Question about Garmin GPS 12 GPS Receiver
Error when powering up GPS
When I power up my GPS I get a message on the LCD screen that reads:UPLOAD NOT PRESENT Please would someone assist me in establishing what the problem is, as I have a lot of info on the GPS that I cannot even download onto pc, as it appears that the device is not initialising. Thank you kindly. rgds Gareth
My Garmin 12 was doing the same thing. I went to ebay and ordered the serial port to 4 pin GPS cord. I turned my computer off and connected the cord to my computer and GPS. I turned my computer back on and went to the Garmin website, and then to updates & downloads. There were two versions available and I went with the GPS 12 software version 4.60. Then I printed off the instructions and followed the instructions at the bottom of the page. I had some problems with #5. After looking at the Garmin download directory I found the file updater.exe and used it instead of the updatesw.exe which I didn't find in their directory. I only did this once but I remember seeing a pop up window confirming the serial port you want to use and another that I think verified the software version of my GPS. After making the appropriate selections on those boxes the download started and a box popped up that showed the progress. About 5 minutes later the GPS had shut off and when I turned it on it loaded. I had to go in and adjust the contrast but it appeared that all the previous stored waypoints were still there. Hope this helps, no promises. Good luck.
Posted on Jan 23, 2008
I would say that it has a bit of Umzumbe fever probably from the water it sucked up when you failed to warn me that it was in my pocket when i jumped over board, a bit like a beer can, no upload available
Posted on Jan 17, 2007
Garmin Forerunner 305 will not upload to Garmin connect, an error message says "object error"??
Try uninstalling and reinstalling the Garmin Communicator Plugin.
http://connect.garmin.com/help/start/usb
Also, you can call Garmin support for assistance.
http://www.garmin.com/us/support/contact
Sep 04, 2011 | Garmin Forerunner 305 GPS Receiver
All the sudden my garmin255w is reading system software missing. help how do i fix this?
I contacted Garmin and I was given the following sequence to recover from this condition:
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the above problem.
Apparently this sequence will only work with the above error. I hope this assists other if they encounter this problem.Thanks for using FixYa
May 23, 2011 | Garmin nuvi 255W GPS Receiver
USB device is not recognized
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Dec 01, 2008 | i.Trek M5 GPS Receiver
Brother MFC 3100 Printer/fax
This is the only reference I could find on error 41: How can I clear the message Machine Error 41 from the display? (ME41)
Machine Error 41 indicates a mechanical malfunction of the Brother
machine. Unplug the unit from the power source and then plug it back
in.
If the error message continues to be displayed on the LCD, please call
Brother Customer Service at 1-800-284-4329 for assistance. The Customer
Service center is open Monday through Friday, from 9:00AM to 7:00PM,
excluding holidays If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 16, 2008 | Office Equipment & Supplies
Upload not present message Garmin GPS12
Hi...once i was asked the same problem!....and we couldn't do anything...i think you lucky because...the one who asked me about the same problem crashed his software forever...i recommend you to go for the warranty...and not to attempt any update...
Aug 23, 2008 | Sport & Outdoor - Others
Reciever will not power up
The same thing happened to me. It turns out the USB to serial adapter had issues. Anyway to fix try this. Hold the NAV + Menu and press the power button. Your Sportrak should start up in software upload mode. You can then use the Magup program in expert mode to bring your GPS to life. I had to find a computer with a serial port to fix mine.
Jim
Aug 10, 2008 | Magellan SporTrak GPS Receiver
GPS 12 "upload not present"
I have a Garmin GPS 12, which has worked perfectly over the last 10 years until a few days ago. It was on and working fine, I marked a waypoint, turned it off and put it in my pocket. 45 minutes later I pulled it out and when I tried to turn it on it only showed the message "UPLOAD NOT PRESENT". Nothing I did would get it to show me anything different (I tried all kinds of button sequences...holding some down for many seconds, pressing multiple at the same time, etc.). The only thing it would do was turn on and show me that message, or turn off. I called Garmin and they said they could repair it, but that would require shipping it to them. They said it would cost $59 (which included the repair and shipping back to me, but I was responsible for whatever it cost to ship it to them). I asked if they would be able to save my routes and waypoints if they "repair" it, but they couldn't guarantee that. I told them that I heard "reloading the firmware" or "uploading the newest update" might fix it AND keep my routes and waypoints. They told me that might work. I didn't have the PC interface cable that was necessary in order to connect it to my computer to update it, so I asked them what it would cost to buy one from them. They said it would be $38.09 through them, but that I could get it cheaper on the Internet (part # 010-10141-00). Then they said they actually may have some of them sitting around in a box somewhere (I'm assuming they meant used cables). They checked around and found one and shipped it to me at no charge! It arrived in a couple days. Then I just plugged it into one of the serial ports in the back of my computer, plugged the other end into the GPS and turned it on, went to Garmin's website: http://www8.garmin.com/products/gps12/download.html and downloaded version 4.60. I'm not sure what version was on my GPS originally (I obviously couldn't check anymore since it wasn't working), but the user manual that came with it said "Software Version 4.03 or above". It asked me to unzip the downloaded files and stored them on my hard drive at C:garmin. I opened up the file named 460_UPDT.TXT and followed the directions listed there (which are slightly different from the directions listed on the website's update page). One of the steps said to "Turn on your GPS and ensure the Serial Data Format is set to "GARMIN". You can find this setting in Setup Menu -> Interface." I couldn't do this since mine only displayed the message "UPLOAD NOT PRESENT", so I just ignored this step. I opened up the file named UPDATER.EXE and had it "auto-detect" when it asked me which serial port I used. The message on the GPS screen changed to "UPLOAD IN PROGRESS" and it only took about 4 minutes until the upload was done. The GPS screen then changed to the start-up screen where it acquires satellites and asked me to enter my country and state. Everything seems to be back to normal and all my routes and waypoints are still there. Even better, it didn't cost me anything but time.
May 31, 2008 | Garmin GPS 12 GPS Receiver
Garmin 360
Have you tried performing a soft reset by pressing the reset button on the back of the unit, then turning it on again?
How about a hard reset?
With the unit powered off, hold your finger on the upper right- hand corner of the touch screen and tap the power key. Continue to hold your finger on the screen until you get a warning message. Tap "OK" to reboot the GPS.
Please let me know if I can be of further assistance to you.
- Jim
Feb 15, 2008 | Garmin nuvi 350 GPS Receiver
Garmin GPS 12
ok
inter in the site garmin
support+updates downloald+additionnel software+gps12+
ther is 2 version 4.60 dowload+ upleod
NB you must connect GPS and BC by cable
goodluck
from redbel001@hotmail.com
Dec 12, 2007 | Garmin GPS 12 GPS Receiver
Temperature below safe level warning when starting GPS
Ahh yes the ever so elusive temp. below safe level error. lol. (sorry) Attached to the radio board are 3 wires connecting to the top of your lcd. This is where the temp is read from. I know telling you this doesn't help, just info. This problem has been fixed from swapping out radio boards (the board that's behind your keypad), additionally swapping out hard drives. I'm not sure if the unit will detect the USB but, if you can, try re-loading whichever version you have ie. 4.32/5.14. As far as end user fixes, I don't exactly have one unless you can find a scrap unit that someone doesn't want b/c it's malfunctioned as well. Good luck and I wish I could of been more help. -Dan
Sep 24, 2006 | Magellan RoadMate 700 GPS Receiver
Garmin GPS 12 GPS Receiver Logo
157 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
