Question about Microwave Ovens
GE Microwave Model # JE1860: Unit does not heat. The timer counts down, but the oven does not heat.
  • 1 more comment
  • rushipa Apr 22, 2009
    I have the same problem.. Control Pad lights up.. When express cook or time cook is selected, the timer counts down BUT the turntable does not turn, no sound at all... Just before the count down starts, a small click is heard... I tried other options like Popcorn and got an error message that said " sensor error, close door and press start"
    Any help would be appreciated...The model is JE1860.. Thank you...
  • Anonymous Apr 26, 2009
    I have the exact same problem as Rushipa! What's wrong?
  • William Miller
    William Miller May 11, 2010
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises? Is it louder or quieter than usual?
    These answers will help me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • Microwave Ovens Master
  • 9,098 Answers
When you hit Start to cook, do the inside light, cooling fan, and turntable come on?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Posted on Dec 02, 2008
GE Model # JVM7195SFSS microwave.
Check the internal ceramic fuse on the circuit board. Sometimes one section will work while another won't. I'm not sure if this model has a rear mounted thermal fuse, but the models with the inline thermal fuse will cause a similar issue.
Jul 04, 2014 | GE XL1800 1100 Watts Microwave Oven
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
Have ge model je1860 turns on but when you hit cook nothing happens is it the turn table motor. i don't want to do trial and error on parts.naturally the fuse is good
I'll presume you can program it ( set the length of time you want to cook)
Does the timer count down?
Does the turntable ( if you have one) turn?
If everything else seems to work properly and it just doesn't cook more then likely the magnetron is bad
$87 from Sears:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JE1860WH04/0432/0123245/G0590488/00005?blt=06&prst=&shdMod=
Jan 18, 2011 | GE JE1860 Microwave Oven
Microwave not working after it ran without food in it.
try unplugging the microwave for a while then plug it back in.
Aug 29, 2009 | GE JE1860 Microwave Oven
How do I replace the magnetron in my GE JE1860?
Considering the cost to have the microwave repaired: both labor and parts, it is more economical to purchase a new one unless it is still under warranty.
Jan 01, 2009 | GE JE1860 Microwave Oven
GE JE1860 Microwave is not heating
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Dec 16, 2008 | GE JE1860 Microwave Oven
faulty relay or solder joint on the power module, but a bad door switch is most common.
Nov 13, 2008 | GE JE1860 Microwave Oven
Microwave Ovens Logo
210 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
