Question about Kenmore Refrigerators
I have a Kenmore Side by Side white fridge with smooth doors. I am on my 2nd (3rd set coming) of doors and when they are delivered there are scratches where the cut the plastic covering around the handles and the Kenmore sign. Any ideas on how to get the scratches out?
    Sergeant:
  • 229 Answers
Dang I would scream if they did this. There used to be professional appliance painters that could redo these like body work the best ones I hear were like artists because it is so hard to match up white. I suggest that you tell them they can keep sending new ones until they stop damaging. Good Luck
Posted on Nov 27, 2008
Just got delivered a new kenmore french door fridge and temp. on freezer is zero. it doesn,t say what temp to put it on
Usually 0 is the warmest setting 1,2,3,4,5 would be increasing to coldest level with 5 as coldest
Jan 04, 2015 | Kenmore Refrigerators
I am getting little white pieces of something in my melted ice from my kenmore in door ice maker. Nothing in the water though. What can this be and is it harmful? How can I fix this? The fridge is 4 m
This is the calcium minerals in your water. They are forming on the inside of your ice maker and then the deposits are setting up in your ice. You are also getting this in your water, but the deposits do not stick together so you do not easily see them. You can remove the ice maker and clean in a vinegar solution to break down the minerals. This will be an ongoing issue, but at least you can manage it and it is not harmful.
Jan 13, 2014 | Kenmore Refrigerators
My vespa px 125 runs smoothly in 1st,2nd,3rd gear but shudders in 4th,does this sound major or easily fixed
Doesn't sound too serious. Sounds like a problem with your carb not delivering enough petrol or air. Get a decent garage to check it out.
Apr 15, 2011 | Peg Perego Vespa Scooter
The chute from the ice cube tray that delivers cubes to you glass keeps clogging up with frost. jocko
this a kenmore made by whirlpool. u need to buy new door chute assembly. Not easy to do if you haven't worked on fridge, best to call an expert to replace it for you.
Oct 31, 2009 | Kenmore 57029 Side by Side Refrigerator
My 2002 Hyundai Accent goes into 1 gear smoothly, jerks into 2nd and goes into 3rd gear smoothly. Then goes back down into 3rd and 2nd gears smoothly and jerks back into 1st.
CHECK ENGINE light??? Whenever the 'CHECK ENGINE' (Service Engine Soon) light comes on, the ECU (Engine Control Unit) sets a Diagnostic Trouble Code (DTC). These codes identify the particular engine management system which caused the light to come on.
You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code which have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE the problem and perhaps eventually fix the problem.
Oct 01, 2009 | 2002 Hyundai Accent
Water and ice won't work on kenmore side by side fridge
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Mar 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Switching doors to open the opposite direction
Look on the other side of the door and see if there's a plug covering a hole even with where the door handle attaches on the opposite side. If so, I think you just unscrew the handle from the top of the fridge door or bottom of the freezer door an unhook the other end and reattach on the other side of the door. And unscrew and move the hinge to the opposite side. If your doors can be reversed the holes should arleady be in place. It didn't look overly difficult when the delivery guy changed mine when the fridge was delivered.
Nov 24, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Friction between the doors
look at the hinge on the top of the freezer door, unloosen the bolts that's holding the bracket, move the door a little bit to the left then tighten the bolts again. that should solve your problem.
Feb 18, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
70 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
