Question about MSI Wireless-G RG54G3 Router
Configuring i have really slow download speed (no mre than 20kbs),someone suggested the problem is caused by my router not being configured correctly and something called "port forwarding" i dont know where to start with either of these. would appreciate any advice.
    President:
  • 2,961 Answers
When you say download speed, are you using a peer to peer programme, in which case you will need to open a port, or are the download speeds related to general file downloads and what speed broadband do you have?
Posted on Feb 14, 2007
Cannot connect to 192.168.0.1
How you connect to the router configuration page is depended upon how you have your router management configured. I believe by default belkin routers allow for remote configuration so if you didn't configure any security on your router someone may have altered your configuration.
The default method for configuring your router requires.
  • An ethernet cable plugged from your computer to a LAN port on the router
  • The correct Gateway address (Start > Run > Type "CMD" at the command prompt type "ipconfig" look at your gateway address
  • In a web browser type in http://192.168.0.1 in this example
If you still can't access it I'd suggest pressing the reset button on the back of the router and re-configure the router in case of tampering.
Comment if you need any further assistance
Oct 27, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
My down load is very slow
Hi,just check your speed from here http://www.scanmyspeed.com/ and if still your speed continues to be slow contact your provider.
Mar 08, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Brand new router - ISP all sorted but for some reason the red light regularly comes on and stops the router working. Only option is to keep rebooting which is realy annoying. Also For a N300 router...
ok Let help you with this I have the solution of your problems but I need more Information like
  1. ISP name
  2. Modem Brand
  3. how many PC's you want to connect and what is the operating system XP,VISTA,W7 or Mac.
  4. let me know the Model Number of your N300 router and also the adapter is in the bottom of your router starting with F5D or F^6D or F7D ok ?
Hard reset your router and after that update your last firmware version that will make all for you easy you will get that on Belkin support web site download that and safe in to your desktop after that update your firm ware and make a manually configuration.
Manual Configuration open Internet Explorer and erase the bar address http://xxxxxxx and type 192.168.2.1 after that you will see the setup page and ready to configure your router Belkin for all what you want .
let me know any update for this issue Im very interesting to solve this.
you can ask me a remote your PC to configure your router ..rating me good luck
Oct 29, 2010 | Belkin Wireless Surf Router (F7D2301)
I am having slow connection speeds. I called my
check your configuration on your PC, see if it is pointing on a DNS that was previously identified. Make sure it is in automatic. also check your router as well as the signal strength. I suggest don't use the router and directly connect your computer to the internet connection just to check the speed and compare. if it is ok then your router is your problem. check its configuration and set it properly.
Jun 20, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
How to configure ports on my modem
U will have to learn port forwarding.............u didn't mention router ur using since differnt router have different settings.......goto http://192.168.1.1 and search for port forwarding settings. Me too had this prob before port forwarding speed 15~20Kbps download and after 197~208Kbps.
Good luck with port forwarding.
Jan 18, 2009 | Computers & Internet
Netopia routers2247NWG/slow download speed/
Actually the application may be games or any other software which it setted port is not open/accessable through your router and it will work by default ports and the speed or the performance is very slow- Try to configure proper port forwarding according to the application port settings check those ports are open after configuration
Hothawk
Jul 14, 2008 | Computers & Internet
After installing netgear router and wg111v2 it has slowed my pc down laptop fine tho? can you help pc is the main home pc and laptop is seconary?
Dear Customer,
Yes It will happen,cause of protocols handling on router with your main pc,
SO,try to use another higher configured pc or you can use server like pc,
Never try to handle router on lower configured pc ,its affect on you r work ,its defanetly very slow-down you work,
SO try my solution you will get more speed,
THNX
May 22, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Router and configuration settings for DSL wireless setup
Maybe you should use same brand of your adapter, use belkin wireless router.
Most of the router has a manual attachment, it will teach you how to configure the router..
Nov 16, 2007 | Computers & Internet
MSI Wireless-G RG54G3 Router Logo
112 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
