Question about Xerox DocuColor 12 Printer
System Fault I was in the middle of running a job of 500, 8.5 x 11, 2 sided when all of a sudden the machine went nuts. There is a system Fault message appears on the screen and the machine will no longer print anything at all. I have done what the machine requested on the screen which was to turn off the copier then pause... then turn on. We have repeatedly tried this and nothing has worked. Below the fault message is a number: 9-357. We have checked all the toners and everything is full however there is still no progress on the machine. Also to include in this problem, the black toner for sometime now has not been working. black & white copies do not come out solid...they are extremely faded. Whenever there is a full color print then the copier prints everything else but the black. What is going on with this thing?
U can get the manual from me alongwith all codes
agrwalsachin@gmail.com
Posted on Mar 20, 2008
    Problem Solver:
  • 4 Answers
Yes, I have the same problem on my machine. For some reason when printing anything that has a high coverage, the machine can't keep up to it's own toner requirements. One solution I've found is to do what Kemo says. If running high colour, switch to some black after a couple hundred sheets for a while then come back. If running all black, switch to some color. One other tip is if the "replace black toner soon" message comes on and you're doing a large job, replace it right away. If you don't the toner reserve will drop low and cause this problem again. I've had my sensors replaced a few times and while it helped, the problem still occurs from time to time.
Posted on Feb 15, 2008
    Sniper:
  • 56 Answers
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Posted on Nov 02, 2007
    Problem Solver:
Erroe 90357 frequently occcurs on my machine too. May instant remedy is go to MVREAD/WRITE
7760/61/62/63/64 and change all values to 0
Posted on Mar 25, 2008
  • sudhir masih Mar 25, 2008
    I have the problem of print quality and toner spilling on the printed material Copy ptints are not dark. I would want to know how to make the light copy/print dark from service mode
I Just changed the breaks on my 2002 yamaha vstar classic. Now i cant get my breaks to pump up. Any sugestions?
When you forced the piston's into the caliper to make room for the new pads, it sometimes will put air in the system if you didn't remove the master cylinder cap first, or possibly went too fast. Anyway, it just happens sometimes. You'll need to bleed the brakes, which isn't too hard.
Put some 3/16 clear fuel line on the bleeder nuts and run them to a drain pan to catch fluid and so you can view the air bubbles. Open the master cylinder cap. Get a helper to slowly pump the lever a number of times, and then hold it down. Start with the left brake bleeder first, and open the nut while the lever is held down. Watch for the bubbles to stop and close the nut BEFORE releasing the lever-otherwise you'll **** air back in the system. Repeat process until no more bubbles come out, and then repeat on the other side. Watch the fluid level closely in the master cylinder and add as needed to insure it doesn't go dry while your bleeding or you'll put air in the system there as well. Set fluid level in the middle of the window in the master cylinder when you're done, replace the cap and your back on the road. good luck!
Jun 12, 2011 | 2002 Yamaha V Star Classic
Middle of cycle message comes up "err7"
Good day, FRIGIDAIRE GALLERY SERIES 4y old well mantained and clen even strainer. the electronic system suddenly went off change of cycle does not show the change of minutes an 18h shows on screen, disconect for a wile appears to work, it starts and stops after 10 minutes and beeps ready no lights then goes crazy again. Please help email: arupro@setarnet.aw
Aug 25, 2010 | Frigidaire ATF6000ES Front Load Washer
Everything comes on but wont start wont even turn over ever since my house was struck by lighting
seen the film, war of the worlds, when all the cars went dead, well so has yours, in the same way,its called Electro Magnetic Pulse.and it kills all your relays.and computer engine management systems.this is not an easy job as you will have to connect to a diagnostic machine while you are searching for faults,unless you are a dab hand at car electrics,get it done by qualified vehicle technician.
each system has a potential fault,and you have loads.
Jun 18, 2010 | Cars & Trucks
Keyboard freezes while typing
My computer does the same thing. I figured out, however, that rather than shutting the computer completely off and rebooting, I can just close the top. When I reopen the computer and go back to the document on which I was typing, I am then allowed to continue. Hope this helps.
May 17, 2010 | ASUS Eee PC 1000HE Netbook
Constant noise from Mirage NanoSat 5.1 System Subwoofer
sounds like an earth fault either with the plug circut or more likely with the power board of the unit.
Jan 06, 2010 | Mirage NANOSAT 5.1 System System
2 year old side by side refrigerator & freeze stopped working. Neither side will cool. Model # 106.55122700 manufactored 6/2007. No pool of water, etc.
Is the machine turned on and can you hear it running??
If nothing is running then it could be a defective cold control (thermostat) or the machine went into a defrost mode and failed there. If it is running then.....
Open the freezer door and you should hear a fan motor running.
If not the fan motor is defective and needs replaced.
Look to see if there is frost building up on the back panel in the freezer section. If you see a buildup, then the defrost system needs repaired.
There is another fan motor located in the machine section behind the cover on the back rear of the fridge. It must be running as well.
If none of these items check bad, then you could well have a failed sealed system, including the compressor.
The sealed system carries a 5 year warrant. Call your selling dealer for service.
Nov 03, 2009 | GALAXY Microsystems 25.4 cu. ft....
Print job stops in the middle of a print job
first if its happening from few days than go for system restore - start - all programs - accessories - system tools - system restore.. select that date on which it worked fine.. or else add printer and install deskjet 990c and than try
Oct 14, 2009 | HP DeskJet 722c InkJet Printer
Canon c3220: delete print job from memory
go into system monitor on the main screen and click on the print jobs recieve and clear them,
Canon Technician
Mar 05, 2009 | Canon imageRUNNER C3200 Copier
Error code 010-348
Hi go to system settings and then go to NVM location then type 744-003 and then change the value in the lower field to 0.
Jun 26, 2008 | Xerox DocuColor 3535 Copier
System fault
Refer to the link i posted and put in you question in the box and that should give you a correct information as its the manufacturer.
May 13, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
910 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
