | Nikon Coolpix L26 Compact
My camera Nikon coolpix L21 . shows battory exhausted please give me solution.
Are you using rechargeable batteries? Even rechargeable batteries have a life span. If you get "Battery Exhausted" error, it means it is time to change the batteries for a new one.
I hope this helped you.
You can rate my anse if you appreciate my help.
Thanks!
-damneddle
Oct 22, 2011 | Cameras
Nikon L100 shows battery exhausted error message after installing new batteries. Unable to perform any operations on camera
That's the bug in Nokin L100, update the firmware version from 1.0 to 1.1, this will solve the battery exhaust problem. Firmware version 1.0 has only 2 battery (Alkaline and Lethium) option where as Firmware version 1.1 has Nickle battery also. But, to update the firmware you need to have EH-67 AC Adapter to give power to the camera.
Jan 24, 2010 | Nikon COOLPIX L100 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image Mode selection.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon coolpix 5600/4600 - won't turn on
I had the some problem... found a fix on another thread here on fixya...
hold the power button and at the same time press the play button.
Mine turned on after about 3-4 seconds of holding them down together!
Aug 06, 2008 | Nikon Coolpix 5600 Digital Camera
Short battery life?
I had a smiler problem with Alkali batteries. Thereafter I started using rechargeable batteries and also changed the setting to Ni-MH. Its working fine now.
Feb 26, 2008 | Nikon COOLPIX L10 Digital Camera
Battery error
Clean the battery contacts in the top and bottom of camera- Come back if no go
Aug 17, 2007 | Nikon Coolpix 4600 Digital Camera
Digital camera
No firmware upgrade available yet, but did you set the camera settings to the TYPE of battery you are using? Go to Setup, chose Battery, then set type - alkaline, lith, metal hyd, etc and see if that helps.
Jun 20, 2006 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
81 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
