Question about Philips 23PF9945-37 23" Flat Panel LCD Monitor
Distorted screen colour
I have a Philips flat TV HD monitor (used mostly as a computer screen), model number 23PF9966/37. I was online a few days ago when the power went out. It came back on a few minutes later but my screen had this weird greenish tint to it; the computer itself works fine but the colour is completely off. I already tried unplugging and plugging wires and cables, rebooting my computer and adjusting the screen settings. Any ideas of what this could be and how to fix it?
4 Suggested Answers
  • 10 Answers
SOURCE: monitor power problem
It sounds like an internal issue, more likely the LOPT components are overheating, possibily due to dust collection causing temporary shorts, or an arcing capacitor. The randomness is due to weather conditions, high humidity more likely to monitor wil shut down, the dryer the weather the moisture in the dust would have evaporated, resulting in nothing happening, and a working monitor. I suggest trying this first:- Unplug the monitor from the outlet, and the computer, open the case, but REMEMBER! the monitor can still pack a punch even when it's unplugged from the outlet, (once the case is open, it is completely safe if you accidently brush against a metal part, but under no circumstances (unless you know what you're doing) remove the rubber cap that's either on the top, bottom, or sides of the back of the screen, doing so can result in a massive jolt of up to 20,000 volts),use a can of compressed air to blow out the dust, making sure you clean right up to the control buttons on the front, screw the case back in place, then try the monitor, if it's still the same, and unless you are a qualified electronics engineer and would like to repair the monitor yourself, I suggest you take it to a repair shop.
Posted on Jun 18, 2007
  • 2229 Answers
SOURCE: Power light is green but screen is black
Do you get anything at all on the screen--like white writing at startup?
Even if your video drivers have become corrupt, they are not used until Windows actually starts.
It very well could be the flourescent backlight has gone bad. Can you adjust the brightness/contrast at all to see anything?
If those controls do nothing for you, then you're looking to get a new monitor.
Your monitor does have a sort of power supply for the backlight and that could be bad, but if you're not into taking it apart, then you are far better off buying a new monitor.
Posted on May 27, 2009
  • 338 Answers
SOURCE: philips brilliance 200w monitor no video
nice anecdote, fixing things from far is not easy, a t.v.-technician right in front of the actual screen could tell more- but they don't come for free, alas. hope that people's idea about problem solving lead up to you fixing a problem yourself - hey this here is for free - to sort wxperts, one needs feedback! thx alot
Posted on Jul 23, 2009
  • 732 Answers
SOURCE: Power problem with LG L204WT Flatron
unique_m_m, Your LG l204WT has a possible bad "switch-mode-power-supply"/"CCFL inverter circuit" that will need to be repaired. The sound that you hear can only come from the circuits mentioned. The SMPS supplies dc voltage to the INVERTER supply and it changes it to a high voltage ac to light-up the "cold-cathode-fluorescent-lamps" (2) that are hung on the reverse side of the lcd panel you look at. You will need a tech type to investigate the units SMPS/inverter board for bad (swollen,leaky) electrolytic filter capacitors and "cold, frosty looking solder joints of the surface and through hole mounted electronic parts soldered to the circuit board. Here is cost to repair. DIY if handy with soldering pencil would be less than $20. Farm out the repair $35 to $65
More if new replacement board is required. I would certainly get on PHILLIPS case and yell and scream about their product's poor quality and short lifespan. Let us know if they give you the "bird"and a "you bought it you own it toyota" attitude. A service life of only two years is totally unacceptable! You could ask phillips if they have a refurbished unit swapout program?? Let us know what happens by doing additional comments to original posting. Bye for now. 12fixlouie
Posted on Jan 31, 2010
0 characters
1 Points
Flicking panel on side of picture
Is a problem with the tcon board - change it and will turn on good conditions.
Good Luck!
Mar 23, 2014 | Sony BRAVIA KDL-46V5500 FULL HD...
Damaged LCD Controller V420H1-C07
not possible has to be the model of your TV, but if the technician knows how to do the programming of memory T with possibly can modify the data that requires your tv or investigate whether your model is compactible with was installed, ie inches has and the number of panel this will help to know if you can installDeshacer cambiosThis language is still in early stages of development and not yet up to the same quality standards as our other languages.">Alpha
Sep 28, 2012 | Insignia Tv Lcd Controller P/n V420h1-c07
Philips low contrast crt
tried to adjust in the screen menu set up adjustment, just let me know if can not get with adjustment.
Jul 18, 2012 | Computer Monitors
Brand new Hannspree 28" tv when you switch it on screen just changes colour white to red all colours and nothing else
Get rid of this model!!!! The Hannspree and Toshiba models used a TFT LCD screen from a chinese manufacturer that has put out faulty components for the last 3 years. The Problem is in the way the Active Matrix Screen was manufactured. I would recommend you return this item immediately to the place where you purchased it and pick a different brand; also stay away from Westinghouse!
Sep 24, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Black screen
Hopefully, she registered it with Westinghouse. Call their tech support.
maybe a transaction printout from her bank account will suffice.
Mar 03, 2009 | Westinghouse 25.5" Widescreen Flat Panel...
Philips tv
Your description is really very vague...
Off colour is usually attributed to the picture tube (CRT) getting weak, and the internal automatic bias control can no longer track the emission of the electron-guns in the CRT to compensate for the bias current change with age and use.
It is possible to have some components failing in the CRT drive and bias circuits, but this is rare in these monitors.
I hope you didn't pay very much for this monitor when buying it used.
I would seriously consider a new LCD monitor. Most of these will give at least 3 years of service with full time use.
Jerry G.
May 18, 2008 | Computer Monitors
Connection cords for Acer flat screen monitor
You would need a 15 pin HD D-Sub cable with appropriate connectors model number HD-15. Pls try here or here to view similar products.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Dec 03, 2007 | Acer AL1714 17" LCD Monitor
Screen patch
Sometimes lcds will turn a yellow/brown/redish colour if they overheat. normally this will not cause long term damage to the screen but it is not good for it, try letting the monitor cool then using commpressed air to get rid of dust or attach a small fan to see if it helps. This may not fix the problem but should confirm if thats what it is.
Oct 30, 2006 | Samsung 997DF 19" CRT Monitor
Philips 23PF9945-37 23" Flat Panel LCD Monitor Logo
Top Philips Computer Monitors Experts
 Mike M
Mike M
Lawrence Oravetz
olayoju victor
Are you a Philips Computer Monitor Expert? Answer questions, earn points and help others
