Question about Frigidaire FEB27S6DC / FEB27S7DC Electric Single Oven
Oven door will not open. Locked during baking noit cleaning?
    Sergeant:
  • 229 Answers
There should be a manual unlock along the top of the door. If not unplug from wall and wait a few it has gotten hot enough that it thinks it is in cleaning mode. After a bit it should reset. I hope your turkey isn't in there! Good Luck!
Posted on Nov 27, 2008
I went to clean my oven and it locked I pressed cancel the door opened but my oven doesn't work when I hit bake locked signal comes up what do I do
Your oven got locked by a hook that gets initiated when the "Clean" button\option is depressed. Even though you hit cancel and the door opened, it is possible the hook didn't completely recluse back into it's housing.
Might I suggest trying to hit clean and let it take it's course, and try to verify the unit DOES heat up during the cleaning process? This may be the only option you have without calling out for a service call.
I really hope this helps.
Aug 16, 2017 | Ovens
Oven door will not open after self-cleaning.
Can you please post make and model in comments?
Do you have a users guide?
Nov 25, 2015 | Ovens
Why is the oven stuck with a "Door Locked" error?
Just guessing but did you just use the clean cycle???? During clean, the oven temp gets high enough to trip the door lock safety thermostat. This is to keep owners from trying to open the door when oven is too hot from clean cycle. It sounds like that safety didn't reset to normal when it cooled off and therefore the door is still locked. With door locked you may need to get oven out of the wall and remove top cover to get to the lock system and thermostats. Make sure power is off before doing any of this.
May 02, 2015 | GE JKP30WMWW 27" Built-in Single Electric...
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
Hi.
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Regards.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I am trying to start my self clean and a minute after I hit start a beeping with this code appears: FSEI
Make sure that the door latch is completly locked and then try again. If it is locked and you are getting this code the door latch assembly is bad. The oven sensor would be fine since you get no codes during normal baking. Problem is in door lock system
Feb 28, 2010 | Whirlpool RBS275PD Electric Single Oven
Oven door is locked and won't open
oven door locked during cleaning then would not unlock after cooling
Jan 19, 2010 | GE JKP86 Electric Double Oven
When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven locked door light on but not, won't bake
Check your breakers and also your wiring. Try to turn off the breakers for about 10-15 seconds. Your board inside the control panel may be bad since you are getting mixed signals.
Jan 12, 2009 | Kenmore 47783 Electric Single Oven
How can i quit cleaning oven?
During the self clean cycle, oven temp will exceed 900 degrees F. At these temps, if you opened the door, the food inside would immediately catch on fire when the supply of oxygen hit it. When you turn your self clean cycle off, the oven door will remain locked until the internal temp drop below aprox. 550 degrees F for your safety. Once the oven cool below this temp, you will be able to start using the bake or broil again. This should be a Fix-Ya for your oven.
Dec 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven locked
Hello dktshopping,
I know you probable don't want to hear this but in you circumstance, I think you would be better off to contact a repair professional. Those oven door locks are meant to keep the door from opening during the oven's self-cleaning cycle. They are both mechanically and temperature controlled so that the door can not be opened when the oven is 950 degrees. It sounds to me as though something is not releasing to allowing the locking mechanisim to disengage from the door even though the lever is in the unlock position. The unit will probably have to be taken apaprt to remedy the problem. Good luck.
Nov 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Open Questions:
Frigidaire FEB27S6DC / FEB27S7DC Electric Single Oven Logo
93 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
