Question about Panasonic DMR-E85H DVD Recorder
No power - can I recover the hard drive with my Windows PC?
My unit is dead.......started to be temperamental and going through the self check loop, but now will not power up at all.
I have home video of my son on the HDD - can I recover this by plugging the HDD unit into my PC and retrieving the data? If so - do I need some software to do this as I have no idea of the format the HDD data is in.
Thanks in advance
  • 2 more comments
  • davegreen197 Nov 27, 2008
    Hi leecom72,
    Thanks for such a quick response. I've removed the drive from the PVR and plugged into my pc. Device Manager says it's working properly, but it's not assigned a drive letter. Do you know how I can get it to do so? I'm using XP Home.
    Appreciate your assistance!
    I can assign it a letter, but when browsing to the disk, it asks me to format, which I obviously don't want to do.
  • davegreen197 Nov 28, 2008
    I see - can you recommend a data recovery programme?
  • drloughney Jan 10, 2009
    I fixed my DMR -E85H DVD recorder with the new capacitors but now I am frozen.  I saw advice to hook up the hard drive to a pc but how do you actually do that?
I just learned the hard way about the way the DMR-E85H manages the internal harddrive. The format information and the table of contents of all recorded video are stored on the unit, not on the HD. I tried the same thing - removed the HD and put it on the PC. Recognized the physical drive but found no partitions and said it was 100% unallocated. I tried a data recovery program (Nucleus Kernel for FAT and NTFS Demo) but it found no file information at all. I have a healthy E85 and a broken one (that I just bought hoping to fix it). I swapped HD's and formatted HD #2 on the healty unit - so I knew that HD was ok. When I put HD #1 back into the healthy unit, the unit immediately wanted to format it (I powered off at that point). By switching drives, the unit lost ALL information about the first drive. Then I put HD#2 back in and interestingly enough, even though it didn't ask to refomat it, the table of contents was gone (there was 1 program I had recorded to test it). So - if you get your unit repaired, it MAY retain the HD info and you will get your programs back. However, the repair may involve clearing the unit memory about your HD and in that case, your drive's data won't be recognized by the E85.
>>> now with all that said, MAYBE there is a data recovery utility somewhere that can extract the video data from the drive - did anything come of the reference to using a torrent client? I'd be curious to know as I still have my HD #1 with program info that the E85 can no longer see. I'd like more info if anyone has it on a powerful data extractor - but otherwise I hope this detail will be helpful. Shawn
Posted on Dec 10, 2008
You can recover videos from the HDD with a Hex Editor
but it's not easy and takes a lot of time to do.
http://www.avsforum.com/avs-vb/showthread.php?p=16070641
Posted on May 09, 2009
  • Panasonic Master
  • 4,806 Answers
Yes you can, the computer will pick the drive up as any normal HDD, all you have to do is search for the files you want and copy them
kind regards and don't forget to rate us please
Posted on Nov 27, 2008
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Nov 27, 2008
    right click on "my computer" and select "manage" then click on "disk management" choose the drive and assign it a letter, if it asks you to format the disk then exit and don't make any changes
    get back to me if this happends
    regards
  • Lee Hodgson
    thats correct, the computer probably doesn't recognise the file system and you have to use a data recovery programme
  • Lee Hodgson
    Lee Hodgson Nov 28, 2008
    do you use a torrent client?
I just bought a used computer to replace my current one, but when i try to start it it ask me to insert boot disk i inserted a microsoft disk and it starts and works ok but if i turn it off and take thisk...
The operating system (Windows probably) was deleted on the hard drive since it would not have belonged to you by license. You will have to install some OS to the hard drive either from Windows disks you already own or some Linux variant. Right now, the needed startup files are not present on the hard drive.
Feb 24, 2011 | Acer Aspire 5315 Notebook
Tip
How to Recover Deleted Files from Seagate Hard Drive in Windows XP?
Accidently delete important filesusing Shift+Delete keys in Windows XP? Can't get valued pictures back from therecycle bin after you emptied it? How to retrieve data from 'not recognized'hard drive and reconstruct inaccessible partition?
You'reLuck!Deleting or formatting won't make the data erased permanently.Thosedeleted data are still stored in the hard drive. They're just invisible orinaccessible.Only the FAT or NTFS table is erased (the information about wherethose data were saved), but the real data are still intact there in sectors ofthe hard drive.
So long as those deleted data are not overwritten by new data, it's highlypossible to recover them. The most effective way is to rely onsome data recovery program.
Tenorshare DataRecovery is a powerful data recovery program that can easily recover lost,damaged, formatted and accidently deleted data from your laptop or computerhard disk and all kinds of USB media drives.It can recover data afterdeeply scanning your hard drive to look for lost data you accidentally deletedor formatted.
This program is equipped with four critical modules:"deleterecovery", "format recovery", "partition recovery" and"raw recovery". It can recover data after deeply scanning yourstorage device to look for lost data due to drives crash, virus corruptedpartitions, system sabotage, physical damage etc.
