I have a Panasonic TH37px808.The thing just started spontaneously shutting off and the red power light on the front of the unit just blinks . I have satellite TV so I thought it was my DVR receiver and I had the satellite co send me a new receiver for that and I set that all up only to have the damn thing repeat its power issues. Do you have any clue as to where to begin? Thank you so much for your time and assistance
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
  • 1694 Answers
SOURCE: panasonic PT 47WX53G
Replace STK392-110 IC's ( both ) with PANASONIC part
# C5AA00000203.........DO NOT use generic IC's !
Posted on Aug 12, 2008
  • 2326 Answers
SOURCE: Sony KDF-50WE655 won't turn on.
if your TV blinks 10 times. Possible solution should be to check and replace on the G1 board Q1600 and Q1601 if shorted and R1614 and diode D1605 open.
Posted on Oct 20, 2008
  • 8617 Answers
SOURCE: My Panasonic tv pt53wx53g wont turn on it blinks 3 red lights
The 3 blinks is a error code for the convergence circuit. You can get the convergence repair kit for your model at the following link which contains both Convergence ICs and all six feed resistors and they include step by step instructions with pictures that show how to do the repair yourself. Heres a link to the proper kit for your model Panasonic.
Posted on Jan 24, 2009
  • 326 Answers
SOURCE: Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Posted on Jan 31, 2009
Panasonic 46" Plasma hDTV power light keeps excess of 60 times. Power comes on then shuts down again then the red light blinks. I changed the power board and the same thing happens.
Hello, If you will look the power light blinks in a pattern. depending on the model number it has either a bad "SS" or "SN" board in it, it's the board on the right side looking from the back. This is a common issue with these sets....tks
Dec 31, 2014 | Panasonic Televison & Video
There is a blinking red light next to power button.Panasonic tv will not turn on.
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Hopefully it eventually stops blinking after unplugging set from the outlet, otherwise claim your Nobel Prize for wireless energy transmission.
Oct 17, 2014 | Panasonic Viera TH-50PZ80U Plasma TV
Hi, Approximately eighteen months ago, I purchased a 42 inch plasma Panasonic television model number: TH-42pz77u) but Saturday night, the television turn off and have five blinking red lights. Then we...
The 5 blinks on the LED means that the main logic D board is defective and will need to be replace to fix the TV.
Check this site to find replacement parts to fix your plasma if you intend to DIY.
Let me know if you need further assistance.
Jan 15, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Tv wont turn on< red power light just keeps blinking?
I have the same thing. Just started blinking 10 times. Pretty much had to unplug the unit over night. Could never turn it off and then turn it on again.
This worked for about a week. This morning, tried to turn it on after being unplugged. Still blinks.
Called Panasonic. they attempted a couple solutions, nothing. Suggested authorized repair shop.
Aug 20, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Orange and red light blinking after one minite
I fixed this problem by disassembling the panels. On the front then sides then back of the unit. The first thing I noticed was some debris in the exhaust fan wheel on the back side. I used some long wood skewer to fish out the debris and even shook the unit upside down. (It's very heavy and would recommend help with shaking the unit.) Also, I think i found a little sensor that is about the size of a thumb drive and incased in a transparent plastic box. I tapped it with my finger and noticed this little black thing bounce up and down inside under the green circuit board. its located right above the drain connection. I didn't do anything else with this. I assumed its the sensor to measure the water buildup. I also found a small toy in the front fan wheel that blows the cool air through the top of the unit. fell out during the shake down. The final thing I noticed was when re-assembling the unit. On the front side you will see the two metal radiator looking panels. Between the two panels is a wire sensor that looks like a temperature measuring device. I had noticed it was touching the metal part of the radiator panel so I gently streightened it out so that it was parallel with the panels and not touching. I pressed the power button and it hasn't shut of yet. I snapped the front panel back on and all is good.
I have the white upright sharp AC unit with the three lights in the front and a power button next to the IR sensor. I lost the remote control and couldn't figured out why the unit would start up then shut down after a minute of use. The operation light would blink red then the orange timer light would blink next. Then both lights would blink simultaneously, then repeat. I thought this was a timer setting. but the unit is supposed to reset after disconnected from the power.
Sep 30, 2009 | Sharp Heating & Cooling
1 yr old panasonic th-50pz700u shut off spontaneously and won't turn back on . red light blinks 8 yimes and repeats
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit).
This has to be replaced, call Panasonic and if you still have warranty you can get it replaced for free.
Jun 03, 2009 | Panasonic (TH-50PZ700U) Television
Tv will not power up Panasonic PT-50LC14
ok guy's i have the same tv and simular problems, first check the lamp light located next to the sd disk input (on the front). if it's not blinking then 2 things 1) more than likely it's the lamp if you haven't replaced it by now your one of the lucky ones, you can find them online for around $100, in which i paid over $300 for two differnt bulbs. the warrent only covers 1 bulb. 2) this happens to me once in a while try unplugging it let it set for a minute or two, replug it back in and try it again. but it depends if the light shines yellow (orange) and blinks twice, then try it again. you kinda have it cycle through and that should work. if not then unplug the unit, then take off the front cover and use a philips screwdriver remover the bulb (located behind the cover in the front) then i highly recomend doing this on a weekend pull out the shop vac and **** out the dust inside the lamp housing, then take off the back housing along with the left side speaker and first clean it out with a rag, then go through it with the shop vac. basically if dust builds up the unit will trap the heat and that it's why it will overheat and shut down.
Mar 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Power problem
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Sep 16, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Tv shuts off spontaneously. red power light blinks.
re: sony flat panel lcd tv mod. # klv s 40a10.
No power. When power button is pressed, nothing happens.
The stand-by at the power supply ( cn6201) measures to be 3.47 v. instead of 5 v. However, when I unplug cn6201 (5 pin connector) I can read 5v. at the power supply.
Any suggestions?
Jan 23, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
