Question about Dell Inspiron 2200 Notebook
When using the keyboard on b2200,keys are incorrect,tbrings t4
When using the keyboard and striking "t", a "t4" comes up,,,,when using caps lock a "4 " comes up, but if I continue holding down the button the T works normally and when hitting "caps lock" it switches from caps to lower case.
  • bustem Nov 30, 2008
    i have tried that and it seems to make no difference,but i have found out that by turning off then on seems to work for a while. Also, is it possible that the keyboard underneath is dirty or that there are some key setups that have made it change?
  • twoup265 Jan 25, 2009
    I have the same problem with a Dell Vostro 1500 laptop. this has started in the last two days and I have noticed that it disappears when the computer is turned off and then started againg and the problem starts again after hibernating.
  • 50 Answers
I have had this problem before the keyboard in this model does this ofter dirt and crumbs have gotten into the keyboard. For me the laptop was under warranty and had the keyboard replaced. most-likely you will have to replace the keyboard. You can try to remove the keyboard from the laptop, hold the keyboard upside down and using a can of air to blow out the dirt.
Posted on Dec 07, 2008
  • 93 Answers
Try "Num Lock" key.
Posted on Nov 27, 2008
  • Chester Harvards
    Chester Harvards Nov 30, 2008
    If you hold the "Shift" key for such long, it will cause some similar problem when you type words in the document.
    Otherwise you have to update BIOS from Dell web.
Sony Vaio keyboard repeating letters
Keyboards to wear out, but are not expensive to replace. Multiple key strikes and sticking can be caused by spilling "stuff" into the keyboard, even crumbs will do it.
Oct 29, 2015 | Sony VAIO Computers & Internet
How to use number keyboard
You use the number pad as follows: your index middle and ring finger rest on the 4, 5, and 6 keys. The index finger reaches up or down to use the 7, 4, 1 keys. The middle finger uses the 8, 5, 2 keys. And the ring finger uses the 9, 6, 3 keys. And the thumb is for the 0.
Jun 18, 2011 | Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
Caps lock and num lock keyboard lights do not come on
If the "Caps Lock" and "Num Lock" keyboard lights do not come on, then press "Scrol Lock" bottom. If the light still not glow then you need to change the key board.
Aug 14, 2009 | Computers & Internet
Meaning of indicator lights on wireless receiver
I concur 2/3's with yooperbud.
1 = System is connected and working
A = Cap locks On= Cap lock is on. Off = Cap lock is off.
F = Function Key usage. On = I'm going to use the alternative fuctions of the F keys as programmed in the Keyboard settings. Off = Your using the standard features of the F keys.
Dec 31, 2008 | Microsoft Wireless Optical Mouse USB...
Ms keyboard 4000
With the new keyboards they don't use lights to indicate what is on or off. While pressing the Caps Lock key , look at the right lower side of your monitor and it will show Caps Lock ON or Caps Lock OFF. Just have to get use to looking at the monitor. Bud
Apr 28, 2008 | Microsoft Computers & Internet
My keyboard
yaa bcoz you have made your Numlock On thats why keyboard gives you these characters. You can see a led 'on' on your keyboard near Num Lock.
To make it off press and hold Fn kye (left side bottom row of the keboard) and press Num Lock kye (Top row right side). It will make your Num Lock on/off.
Thanks
Iqbal
Apr 12, 2008 | IBM ThinkPad T30 2366 Notebook
Toshiba Equium Laptop Keyboard Problem
Yo, I think I got this one.
Someone brought this model of laptop to me and the keyboard and mouse were shot. Totally unresponsive. So I downloaded the driver found here
http://support1.toshiba-tro.de/tedd-files2/0/butsu-20070709123021.zip
which is described on the drivers section of the toshiba site here
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK&selCategory=2&selFamily=382&selSeries=173&selProduct=667&selShortMod=477&language=13&selOS=26&selType=all&yearupload=&monthupload=&dayupload=&useDate=null&mode=allMachines&search=&action=search&macId=&country=8&page=1&startPage=1&prevCl=true
to be the button support.
I did this all with a USB keyboard and mouse by the way.
OK, so now that I can actually use them, I start to test out the touchpad and keyboard and had the same problem all you lot did. I looked at the keys which were giving me greif and saw that they are all keys that had alternate settings when used with the function (fn) key. Turns out that there was a fn lock on the keyboard which I cleared by holding the fn key and pressing f11. This turned off a little LED just above the "9" key and voila, working laptop again.
To test if this is the problem with your laptop, press and hold down the "fn" key and press any of the keys which are coming up incorrectly. If while holding it down (cancelling out the lock, like how shift and caps lock work) the correct character appears on screen, then you too are suffering from funct-itis (tm)
Sep 03, 2007 | Computers & Internet
"Reprogrammed" keyboard
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then set up the Cap Lock key.
Hope this will help some. Bud
Feb 06, 2007 | Mitsumi (KFK-EA4XT/PS2) Keyboard
Dell Inspiron 2200 Notebook Logo
296 people viewed this question
Alun Cox
