Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Water won't dispense
The ice dispenser of my Maytag refrigerator is working fine, but the water dispenser won't dispense a drop of water!  The water pipe seems to be filling up ok, so what else could be the problem?
  • 10 more comments
  • malteses7 Dec 01, 2008
    Maytag Model MZ02766GEW side by side. Ice works fine but water takes 15 minutes to pour. I've changed the filter 2X. All the lights are working fine. Problem started after the house water was turn off for a week and house water meter was changed.
    Maytag Model MZ02766GEW side by side. The ice works fine but the water takes 15 minutes to start pouring. I've changed the filter twice. The problem started after the house water was turn off for a week and the house water meter was changed. All the lights are working fine.
    I have change the filter 2 times (new filters). The water takes 15 minutes to pour so water is coming to the filter.
    I have holding a container for 15 minutes for the water to pour.  Once started pouring I have collected several gallons of water to release any possible air in the line.  The problem was not solved.  Once I stopped collecting water.  I tried to collect water an hour later and again it took 15 minutes to start pouring.  I have done this several times but the problem is still there.
    I strongly appreciate your kind attention to help me to solve this problem. I am going to check your solution. Could you please help me to decide if it is the Solenoid or the pump. Once the water start pouring I can collect as much water as several gallons with no problem but an hour later it takes 15 minutes to start pouring again.
    We check the water pressure and it seems to be fine according to the Orange County Utilities.
  • Anonymous Mar 11, 2014
    led lcd asha 201 not working,but the keypad lights are working
    2005 pt cruiser clutch replacement
    Have erased DSN settings and now Internet won't work. Don't know what settings were
    I need to lower the spare tire, where is the tool to do that
    afunta mini clip mp3 player won't play
  • Anonymous Mar 12, 2014
    i can smell coolant but it leaks down the firewall from black box on passenger side where heater hose and ac lines go in
    Genius:
  • 2,035 Answers
Flush air from the water system the first time it is used and after replacing the filter. Air trapped in the water line or filter may slowly travel through the coiled water reservoir or water tank to the dispenser, and push any water ahead of it. This can cause the dispenser to drip. Water needs to completely fill the lines for all air to be cleared.
  • Use a sturdy container to press and hold the water dispenser bar for 5 seconds, then release it for 5 seconds. Repeat until the water begins to flow. Once the water begins to flow, continue to press and release the dispenser bar (5 seconds on, 5 seconds off) for an additional 2 minutes. Repeat if dripping starts again because air can re-enter from the water supply.
  • As air is cleared from the system, water may spurt from the water dispenser.
  • Be sure the refrigerator is connected to a cold water source.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after the dispenser lever is released.
Posted on Dec 01, 2008
    Novelist:
  • 157 Answers
You could have a clogged filter or frozen filter. If you have a filter in the unit, remove it and put in the filter bypass plug that came with the unit. If you do not have the plug, remove the filter and while holding the frig door switch closed (has to be closed to send power to the valves) have someone call for water and see if water comes out of the line feeding the filter. If this does not prove one way or another what is going on, do you have a voltage meter we can do a quick test with?
    Master:
  • 505 Answers
Make sure the TAP and the filter is working properly. Get the tap checked. Also make sure the LED light is lit up.
Thanks
  • Indrajit Roy
    Indrajit Roy Dec 01, 2008
    i would request you to check the water pressure and also the source.
  • Maytag Master
  • 19,396 Answers
If water is to the valve then the valve is not opening.
When this happens you usually have to replace the solenoid that activates the valve.
Try first unplugging the fridge power cord for ten minutes.
If the valve is still stuck, the water dispenser solenoid must be tested and eventually replaced.
  • Ginko
    Ginko Dec 01, 2008
    If he problem started after the house water was turn off, and the house water meter was change, check pressure at water spply first.
    If water was cut for one week, and the water dispenser kept working with no water, then this is probably a faulty pump.
    Check all the lines if lines are not clogged, pump pressure is not sufficient, replace pump assembly.
    You find parts and diagrams here.
Where do I find the ice maker inlet water valve or solenoid? The valve on the back of my fridge has only one hose going to both the water dispenser and ice maker and the water dispenser works fine.
Since there is water that flows to the water dispenser, the water valve is working. Now, there's a spout that water flows from to the icemaker tray. Look for it. It's located on the back wall inside the freezer and maybe behind the icemaker tray. Check and see if it's frozen. If so, defrost your freezer by turning the temperature gauge to off position. Wait a while until it's defrosted, then turn it back on.
Next, make sure that the metal wire is in down position.
If that doesn't work, your icemaker maybe defective and needs replacement.
Nov 01, 2014 | Maytag MFI2665XEM Stainless Steel
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Apr 09, 2009 | Maytag MFI2568AE Side by Side French Door...
No water coming from dispenser on Maytag MZD2766GE
You should defrost the freezer. The water line coming into the freezer is frozen and the water can't get through the little tubing.
Feb 01, 2009 | Maytag MZD2766GES Side by Side...
Ice maker working fine - Water dispenser nto doing anything
hi there,
sounds like the water valve may be the culprit.
can you provide the model # off your fridge please?
Sep 21, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Dispenser not responding
On mzd2766 there is a solonoid type switch that goes bad. Could be your problem too.
Aug 16, 2007 | Maytag MSD2754G Side by Side Refrigerator
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
340 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