It supports for almost all Windows systems like Windows XP,Windows7,Vista,2000,2003,NT and common file systems (FAT12, FAT16,FAT32 and NTFS).You can get ithere: http://www.any-data-recovery.com/index.htm
It can RecoverLost Data Due to
Accidental deleting
» "Shift + Delete" without backup
» "Delete All" when deleting useless files
» Cut files instead of copying and pressing"Cancle" button
» Emptying Recycle Bin after delection
Formatting
» "Media/Drive is not formatted would you liketo format now?"
Virus infection/attack
Unexpected power off
Others
» Factory setting of device
»System reinstalling but want to retrieve the oldfiles
» Inaccessible partition or drive
» Dead hard drive
» Losing files during transferring files fromstorage device to PC/laptop
» Pulling out card while the camera is on
» Removing out storage devices not in "saferemove the drive"
» Turning off the camera during a write process
Then,howto retrieve deleted files?
Withinfour steps, you can get back your data:
1.Select deleted recovery. It will take you a few minutes to scan your storagedevice;
2. heck the deleted datayou want to recover;
3.Select a path folder for the recovered files;
4.Click "OK" to finish recovery.
Onemore tip:
If the hard drive can't be detected(means can't showup in 'My Computer' as a drive letter like C: drive),you can try this way.Putthe hard drive in a zip-lock bag and put it in the freezer for 2-3 hours. Thenwhile it's still cold plug it into the computer.If it fails, you will have to go to a recoveryoffice but let's hope not because it will cost you a lot of money and whetherthey can recover the data or not is not guarantee.
Recover deleted files from hard drive in Windows XP
Recover deleted photos from SD card of Samsung digital camera
Recover deleted partition with data recovery program in Windows XP
Data recovery program for Windows XP to retrieve deleted files from Seagate external hard driveRetrieve data from Dell hard drive in Windows
on May 10, 2011 | Casio Parts Cash Register PC Desktop
On start up it blue screens. HD check gvies Return Code 7
The hard disk is dead. To recover some of your files from it just boot from a Linux Live-CD like   http:pclinuxos.com/  and copy whatever you can recover to a USB memory stick.
May 19, 2010 | Dell Dimension 3100 PC Desktop
Compaq 615 froze with no display and fan whirring.
1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
2. Shut down the computer if it is running.
3. Press the power button to turn on the computer.
4. Press f10 when the HP/Compaq logo displays.
5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
6. Select HDD Self-Test options .
7. Press enter to display a list of HDD/Self-Test options.
8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If test reports pass then perform installation of OS
else hard drive has gone bad
Apr 16, 2010 | Compaq Computers & Internet
I have a dimension 8400, I recently upgraded my graphics card. Followed the instructions, blew out the computer of dust bunnies, inserted the new card, tured on the power, machine went from start screen to...
check the power cable and ide/sata cable connecting the hard drive to the motherboard maybe they are just disconnected, if the unit is working properly before you cleaned it, or does the unit detect the hard drive and cd/dvd drive during power on self test, if yes then you do need to re install windows, if you do not have an xp cd then you just have to purchased a genuine copy if you want to troubleshoot it by your self, or just take to it to comp. tech save trouble and lost of your time
Nov 24, 2009 | Dell Dimension 8400 PC Desktop
Reboot is in a loop and c drive is corrupt
I had this same problem on a machine that was brought in for me to repair. After removing a lot of spyware, the machine started logging out immediately after logging on. Here's how I fixed it: First: I used the XP CD to boot to the recovery console("R" at the first prompt). From there, I ran chkdsk /r c: to fix problems on the hard drive. There were plenty. Second: I rebooted to the XP CD to repair the installation of Windows XP. Do not use the "R" Recovery Console this time. Instead go through as if you are going to reinstall afresh and when it detects the current installation, choose the option to repair it. That corrected the problem. It seemed to be an issue with errors on the hard drive related to corrupted user profiles because I could not log in with any account. Hope this helps.
May 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
HP pavilion laptop will not boot windows...IDE device not found
You usually get that message when the hard drive has crashed.
Try removing the hard drive from the unit, then reseat it back into place.
Hopefully it was just dislodged a little bit.
Let me know what happens.
Mar 02, 2009 | HP Pavilion zd8000 Notebook
Windows laptop won't boot -
Try pressing the F8 key at start up. This should take you to safe mode, from here you will be able to shut Windows down properly and reboot without the loss on any data except for what you were working on at the time of the power loss. If it won't let you do this and stays in the same loop, it could be that the hard drive crashed and needs replacing. I don't do data recovery from a dead hard drives, so I can't give you an estimate on that, but a hard drive replacement, system reload with drivers and updates will run anywhere from $150 up to $600 depending on what you want.
Jul 01, 2008 | Gateway MX6920 Notebook
DST Short Status Test (Error detected)
DST stands for Drive Self Test, it means your drive is failing.
I would get a new hard drive and USB enclosure, install new drive in laptop and install windows, then take the old drive and install it in the USB enclosure so you can connect to your laptop when windows is running and restore your files, assuming the drive is not completely dead.
thanks for rating
Jan 10, 2008 | Dell Inspiron 6000 Notebook
Panasonic DMR-E85H DVD Recorder Logo
1,087 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
