Question about Panasonic KX-T7630 Corded Phone
Programming new numbers into kx t7630
Hi i would like some help to programme a new number onto an extension button. how would i do this??
  • 1mbaker Apr 08, 2009
    What happens if you press PROG and nothing happens. It used to work just like it says above, but now, 2 phones in the office are unable to program because nothing happens.
  • Anonymous Mar 17, 2014
    how to change internal extension number on DT300 programmable buttons
  • Panasonic Master
  • 2,460 Answers
If it's going to be an extension press PROG dial 1 and the ext number and ENTER
If you're trying to put an outside number on it, press PROG dial 2 then 9 + number and ENTER
Carl
Posted on Nov 27, 2008
  • Carl Navarro
    Carl Navarro Dec 03, 2008
    Oops, the step I missed is PROG press the BUTTON to program then 1 or 2.
How do I connect a background music source to Panasonic KX-T7630 phones?
The Music On Hold (MOH) is not connected on the KX-T7630 Phone but rather to the phone system. You will need to get an extension from the phone system and connect it to the KX-TVM50/200 Voice Processing System (VPS). Incoming calls are then answered by the extension connected to the VPS ... i sugest you get a Tech to help you with setup or get an online programmer to guide you on hardware setup and he does the programming for you.
May 27, 2014 | Panasonic KX-T7630 Corded Phone
How do I set Direct Station Buttons
From the idle phone, press PROG a button and dial 1 + ext number ENTER. You can keep pressing buttons and dialing extensions or press EXIT to end programming.
Carl
Apr 19, 2011 | Panasonic KX-T7630 Corded Phone
How to change extension name in panasonic kx-t7633
depending on programming restrictions:
at ext 101
1) press "PROG"
2) "**"
3) the user programming password (most likely "1234")
4) "004"
5) "ENTER"
6) enter the extension number you wish to change
7) txt out the name (you must use the direction pad in the bottom right corner of your phone if you have 2 letters in a row that are on the same key)
8) press the "AUTO DIAL/STORE" button
9) lift hand set and hang up
Jan 06, 2011 | Panasonic KX-T7630 Corded Phone
How do i customize a call button to a number?
What number? You have 24 buttons. You can store inside numbers under a button by pressing PROGRAM the button and dial 1 + the extension number and ENTER or STORE.
Outside numbers depend on what you dial to get an outside line (usually 9). In that case, press PROG button 9+your outside number and ENTER or STORE.
Press EXIT to leave programming.
Carl
Sep 30, 2010 | Panasonic KX-T7630 Corded Phone
How can i change the extension numbers and names on kx-t7630
It requires access to system programs 003 and 004. That can be done from the extension authorized for programming, usually extension 101. There is no "swap" command and we usually move the hardware at the frame rather than in software, but you can do it if you find a vacant number. An example would be to swap 102 and 108 you make 102 some other extension, like 402, then make 108 102 and then 402 108. Yeah. Sure.
Anyway, the user's guide (UG) for your specific system (not the phone) has instructions for the System Manager that details how to program Extensions and Names.
Carl
Aug 26, 2010 | Panasonic KX-T7630 Corded Phone
When I try to hook a second kx-t7630 to another (parallel) I can make outgoing calls but cannot answer them.
I'm guessing you're using the Digital XDP port. Each of the phones has an extension and that 2nd extension number has to be added to the ICD group as a phone for the lines to blink or ring on the 2nd phone.
It requires system programming.
Carl
Sep 24, 2009 | Panasonic KX-T7630 Corded Phone
I attached one t7630 to another (parallel). The
Parallel is just a method of connecting phones. It has its own set of programming, both extension number, class of service, and ringing.
If you have access to system programming, you can add this phone to an ICD group with the other extensions. If not, you'll have to get in touch with your installer/dealer to make the changes.
Carl
How do I programme numbers into the KX-T7730
hi kim
if u mean how to store a phone number on a Flexible button, her is the way:
1. Press Program button to be on Programming mode.
2. Press the desired Flexible button you wish to assign as a One-Touch Dialing button.
3. Dial 2.
3. Enter the desired number (extension number, phone number, etc.).
4. Press STORE.
Ali
Aug 25, 2009 | Panasonic KX-T7730 Corded Phone
Switching phone to night mode on dfferent number
If you can dial *7801 on the intercom from your phone and it puts the system in night mode, then you can program a button to do the same. It would be better if you go to the original phone where the buttons worked and read them (PROG press the button and write down what it says).
Now go to your phone, press PROG the same button and dial the code you wrote down. In the simplest, you put 593 ENTER for DAY/NIGHT. Then PROG to exit. If you want more options, then 59x can be 0 for DAY/NIGHT/LUNCH/BREAK 1 for D/N/B 2 for D/N/L.
Every time you press the button, it will toggle to a different setting and the display will show it.
Carl
Nov 13, 2008 | Panasonic KX-T7630 Corded Phone
Kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button 2. Then dial ** (star, star) 3. Enter the password (usually 1234) 4. Press 'Next' until you get to 'Ext Name' 5. Press 'Enter' 6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is) 7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters. 8. Press 'Enter' then you are all done... pick and hang up the handset.
Feb 11, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
378 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
