Question about Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV
Perfect picture but no sound
My tv has a perfect picture but ther's no sound from the tv speakers at all. However the sound works on the dvd and the video. What could be the problem?The tv speakers are on on the menu. Have you got any other solution?
    Novelist:
  • 192 Answers
More than likely the problem is the audio is set in the SAP (Second Audio Program) mode. You can search the audio section of the menu, usually in the MTS part of it. There might be a button on the remote (which usually causes this problem) labeled MTS or audio that can be used to adjust the audio. It could be that the tuner is bad. Using a cable box or VCR into an input would allow you to use the audio. If this doesn't help, respond with your setup and we may be able to figure it out.
Posted on Jan 13, 2007
Purchased a new Sony Bravia TV KDL32R420B. Picture perfect but no sound from Right speaker. Please help!!
Check whether the balance control is settings. Go to the audio menu to both TV and DVD player; and make sure that it is set to Centre position; to both the devices. Still there is no audio with one channel, check it with an other know good disc. Still you can't get sound from one channel, the audio output section to the TV circuit should be checked. Contact any service technician.
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Nov 01, 2014 | Televison & Video
I have a brand new LG 37" television. Picture quality is perfect but the in-built speakers vibrate heavily to a deep bass sound. I played "Close Encounters of the 3rd Kind" through the dvd player and in...
i also have this tv.same problem too.i bought two multimedia bose speakers for 100$. they are actually designed for a laptop but trust me....they are better than most so called surround sound speakers designed for tv's.these tv's are not known for their built in speakers.
Aug 17, 2010 | LG 37LG50 37 in. LCD HDTV
Speakers stopped working
Is it connected to a stereo or are you using hdmi? The reason I ask is that sometimes when there is no sound it could be due to a loose cable particularly when it comes to using optical cables. Have you tried unplugging all your external sound equipment including cable / satellite tv leaving the tv unit free from any external sources? If it then does not work (and the mute button is not on) then it is definately an issue with the tv. More often than not it is due to old cables or a loose cable. If the tv works then add in each extra thing like dvd player one at a time. If the sound goes you know it is the cable for that particular item etc.
May 15, 2010 | Televison & Video
My samsung lcd tv.32inches.lost sound .picture is perfect. model number LE32R88DB
Have you try to play with a DVD or other source beside cable? Did you check the TV speaker is on or in mute mode? Try to get TV back to factory reset.
If does not help, check the TV speakers by plug in an AV source.
Lastly, replace the main board.
Aug 13, 2009 | Samsung Televison & Video
Sound off
you are having problem on your tv with your tv sound ic this can be located ion the sound circuit just where the speaker is hooked up inside the set if you are not a tech have one repair your tv good luck
Jul 12, 2009 | Televison & Video
Cannot hear audio when connect dvd player to TV using analog audio cable
i think you need to get an Optical Digital Audio Cable and connect it to the tv and speakers then it should work
Jul 08, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
No audio from dvd player
you wil get the sound from the surround speakers only but not from tv first connect all the speakers that are given to the player correctly then you can get perfect sounds with dts...
May 04, 2008 | JVC TH-A25 System
There audio but no picture
I don't know how you connect the unit to the tv.
Let's just start on basic:
composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV.
If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable!
Jan 20, 2008 | Toshiba SD-V392 DVD Player/VCR
No Sound, perfect picture but no sound
go to the audio menu setup then find the sub menu speaker after that you will see some command indicates if you want to on or off the speaker, choose the on command to be able to hear the sound in your television from your dvd player.
Aug 25, 2007 | Sanyo DS24205 24" TV
Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV Logo
94 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
