Question about Mitsubishi WS-55908 55" Rear Projection Television
Unable to access menu button. Need to adjust video cable to go from 480 to 1080--have new box and can't get into menu
  • Anonymous May 08, 2009
    same thing cannot enter menu screen
  • 293 Answers
Why doesn't it work?
You may need to purchase an original remote controller and then take it out of Hotel Mode to allow adjustment.
Jul 31, 2017 | Televison & Video
Cannot switch the wii to 480p
Go to the menu setting on the tv and select video , then standard, then select the pixel resolution. 480,1080, etc. Select 480, and hit enter. The tv will adjust the picture quality. Hope this helps.
Jun 01, 2014 | Nintendo Wii Console
Cinevision rv 4000 locked
Unable to access all TV channels from my cable box
  1. You can only tune in to your cable channels on Channel 3 and you may have to use the remote for your cable box to select program channels.
Viewing resolution is poor in dim movie/TV scenes
  1. Apart from the RCA connections, try to disconnect any other video output cable from the connectors (e.g. S-Video) on the DVD player; or/and
  2. If there are other RCA inputs on the TV, you may try to connect the video and audio output to them.
Remote does not work
  1. Make sure no objects obstruct the line of sight between the remote and player.
  2. The remote may need new batteries.
Cannot enter menu selection
  1. Use the arrow keys to select option and then activate by pressing the Enter key.
Oct 30, 2013 | GoVideo Cinevision RV4000
2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Nov 09, 2010 | Samsung LN32A540 32 in. LCD HDTV
TV only works on HD stations
Your TV has an SD/ED component input and an HD component input. You are using the HD input. It can only accept HD signals. You need to correct the settings in you cable box. You need to "fix" the video output so that it converts everything to HD. If you have a motorola box, you can usually turn the box off and press the menu button to access the cable box setup menu. Set the 4:3 override to Stretch or Full. If you need more help with this, post back with more information: cable provider, cable box used. I hope this was of some assistance.
Mar 28, 2010 | Samsung DLP HL-P5663W 56" TV
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
When hooked directly to cable, I get a blue screen and sound. When hooked to Componet Video, S- Video, or Composit Video via a cable box, I get a picture and sound. Apex remote will not change sound or...
your cable box rf pass through may be turned off if you can access the menu of the cable box by turning it off and hittiing th emenu button on the cable box with tv on an scroll down to rf out if you need hael call your local cable company
Nov 19, 2009 | Apex Digital AVL2776 27 in. HD-Ready LCD...
Unable to turn CC off
the captions are on in the dvr cable box. you cable guy can emter the menu on the box and turn it off. Some boxes will allow you access by pushing the power button on the box while tv is on then immediately pushing the menu button but be careful.
Jan 08, 2009 | LG 37LP1D 37 in. LCD Television
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Mitsubishi WS-55908 55" Rear Projection Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
